Question about Brother ML-100 Typewriter
The correctional tape isn't popping up to white-out the errors. Instead the actual ink is typing where it should be correcting making the letters bold. I tried tightening the correctional ribbon and the black ink ribbon and still doesn't pop up. I checked to make sure the springs were still in place and they are. I restarted the typewriter and the same thing.
  • 14 Answers
Hello. I had a similar problem, and Upstatoes helped me. Mine started with striker stuck forward, and then went to working for a few days, but sticking forward again And it was caused by the spring not being in the right place. But the correction tape housing is pushed up and pulled down by the white, adjustable piece on the right side, that has the screw holding it into the adjustment place. If you take off the ink ribbon, push the carriage to middle, and turn on the typewriter, there will be a switch at the top left of the keyboard, on the underside, you will need to flick with your finger, one time, as the carriage moves to the left. This is the reference switch, and you will be tricking the typewriter into thinking it is now in the left side start position. After this, you can see the white adjuster piece on the right side of the carriage, and, as you type a letter, also see if it is holding down the correction tape housing. Then when you hit the erase key, see if the cam on the inside (looking through the small holes in the correction tape housing) turns and pushes up this housing? It may be the tab in the white adjuster is not inside the grove of this cam. Either way, at that point, you may be able to see if something else is not as it should be? My problem was the long side of the spring was not underneth the white adjuster. (I had been putting it under the housing, and it was not helping ot push everything up like it should be.) Aparently this cam with the white adjuster tab in the groove holds everything down, easily, as you type, but has to have the spring help to push up when you use the earse key.
Posted on Sep 18, 2008
I dunno
Posted on Oct 24, 2008
Is there an auto correction feature
The key to the right of the spacebar with the "X" printed on it is the correction button. You just place the carrier on the character to the right of the wrong one and hit the corr. button. The carrier should automatically back up and and remove the incorrect character and if you hold the key down it will continue to back up and remove characters. then you just type in the right one(s). Of course you have to have good "correctable" ribbon and correction tape cartridges installed. If the tapes are old you may have to advance them by typing and correcting or by manually advancing them before they will work. If the correction doesn't remove all the ink from the paper you may have a bad ribbon and/or correction tape.
Sep 17, 2015 | IBM Wheelwriter 3500 By Lexmark Electric...
When typing wrong letters and numbers type
You might have a "proportional space" printwheel but the pitch selector is on 10, 12, or 15 instead of PS. OR it is on PS but you have a normal print wheel. Try selecting different pitches. Another thing that causes that problem is sometimes the ribbon or correction tape gets caught in the printwheel.
Feb 18, 2010 | Swintec 7040 Typewriter
Letters and numbers not printing correctly
It sounds like you have a damaged printwheel. Get a new one and try it.
DickyO
Apr 28, 2009 | Lexmark Wheelwriter 15 Series II...
Brother ML300 Typewriter
make sure the correction tape and ribbon are in properly between the metal fingers and the card holder. turn machine on and off. if it still doesn't work it needs professional help
Oct 22, 2008 | Brother ML-300 Typewriter
Brother ML100 Lift-Off Correction Tape won't lift off
Correction tapes DO have a shelf life, Also make sure the ribbon is moving and very important and this may sound dumb, but I have seen it that the ribbon is not a correction ribon. Are the spool turns orange or yellow? should be. Blue is multistrike and will not correct. Don't know the shelf life of ribbons but they do loose the ability to correct.....Good luck try new supplies..
Jun 30, 2008 | Brother ML-100 Typewriter
Correction function not working
Make sure the ribbon is a correctable (yellow or orange core) not a multi strick (blue core)
Sep 13, 2007 | Brother GX-6750 Typewriter
Correction Tape
Is the ink cartridge correctable ( yellow or orange core) not nultistrike (blue core) ?
Aug 29, 2007 | Brother EM-530 Typewriter
Correction Tape
Check the way the correct tape is installed. I have seen people twist them around the guide backwards and the correction material is facing away from the paper. Also can you see the correction tape lifting up?
Aug 13, 2007 | Brother GX-6750 Typewriter
Brother ML-100 Typewriter Logo
121 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
