Question about Xante Ilumina® 502 Laser Printer
I have a Xante 502 and need a service manual. I have 917 codes and take the Xfer belt assembly and clean sensors to left of assemble. I have a lot of loose cyan toner in this area. I do not know for sure if I am cleaning the right sensor. I need manual to troubleshoot problems. Do I have a Cyan drum problem or a Xfer Belt problem? Do I need to change one of these? Jerry
Soulvisitor
  • 1113 Answers
SOURCE: toner sensor problems
On the base of machine after removing drums and transport, there are 4 sets of 3 pins that connect to left hand bottom of each drum, these can get toner on them and not make proper contact, each set of 3 pins just pop out with the help of a flat blade, out of base to be cleaned. in yout case just switch the set under the cyan with another lot from different colour.
I am taking it that you are using genuinne non imported oki drum and toner. If this doesnt fix your problem then you must have fauly drum/toner
Posted on Nov 13, 2007
mosesclive
  • 191 Answers
SOURCE: diagonal lines on print
Follow these steps.
Print Quality Problems on 3010cn.
Reset the NVRAM On the 3010cn
To reset the NVRAM, perform the following steps:
  1. Press the Menu button.
  2. Press the down%20arrow%203100cn.jpg (down arrow) button on the printer until Configure appears, and then press the right%20arrow%203100cn.jpg (right arrow) button on the printer or return%20arrow%203100cn.jpg (Set) button.
  3. Press down%20arrow%203100cn.jpg on the printer until Maintenance appears, and then press right%20arrow%203100cn.jpg on the printer or return%20arrow%203100cn.jpg.
  4. Press the down%20arrow%203100cn.jpg until Init NVRAM appears, and then press right%20arrow%203100cn.jpg or return%20arrow%203100cn.jpg.
  5. Press return%20arrow%203100cn.jpgInitializing and Restart Printer will appear.
  6. Power off the printer and power back on.
To print the Gradation [ESS] test print, perform the following steps:
  1. Power off the printer.
  2. Hold down the up and down arrow buttons on the printer and power the printer on. This will bring up a Customer Mode menu.
  3. Press the down arrow button until Test Print appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow button until Gradation [ESS] appears and press the return%20arrow%203100cn.jpg button.
  5. Press the return%20arrow%203100cn.jpg button. On the LCD, Processing appears and the test page is printed.
To print all four 20% toner test prints, perform the following step:
  4. Press the down arrow until Cyan20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  5. Press the return%20arrow%203100cn.jpg button. The test print will print.
  6. Press the Cancel button.
  7. Press the down arrow until Magenta20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  8. Press the return%20arrow%203100cn.jpg button. The test print will print.
  9. Press the Cancel button.
  10. Press the down arrow until Yellow20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  11. Press the return%20arrow%203100cn.jpg button. The test print will print.
  12. Press the Cancel button.
  13. Press the down arrow until Black20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  14. Press the return%20arrow%203100cn.jpg button. The test print will print.
  15. Press the Cancel button.
  16. Power off the printer and power back on.
Reseat the drum cartridge, perform the following steps:
  2. Unplug the power cable.
  3. Pull to open the front cover and then lift to open the top cover. (Figure 1)
    Figure 1 - Open Front and Top Covers
  4. Raise the lever on the top right side of the drum cartridge. (Figure 2)
    Figure 2 - Raise Lever to Release Drum Cartridge
  5. Grasp the drum cartridge by the handle and lift up and out. (Figure 3)
    Figure 3 - Remove Drum Cartridge
  6. Insert the drum cartridge.
  7. Close the top and front covers.
  8. Plug in the power cable.
  9. Power on the printer.
Posted on Dec 20, 2007
Hi i have the solucion a error of sensor black oki c3100. For two times i have the problem and a long time study the problem. it´s the solucion. Because i spanish the solution is in spanish languaje.
Desmontar la tapa semitransparente redonda del lateral.
El sensor lleva un iman incorporado que dice a la impresora cuando el toner se a agotado. El polvo de impresion lleva impurezas o las ponen a proposito y hacen que el iman no pueda levantar la leva que hace contanto con el sensor. Con un destornillador limpiar las impurezas que estan pegadas al iman por dentro del toner. Cerrar y listo. YA FUNCIONA JAJAJAJAJAJAJAJA.
Posted on Apr 25, 2008
rooboy
  • 24 Answers
SOURCE: Xante Illumina runs very slow when printing on
you need to check your settings, you may need to fool the machine..
on the webpage, or the front panel, select material type as plain.
set the weight setting as auto.
in the driver, make sure the setting is set to "printer Setting"
also in the driver check the selection for "black" instead of "colour"
hope this helps..
Posted on Mar 13, 2009
  • 253 Answers
SOURCE: problem
in photoshop or MS word just increase the contrast of the image and all dirty gray background will disappear and if u need our technician support contact http://tinyurl.com/mtgjzz
Posted on Jun 22, 2009
How do I replace a fuser for a Xante Accel-a-Writer 4G?
dear please find back cover and open it found big unit of printer called printer fuser assembly.removed it carefully you need one Philips screw driver,losses the two screw after that you removed screws slide it right side if you stand back of the printer,however after remove the fuser assembly you can installed it new in the Xante 4G printer when you install slide fuser to left side and alignment carefully,hope you understand.
thanks.
Jun 19, 2014 | Xante Accel-a-Writer 4G Laser Printer
Yellow registration problems on xante 502
clean all the registration sensors on the imaging drums and at the fuser end (there are 3 under a shifting piece of white plastic on the left side after transfer belt is removed.
