My Hp 6735s laptop won't turn on, I removed the battery and tried to turn it on using the ac cord only, but still the same problem. I can feel electrical charge on the laptop body. kidher
  • 336 Answers
Try to test using voltmeter your power cord charger of laptop maybe loose wiring or damage power supply.if same problem need hp service center that's damage motherboard.
Posted on May 23, 2011
Toshiba Satellite won't start up when AC plugged in
Try another Cord/Charger to verify the Cord, AC jack. If you plug in the AC cord after starting on battery, does the battery charge? Open Control Panel, Power Options, set to High Performance, Advanced power settings, set Sleep and Hibernate to Never, Adjust Advanced power setting to your preference.
Feb 06, 2013 | Toshiba Satellite L300D-ST3501 Notebook
I got a hp 6735s laptop battery that tells me that i should consider replacing my battery when i power it on but when i remove the battery and i plug in the a/c cable direct it works well what could be...
If the battery is removed you will see a X in the battery icon in the Tray Notification Area, indicating no battery present, your laptop is working off the AC cord/transformer. It will work this way forever. If you do not need to use a battery , just use plugged in. The idea of a laptop is it's protable, hence the battery, no AC option. The battery must be reaching the end of it's "lifecycle", replace the battery with a Good replacement with the EXACT same power specs. Beware of inexpensive batteries, they , sometimes don't work well and COULD be a fire hazzard, they are cheap for a reason.
Dec 27, 2012 | HP Compaq 6735s Notebook
Internal battery error 601 hp compaq 6735s laptop
Remove the main battery and run the ac adapter only, if everything works fine the battery will need to be replaced, if the computer continues to shutdown the problem is most likely a bad cooling fan or it needs to be taken apart and given a good cleaning.
Jun 16, 2012 | HP Compaq 6735s Notebook
HP Compaq 6735s Laptop screen was blank when turned on
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Mar 26, 2012 | Computers & Internet
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My hp 6735s laptop battery not charging says pluged in but not charging only 1 year 6month old
r u getting the message when on AC power that the "smart AC adapter is not providing enough power" ?? If yes then remove the battery and c if the laptop works fine with just the adapter plugged in ...
if yes then take power cord out of the adapter from the end that goes to the wall socket .. that side is removeable ..then plug it back in and flip the way its plugged into the wall socket .. c if this helps ..
Oct 22, 2010 | HP Computers & Internet
Hi all please i need a hardware specialist who is conversant to the HP compaq 6735s AMD sempron 1gig ram notebook to help me on this one i made a mistake trying to use the ac adapter for another hp...
internal component failure close to adapter socket Maybe user serviceable problem with recent surface mount components not really repairable by consumer
Sep 06, 2010 | HP Compaq 6735s Notebook
HP Compaq 6735s battery light orange blinking
Have you tried another power cord? If you try another power cord, and it still does the same thing, then I think your laptop is having a power problem. You need to take is to a technician to fix the problem for you.
Best wishes.
Nov 28, 2009 | HP Compaq 6735s Notebook
I have a hp 6735s laptop that i bought recently and when the adapters not plugged in the screen keeps going bright for a second then dull how do i stop this?
So you mean the screen goes dimmer when you remove the AC POWER ADAPTER?
If so, then this is due to the POWER SAVER mode that most laptops use for when not plugged into AC.
In control panel (if using XP) there should be a POWER MANAGMENT or BATTERY MANAGEMENT icon or section. In here there are usually settings for what you want the laptop to do with regard to power under different scenarios (ie. No adapter, with adapter, etc).
In the settings there should be an option to turn off power saving mode when the AC adapter is not plugged in.
Mar 27, 2009 | HP 6735s Notebook Laptops
Computers & Internet Logo
180 people viewed this question
David Payne
David Payne
