Question about Connecticut Electric UBIZ0215 Zinsco Circuit Breaker 2Pole 15Amp Thin Se
Are there zinsco afci breakers available? - Connecticut Electric UBIZ0215 Zinsco Circuit Breaker 2Pole 15Amp Thin Se
    Problem Solver:
  • 18 Answers
I have never seen one before I don't think that they have one. I was able at one time to get a zinsco GFCI breaker but even that was difficult and it was used with no returns and very expensive. Sorry
Posted on May 26, 2011
How to find zinsco main breakers?
HomeDepot.com carries Connecticut Electric breakers. They can supply breakers for outdated electrical equipment, including Zinsco (Sylvania), Challenger, ITE push-a-matic, Wadsworth, etc. Prices are high though, it would probably be better to purchase and install a new panel.
Aug 26, 2014 | Electrical Supplies
Where can I locate a copy of a troubleshooting guide for arc fault problems with your product?
AFCI (arc fault circuit interrupter) devices such as yours rarely have a problem - but a trip indicates there's a problem with the circuit it is supplying. It like a fuse - they generally don't go bad by themselves - but do when there's a problem.
AFCI have the unique ability to detect arcing - or sparking. An arc or spark is very hot - and is a fire hazard. An AFCI can sense this condition before it is even seen - if it were in an exposed place that it could be seen and shuts off power. Arcing can occur at a loose connection, such as in a wirenut, terminal screw, etc. The AFCI can also detect when a cable support staple has been driven to deep and crushed through the cable insulation and is beginning to cause a high resistance short circuit. Because these problems often occur where they can't be seen, it is a labor intensive job to locate and repair the problem. Sometimes, entire sections of circuits must be re-fed due to the location of the fault. Due to the complexity of searching for the fault, you may want to call an electrician to clear the fault for you. You should not under any circumstances replace the AFCI with a standard circuit breaker or GFCI type circuit breaker. You may however, change it with an adjacent AFCI breaker to determine if the issue is with the circuit - or the AFCI. If the AFCI trips on the new circuit, you should accept that it has failed and should be replaced. If the problem stays in the same circuit, then the AFCI is good and the problem is in the circuit somewhere.
Here are a couple links to youtube videos that may help you understand the how and why of AFCI devices: video 1 and video 2. A link back to Siemen's site on AFCI is here.
I hope this helps and good luck. Please rate my reply - thanks!
Apr 21, 2011 | Siemens Seimens Arc Fault Breaker
Can and arc fault circuit interupter be on a grounded neutral panel
Yes, the (coiled) white wire that is permanently attached to the breaker connects to the neutral busbar in the panel and the white wire that goes to the circuit that you want to protect connects to the "white" terminal on the AFCI breaker.
Aug 05, 2010 | Eaton Corporation BR120CAF AFCI Circuit...
Eaton afci breakers tripping out due to lightolier low voltage lighting. Lightolier and eaton both agree that it is a frequency problem but neither has a solution. Any help?
everytime I plug in my vacuum cleaner (Kenmore canister model) I trip the Eaton AFCI Braf breaker. Now it doesn't even work though I can flip the switch back to the on position
Jul 19, 2010 | Eaton ARC FAULT CIRC BREAKER
How to install arc fault circuit interrupter
connect the neutral from the circuit to the afci breaker, and run the neutral that came on the afci breaker to the neutral bar in the panel. Make sure that the neutral that you connect from the circuit to the afci breaker is the one that belongs to the circuit that you're protecting or the afci wont work.
Sep 19, 2009 | Siemens Seimens Arc Fault Breaker
I need to install a GFI breaker on a Baptistry.
You could install a standard GFCI in line at each component ( heater, pump & timer) or you could install AFCI breakers similar to what are required in many residential codes (provide the same protection at the panel not at the location... http://www.cpsc.gov/CPSCPUB/PUBS/afcifac8.PDF
The AFCI breakers will need to match your panel type (siemens, GE or Square-D) and the amperage/configuration.
I would install them at the lowest level (closest to the components) in the system to reduce possibility of fire in the wiring between the components and the afci breaker.
Jan 04, 2009 | Electrical Supplies
Hello: I have an old electrical box with the old style Zinsco beakers. For some reason, the left side of the main 200 amp breaker continues to go out. only one side. the breaker arks right where I screw...
The screw is loose. It is always HOT (has electricity going to it) so be careful. If you feel confident, cover a screwdriver with a few layers of electrical tape and tighten it. Depending on how long it has been arcing, the breaker will need to be replaced. Since the incoming wire will have power to it, have a licensed electrician do the job. He will possibly remove the meter head to cut the power while he does the work.
Jan 03, 2009 | General Electric 100Amp 3-pole circuit...
Connecticut Electric UBIZ0215 Zinsco Circuit Breaker 2Pole 15Amp Thin Se Logo
465 people viewed this question
Top Connecticut Electric Electrical Supplies Experts
Steve
Gene Haynes
Steve Pack
Steve Pack
Are you a Connecticut Electric Electrical Supply Expert? Answer questions, earn points and help others
