Question about Karcher Pressure Washer 1800 PSI 15 GPM Model K348M
My karcher 289 pressure washer is leaking at the trigger gun,where the cobnnection is
SOURCE: Karcher K3.91 compressor run for a few seconds every 10-15 second
They have a problem. I removed both valves and lubed with lithium grease as I was told. Unit is now working for how long who knowes.
Posted on May 19, 2009
  • 92 Answers
SOURCE: Electric Karcher pressure washer surging when turned on
Dear firenutt681,
One simple thing you can do, is to check for leaks. Check if hose at machine is leaking. Check gun if it is leaking. You can also check if water still comes out of lance nozzel. These leaks however so small, will cause the machine to surge.
Another reason is due to a faulty SPILL VALVE. This spill valve( often called CONTROL VALVE) will contract when the gun is closed. When it contracts under the enclosed pressure it will switch off the machine by means of a Micro Switch. Now if this Spill valve is faulty it will loose its compression under pressure and puts on the micro switch again. This can be seen once in a while or more frequent, as in your case. I sometimes do service Spill Valves, but mostly I replace them with a new one. I do not know the model number of your machine, but normally you have to open the cover and you should spot the spill valve on the head. Most probably you see a thick wire or a cap containing the micro swith. If you find the micro switch, you have found the spill valve. Sometimes it is a bit hard to pull out the spill valve. Myself, in various Karcher models I remove the spill valve by trying to feed water and put on a bit the machine. In this way the spill valve will be spitted out.
Another reason which makes your machine surge, is leakage from from the detergent inlet.
If you do not see no leakages at all....then for sure it is the SPILL VALVE.
If you cannot do this job yourself or you do not find spare parts...you can continue using the machine as it is...but before closing the gun...switch off the electricity. I only recommend this in an emergency. You do this so that you do not leave the machine surging. This surge will for sure damage the electric motor and the capacitor (assuming it is single phase).
Regards,
Fulltech.
Posted on May 30, 2009
  • 104 Answers
SOURCE: Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
Posted on Jun 05, 2009
  • 12 Answers
SOURCE: I have a karcher 2400 psi pressure washer and it
the most comon problem with thease is a stuck bypass valve, this is the valve that alowes the water to bypass round the pump when the triger is closed, when they stick all of your pressure runs around the pump and not out of your nozzle,,
its located in the centre of the pump on the top, undo the 2 cap screws pull out valve greese and re fit
Posted on Jun 18, 2009
  • 5 Answers
SOURCE: karcher pressure washer trigger problem
The wands that it will not run with would most likley have a little dirt in the tip of the nozzle. This would not allow the water to flow through in turn activating the pressure switch and shutting the machine down
Troy
Posted on Jul 08, 2009
Karcher gun leaking
the gun needs replacing, non servicable, interchangable with many brands
Mar 21, 2014 | Garden
My electric Karcher pressure washer does not shut off.
this can be that you need to bleed the system of air or that there is a problem with your trigger gun sticking when you release the trigger.
These are two things I would check before you go into the machine.
May 14, 2012 | Karcher Garden
Water leaking from spray gun
It depends on were the water is leaking from on the gun. If the water is leaking from were the high pressure hose goes into the gun it could be that on oring as been damaged. If the water is coming from the trigger you may need a new trigger gun.
If you tell me your model number (1.xxx-xxx.0) i can tell you the part number that you will need to give to your Karcher dealer/supplier to replace it.
Jan 02, 2011 | Karcher Garden
Engine runs , not getting any water flow when trigger pressed.
Disconnect hoses.
Look for kink in water hose.
Check incoming water connection for filter washer
Replace filter washer
If you don't have a filter washer, put one in.
Hook up water, and turn on
Water should come out other side of pump.
Turn on machine.
Do you get pressured water out of pump.
If no pressure, then pump is suspect
Hook up washer hose without gun
Does pressure come out of washer hose
Finally, the gun trigger may be bad.
We had to buy guns now and then.
Search for pressure washer guns
Following link shows guns we used:
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
Why dose my Karcher K2.35 keep blowing the gun hose off?
There is a good chance you are missing the black plastic clip that holds the hose into the trigger gun. If you look at where the hose goes into the gun there should be a flat slot where a black plastic clip would slide in and keep the hose into the trigger gun.
Oct 24, 2010 | Karcher 2500 PSI Pressure Washer
The handle leaks and seems to not have the tension on the handle. I have it apart and it seems like a tension string is broken but I can't see how it reconnects.
They don't offer parts for the trigger guns, you would just need to purchase a new trigger gun. There is a number of different trigger guns for these machines though, what is the model and part number of the machine that you have?
Oct 10, 2010 | Karcher 2500 PSI Pressure Washer
Karcher Model K 2.40, water is leaking from the gun at yellow trigger.
You are going to have to purchase a new trigger gun, they don't offer any parts for replacement on the inside of this trigger gun. See this link to purchase a new one.
Oct 08, 2010 | Karcher FactoryReconditioned K240R 1400...
Faulty
water is pouring out of my 5 year old karcher from the trigger handle WHY???
May 22, 2010 | Karcher PSI Electric Pressure Washer
Karcher K 3.68 M operation
These units have pressure valves that automatically turn off the pump once the pressure is high enough. The pressure switches do fail and sometimes stick and act as you've described.
May 07, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Karcher Pressure Washer  1800 PSI 15 GPM Model K348M Logo
177 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
