Question about Water Heaters
I have a Kenmore Econominder water heater. Model 153-332040 40 gal natural gas/direct vent WH. The last several days it starts up and runs for about 10 seconds 1-2 times before it stays on and heats up properly. I appreciate the help, RJ
  • RJ H2O
    RJ H2O May 29, 2011
    Back up and running. Code showed pressure switch problem. Unplugged WH, Turned off gas. Air intake for burner was partially plugged. Vacuumed it out and blew all debris out. Burner was partially plugged with soot causing too much back pressure on gas valve. Consequently the gas valve would stay on too long and trip safety override. Completely cleaned, vacuumed, blew out out burner assembly. Fired it back up and it works like new.
    Why do these things always happen on holiday weekends?
    That cold water shower this morning was a brutal wake up.
    RJ
Water heater burner assembly and combustion chamber probably needs clean and maintenance.
I suggest calling sears service 1-800 469-4663 or plumber.
I'm on Sears/ American/ Rheem/ Reliance etc gas water heater websites most days, and read gas water heater manuals continually.
http://www.sears.com/shc/s/search_10153_12605?keyword=kenmore+power+miser+9+40+gallon+gas+water+heater+gas
http://www.sears.com/shc/s/s_10153_12605_Appliances_Water+Heaters_Natural+Gas
Most people don't fix air conditioning without knowledge going in, but people think water heaters are simpler, because water heaters were simpler a few years ago.
Today, gas water heaters require testing equipment, and specialized tools, plus replacement parts.
Possible problems include: Improper fuel-air mixture, dirty air intake, venting problems, gas control valve problems, air in gas line, low gas pressure, dirty combustion parts, Water condensate dripping on burner, chemicals stored inside same room. Service technician will review all these things during troubleshoot, and you can watch technician and glean information for keeping water heater working longer than warranty.
http://waterheatertimer.org/Replace-anode-rod.html
If repairs are going to cost more than $400, then install new gas water heater yourself same day:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 24, 2011
  • RJ H2O
    RJ H2O May 24, 2011
    I read where if the polarity is reversed this can cause an issue also. I changed to a different outlet, it still short cycles for about 5-10 seconds, but only 1 time before it stays on. The water is now hot. When I checked the controls, I thought this was peculiar, the control settings were at the temperature I had set but the vacation setting / light was also on and no hot water. After I moved the plug I reset the settings and the unit fired up but is short cycling as stated here. Can high humidity cause this problem, affecting the burner? My chimney footing has been wicking up water ( which is next to the water heater, very high water table this spring and NO the water is not coming from the WH) and I have had some standing water by the WH. I fired up the dehumidifier this week.
    Thank you,
    RJ
  • Anonymous May 24, 2011
    (1) Well RJ. Change the vote to 4 thumbs, and we'll call it square (2) Clean the burner assembly and combustion chamber which includes visible check for condensate problem, which can be related to humidity, and can clog incoming air (3) call technician unless you know how to clean burner and combustion chamber and do the required yearly maintenance. (4) If you heard that reversed polarity was an issue, then use cheap circuit analyzer from home center to check outlet. (5) if repairs are going to cost more than $400, then install new heater (6) They sell electric water heaters for $207 that require no maintenance except flushing each year. (7) gas water heaters require yearly maintenance, so clean the burner and combustion chamber.
Suburban Water Heater-Sw10de-10 Gal Gas/Elec W/Direct Spark - 5063A
Manual Yes 12 volts may help. I can't see anything about your switch from this manual
Dec 02, 2013 | SUBURBAN MANUFACTURING C Suburban Water...
Have 75 gallon gas water heater. Can I run 90 PVC off top power vent without vertical PVC first? Have Richmond unit.
1) I believe you can immediately elbow the PVC pipe.
There is a limit for how many elbows can be used between blower and termination, and limit is determined by diameter of PVC pipe.
2) Copy following link for venting resources and typical Rheem and Richmond power vent manuals, and diameter-elbow pdf from Bradford White.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#venting
3) Richmond is Rheem. Product manual will show specifications for venting.
Product warranty is voided if installation does not follow specifications shown in manual.
Feb 20, 2013 | Rheem Richmond 75 Gal Natural Gas 6 Year...
RUUD 100-199 GAS WH keeps turning off
check regulator @ gas meter or bottle station is set to correct presure, may need replacing.
Oct 10, 2012 | Rheem RUUD G100-200 Water Heater,gas,100...
Loud Vibration/Noise when System Starts
This happen when there is air in the gas line...if the problem is still there after a couple of days you will have to return the unit for an exchange the gas control is giving problem...contact rheem first before making a exchange decision..they will walk you some step first to ensure there is not a problem
Jul 03, 2010 | Rheem Direct Vent Natural Gas Tankless...
Problems with bosch 1600h ng tankless wh igniting
I found that the solution to my issue of not igniting was due to a bad pilot electrovalve part #8708501249. It was about a $50 part that was bad from the start.
Really disappointing that Bosch's QA would let a such a defective part ship. I spent about 3 years of using a workaround with a fan blowing air to get ignition until it finally failed. I had a tech look over the system to point me in the right direction.
Mar 23, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Eractic Power Vent Gas Water Heater
Th epproblem you are most likely have is from a safety called a flag switch usually located either in the blower or right past it. When you unplug and replug you reset the switch. Sequence of events.  1 fan comes on. 2 switch is made from the airflow of the fan.  3 ignitor come on 4. main gas valve opens and ignitor starts flame.
You are being stopped at step 2 when the fan does not move with the air. This shuts off and out the water heater from calling again.  Find the fan switch and make sure it moves easily. They get dirty and also dry from lack of lube. Good luck.
Mar 16, 2009 | Water Heaters
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Water Heaters Logo
294 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
