SOURCE: Trying to setup Traktor PRO with the DJ IO and
the outputs in Traktor should be set up like this; Chanel 1 (3&4) Chanel 2 (2&1) this set up will give you a stereo sound coming out of Traktor using Numark DJ IO. Make sure the output is set up External and the Audio Devise is Numark DJ IO.
SOURCE: im trying to connect my
Check if the Mbox2 has an echo setting that echos the audio from its input. If you want the audio to loop through the PC then it will have to echo there instead. Check that in "Sound and devices" of the PC are all set to transfer via the MBox for voice and playback instead of the internal PC audio system.
SOURCE: Please, I need a Behringer xenyx 1202fx list of
Go to the Behringer website and then the product page for the mixer. On that page are links to the manual, spec sheet and something called view sheet. The "view sheet" has a wiring diagram and a list of the effects.
