How do i change the nat type from strict to open on a att mifi 2372?
Joed911
  • 4338 Answers
SOURCE: Change NAT to open
Open an Internet Explorer browser page.In the address bar type - 192.168.1.1
Leave username blank & in password use admin in lower case...
Click on "Applications and Gaming" tab and then click on "Port Range Forwarding" subtab...
1) On the first line in Application box type in ABC, in the start box type in 88 and End box type in 88, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
2) On the second line in Application box type in PQR, in the start box type in 3074 and End box type in 3074, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
3) On the third line in Application box type in XYZ, in the start box type in 53 and End box type in 53, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box and click on Save Settings...
3) Once you return to the set up page click on the Security tab and uncheck Block Anonymous Internet Requests and click on Save Settings...
4) Click on set-up and change the MTU Size to 1452 and click Save Settings...
5) Goto the XBox Network Settings and IP Address Settings and select manual IP Settings and assign the following on your Xbox
IP Address :- 192.168.1.20, Subnet Mask :- 255.255.255.0, Default Gateway :- 192.168.1.1...
6) Also assign the DNS Addresses on the Xbox
Primary dns :- 4.2.2.2...Secondary dns :- 192.168.1.1
7) Turn off your modem, router, and Xbox...Wait for a minute...
8) Plug the modem power first, wait for another minute and plug the router power cable, wait another minute and turn on the Xbox and test it...it will connect... Kudos! Thanks! If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 05, 2009
  • 138 Answers
SOURCE: i need to change my nat type from strict to open
This router does not have the typical "strict or open" NAT types. Looking at the manual, it looks like what you want is NAT enabled and SUA only enabled.
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906173729&ModelIndexflags=0,420041221102511,420041221102520,420050117110858,420050117110916,420050117110934,420050831093216,420050831095441,420060420160946,420060420161739,420060816160116,420080815092146,420090427144843
Page 133 has the details.
Log into router
go to the NAT tab
Enable NAT
Enable SUA only
Apply the change.
Posted on Nov 18, 2009
govinda123
  • 2260 Answers
SOURCE: ok my nat type is strict and i am trying to change to open
You want the NAT open for X-box ?
For X-box you will need to open some ports on the router.
Also you will need to reduce down the MTU on the router to 1365.
That will work.
for this you will need to open the router set up.
Click here for more info about x-box and router settings
Posted on Dec 10, 2009
govinda123
  • 2260 Answers
SOURCE: HOW DO I CHANGE MY NAT TO OPEN FROM STRICT?
redu8ce the MTU settings on the router to 1365.
you will also need to open some ports for PS3 on the router.
For this you will need to access the router set up page.
connect a computer to the router. check the IP address on the computer.
according to the default gateway open the router set up page.
Click Here for more information about the routers and network
Posted on Jan 10, 2010
govinda123
  • 2260 Answers
SOURCE: dlink dir-615 change nat from strict to open
you will need to change some settings on the router.
reduce the MTU. if the MTU settings on the router is 1500 then change 1365 also you will need to open the some ports on the router.
Posted on Jan 12, 2010
I won't to change my nat type
You will need to change the firewall settings of your router. If your Internet service provider is DSL then make sure that modem is in bridge mode. How to change NAT type to open
Nov 29, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Tip
Xbox live NAT
Simple Rules
-if your NAt is strict and cannot connect
try turning your hub off for 30 seconds then turning it back on
if that didnt work.
-try resetting your IP address.
if that didnt work
-take addaptor from xbox to pc out for 30 seconds, then put it back in
if that didnt work
- try opening thies ports
TCP 53
UDP 53
TCP 80
UDP 88
UDP 3074
TCP 3074
Helpfull Info
Sometimes depending on the router brand, it's not possible to open your NAT, this simpily becuase some are not specificly designed for Xbox Live purposes. A good example of this is Belkin routers. These brands are most commonly made for Buissness connection servers. If you are experiencing a STRICT/MODERATE Nat with a Belkin router, the chances are you are going to have to deal with it, but that is not 100% of the time. If you've have attempted several techniques to open your Nat and the changes arnt happening, i'd recommend a 'N' powerd Belkin router, the most majority of these routers work 100% perect for Xbox Live, I myself oned one but changed due to a broadband switch.
How do I change the NAT firewall protection? (Open/Moderate/Strict)
Find your IP address number then type it in on your web browser, this will bring up all your switchable options where several options can be changed to your approval. The NAT firewall is one of these options which can be changed. (like I mentioned before, if you own a Belkin router, the chances are even after changing the fireall level, it will turn back to moderate or strict)
on Feb 17, 2010 | Computers & Internet
How do I change the NAT type from strict to open so i can play xbox 360 I have a Belkin 3D54 router
There are several things you need to configure in order to change your NAT to open. Here's a link to help you out:
http://support.xbox.com/en-us/pages/xbox-live/troubleshoot/connection-issues/nat-type-strict.aspx
It has steps that can help resolve your issue.
Mar 27, 2011 | Belkin Office Equipment & Supplies
I purchased a mifi 2372 from att to connect to a ps3 for my son who lives in an area of limited internet service. I've called tech support at att and sony to see if they can help since everything I've...
Samething with me. I have a mifi and it can connect to the playstation but cant sign in. It says it a DNS error. Which means one of your DNS numbers have blacked out and it can be fixed by getting knew dns numbers.
Dec 19, 2010 | Novatel MiFi 2200 Mobile WiFi Hotspot...
Just got a mifi 2372 and I can't install it. As soon as I plug it into my computer the wifi light goes off and the computer can't detect it. Can u help
The MiFi is not meant to be cabled to your computer while in use. The manual says the cable is only for software updates and charging it when not in use. Just turn it on without the cable and the computer should detect it. Be aware that it takes a long time to boot up (maybe a minute or so) and that even when the little blue light comes on at the side of the device it can still be another 10-15 seconds before the computer will see it.
Dec 04, 2010 | Novatel Wireless MiFi 2352 and 2372...
My nat settings are strict and I don't know how to change them to open?
Using your Internet browser, you can access the Router’s Web-Based Advanced User Interface. In your browser, type “192.168.2.1” (do not type in anything else such as “http://” or “www”). Then press the “Enter” key.
You will get a set up page where you can disable NAT
Follow me on Twitter
May 20, 2010 | Belkin (F5D8231-4) Wireless Router...
Dlink dir-615 change nat from strict to open
Jan 04, 2010 | NetGear DGN2000-100NAS Router
Ok my nat type is strict and i am trying to change to open
That will work.
Dec 09, 2009 | Actiontec Computers & Internet
I need to change my nat type from strict to open
Log into router
go to the NAT tab
Enable NAT
Enable SUA only
Apply the change.
Nov 18, 2009 | Zyxel P660HW-D1 Router
Change NAT from strict to open
You need to do port forwarding on your router. First, you must setup a static IP address on your XBOX. Then You must open these ports on your router setup page using Port Forwarding feature. 80 TCP and UDP, 53 TCP and UDP, 3074 TCP and UDP.
Jun 01, 2009 | Zyxel P660HW-D1 Router
Computers & Internet Logo
524 people viewed this question
David Payne
David Payne