May 15, 2014 | Xante Ilumina Digital Color Press Printer
Close top cover . error code: 310
Make sure the door is not binding on anything and check the area around the door where it shuts. It could be a sensor malfunction or the door is worn and the sensor is detecting it.
Jul 24, 2012 | Xante Ilumina® 502 Laser Printer
I dont have the manuals to my philips universal remote so i need to add componts dvd
Try this link, http://www.universal-remote.net/philipsmagnavox.html
or instructions are as follows - Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
TV
MULTITECH ................... 906
MULTIVISION ................. 010
NAD ............ 002 120 502 512
NEC ............. 002 102 110 111 502 510 602 901
NIKEI ................................ 805
NIKKO ............... 002 407 502
NTC ................................... 407
ONKING ............................ 805
ONWA ........................ 805 906
OPTIMUS .................. 120 618
OPTONICA ............... 111 918
ORION ................ 105 115 713
PANASONIC ...... 007 107 516 608 618 718 807 901
PHILCO ...... 002 009 102 109 309 402 408 502 508 807 901 914
PHILIPS ..... 002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
PILOT .............................. 002
PIONEER ...................002 120 502 519 610
PORTLAND.................002 102 407 502
PRECISION ....................... 218
PRICE CLUB .................... 112
PRISM ................................ 107
PROSCAN ......... 312 601 704 719
PROTON .................... 002 119 220 502 910
PULSAR ............................ 713
PULSER ............................. 002
QUASAR .... 007 107 516 608 618 718 807 901
RADIO SHACK/REALISTIC ......... 002 111 117 406 502 506 601 618 704 705 805 818 906 914
RCA ..... 002 011 102 211 302 312 318 320 406 409 411
420 502 511 514 519 601 702 711 719 809 811 901 909 911 912 914
RHAPSODY ..................... 003
RUNCO .............................. 713
SAMPO ....... 002 119 502 818
SAMSUNG .. 002 012 102 103 112 212 502 512 818 914
SAMSUX ........................... 502
SANSUI ....................... 115 215
SANYO ............002 412 506 619 902
SCOTCH ..................... 002 502
SCOTT ............... 002 004 105 206 502 805 906
SEARS ............... 002 112 206 312 502 506 512 520 601 612 619 704 719 902 914
SHARP 002 013 014 111 502 712 812 813 913 918
SHOGUN ........................... 002
SIGNATURE ...... 601 701 903
SIMPSON .......................... 402
SONIC ................................ 003
SONY .................. 202 708 801
SOUNDESIGN ... 002 206 402 502 805 906
SPECTRAVISION ............ 921
SQUAREVIEW ................. 520
SSS ....................... 002 805 906
STARLITE ........................ 906
SUPREMACY ................... 019
SUPREME ......................... 801
SYLVANIA . 002 009 109 209 309 402 408 502 508 717 807 914 917
SYMPHONIC..... 520 904 906
TANDY ............................. 918
TATUNG ........................... 901
TECHNICS ................. 007 107
TECHWOOD.............002 007 107 502
TEKNIKA .. 002 019 102 112 206 209 402 407 502 512 601 618 701 805 902 906
TELECAPTION .............. 313
TELERENT ............... 601 701
TERA .......................... 002 220
TMK ........................... 002 502
TOSHIBA ... 112 313 413 506 510 512 613 902
UNIVERSAL .............. 310 806
VICTOR ............................. 607
VIDTECH........... 002 102 502
VIKING .............................. 019
WARDS ....... 002 004 009 102 109 111 206 209 310
408 502 508 513 601 701 704 806 807 914
WHITE WESTINGHOUSE ... 311 611
YAMAHA... 002 102 502 914
YUPITERU....................... 805
ZENITH ............. 002 008 115 215 405 407 601 701 713 903 916
Jul 03, 2010 | Philips Televison & Video
SERVICE CALL 14 XFER ROLLER
The problem is most likely due to the little optical sensor assembly on the Transfer Belt getting covered up with toner. When you pull the transfer belt unit out and flip it over to the right, it will be located on the top left of the unit. It looks like a little rectangle sticking out over the edge of the plastic transfer belt. Remove the sensor assembly by removing the screws around it, and it should come right off (will have some wires running to it). You can further disassemble the sensor by removing the circuit board holding the LED and receiver. You'll have to clean toner out of or off of both of these. Mine had more on the emitter (LED), but YMMV. Be careful removing the circuit boards, because if you break it, it's $330US for a new transfer belt. 8-o
Mar 01, 2009 | Minolta magicolor 2200 DeskLaser Printer
917 error code
That is a transfer belt error, The edge of the belt is not being sensed.
Take the transfer assembly out and reseat it. if that doesn't fix it, return the belt assembly for a warranty exchange. Sometimes just taking the transfer assembly out and putting it back in retracks it properly.
Feb 14, 2009 | Xerox Phaser 7400/DXF Laser Printer
Service Call 15H
FATAL ERROR CODE 15H / SERVICE CALL 15 XFER BELT: Incorrect pressure
by or separation from the transfer belt cleaner
something wrong with the transfer belt
Aug 21, 2008 | Konica Minolta magicolor 2300DL Laser...
Power Off/On Fatal Error : 917
The 917 fatal error is a belt **** se sensor error. This could be caused by the belt not installed correctly or the belt at the end of its life, or the belt being torn. Please power the printer off and then reseat the transfer belt and then power the printer back on. If the error remains then I will need you to check the life remaining on the transfer belt. Also make sure the transfer belt is not torn.
Aug 08, 2008 | Xante Ilumina Digital Color Press Printer
Xante Ilumina® 502  Laser Printer Logo
166 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Dudeman321
CheckitRight
CheckitRight
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
