Question about Samsung Prostar DCS Phone
Samsung PBX LCD 24
I have three Phones lines that come to the system, and only one that works on the console,so I would to know what can I do about this?
  • Kenneth Hernandez Aug 15, 2008
    Yes... All the lines are hook up
  • 594 Answers
Are all the phones plugged in and synced together?
Posted on Aug 15, 2008
  • Cameron Viseth
    Cameron Viseth Aug 15, 2008
    i need the model number of your phone......
Why my mitel sx-50 shows message on console no communication?
The phone line between the SX-50 console and the main control is disconnected or the console may need to be rebooted (unplug the phone line then reconnect it). If this doesn't solve it then contact your PBX system support person.
Jul 14, 2014 | Mitel Lands Phones
How to change viocemail for the 2110
IP Phones do not provide voicemail, that is a function of the PBX it is connected to, either a premise IP PBX or a cloud-based (hosted) PBX. If you are using an Asterisk-based PBX system, the usual way to access the voicemail system is to dial 98 from the phone, however you will need to know the voicemail password.
Jul 07, 2014 | Grandstream GXP2110
How do i set ring on Flexible Buttons.....
Perhaps you are trying to set up speed dialing.
Right?
Jul 22, 2013 | Panasonic KX-DT343 White 24 Button 3-Line...
We have three lines incoming. when line 1 is busy the second call on line 2 will not ring on other extensions.we have 4 extensions but call goes straight to the answering service on extension 5. Is this a...
This could be a setup problem, however I suspect you may have a "smart ring" set up with the telephone company. If this is so then it won't work. If the 3 lines are dedicated, then there is something wrong with the PBX.
Oct 04, 2010 | Office Equipment & Supplies
Do the Norstar M7208 and Aastra 9120 phones compatible on the same PBX? I have a M7208 that works fine on current PBX, but new Aastra 9120 doesn't work. Should they both operate on the same PBX?
No, the M7208 is a propriatary set which requires the PBX to function, whereas the aastra phone is a stand alone set which requires a standard telephone line and a power source.
Dec 23, 2009 | NorStar M7208 Corded Phone
Is tha possible to get 25 single lines on 16SLC card(50 pin)
The 25-pair Amphenol connector is just something the industry uses because it's standard and easy. In a TDA system, the 8-port C.O. Trunk card uses the first 8 pairs, a 16-port the first 16 pairs, an 8-port Pana station card uses the first 24 pairs, 3 pairs per extension. The last pars don't have any hardware behind it and are connected to nothing.
The only phone system that I remember where all 25 pairs are used is a 1a2 10 button set and, maybe a Comdial system where the 25th pair is the common audible for station 17 :-)
Carl
May 22, 2009 | Panasonic KX-T7730 Corded Phone
TalkSwitch 48 disconnects call after transfer
You are using the wrong option for transfer -- the one you are using is a conference which requires the person transferring the call to stay on the line. You need the option which permits a blind transfer or announced transfer. This issue is specifically discussed in the manual.
Feb 09, 2009 | TalkSwitch CT.TS001.124001.US...
Change clock time.
The XN120 I know is a PBX, so setting the time sets it for all phones connected to the PBX. The time can only be set on an XN120 system phone which has an LCD display (or a PC - see below). It's quite complicated - refer to setup guide such as
http://www10.GIScafe.com/nl/newsletter_confirm.php?enc_email=ZGF2ZS5jb3ZlbGxAc2lnbWFzZXZlbi5jby51aw==&subscriber_key=5d4ff921b647525ca172f7fb11ae56b4
Some of these PBX systems have TCP/IP network cards installed so the time can be set from the NEC PC-Pro configuration program run on a network connected PC.
Nov 10, 2008 | Lands Phones
Help Request
Do you have any programming experience on your system ? Is seems like the line has to be asigned to the phone it is ringing on but you will have to do that in system programming.
Jul 28, 2008 | Lands Phones
SAMSUNG DCS 12 OR 24 LCD HAVE (answer machine emulation)
Depends on your vmail system and telephone system. If you have a cadence vmail or svmi-8, you must go into system programming on your telephone system and program the key on the phone.
Jan 16, 2008 | Samsung Prostar DCS Phone
Samsung Prostar DCS Phone Logo
119 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
