Question about Vacuums
Radio will turn on....bought new power adaptor but still have problems. It did go on, but after turning odd will not come on again Can you help please
  • 43,501 Answers
The receptacle inside the radio for the power adapter goes bad/worn or a wire comes loose inside the radio. You would have to find a new power adapter receptacle...take the radio apart and then solder out the old and in the new to repair the radio. Not sure that there are parts available to do this.
heatman101
Posted on May 24, 2011
My new Sanitaire SC688A won't turn on. The vacuum is new, but I bought it on ebay. The vacuum looks new, is there a fuse on this vacuum or could it be the switch.
is it the right power supply for the item. did you read it as near new or new
contact the seller direct for warranty claim
May 30, 2016 | Vacuums
I just bought a new belt, put it on, took two swipes, smelled burnt rubber again. My new belt broke. Why?
The beater bar is probably not turning. It get's jammed up with hair and strings and Christmas icicles and anything else on the floor. Taking the bar out and cutting all the stuff off is the easiest way to clear it. Make sure it turns freely before you hook the belt to it again and watch it when you turn it on to see if it's turning.
Sep 15, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
My miele titan is not turning on when plugged in. i think it might be some sort of clog? but the electric head is working... help!
Wow!, that's not typical of a Miele, especially a new model like the Titan which has been on the market for less than 2 years. If I read this correctly, your power nozzle (electric head) is working, but the main suction motor is not. Thta's usually a sign that the carbon brushes in your suction motor are stuck or too short. Again, not a common problem with Miele. A clog could cause your machine to run hot from reduced airflow and then shut down until it cools, but it would shut the whole machine down, not just the suction motor.
Is your power dial, (located just forward of the main switch and cord retractor buttons) set to minimum? If so, you just might not be getting enough suction. If, after turning the dial to maximum, you still get no suction, then you should definitely take it back to the dealer you bought it from. You have a 7 year motor warranty and a 1 year warranty on all non-wearing components. If you bought your vacuum on the internet then you can go to www.mieleusa.com and search for a local dealer. There is a 'Dealer Locator' link on the left side menu.
May 18, 2010 | Vacuums
My Miele capricorn has started making an odd noise. It seems like something is blocking the engine. I've turned if off and on, and reset it and it still have the odd, almost loud barking noise. The power...
Greetings,
This is a major problem. The Miele vacuums motor should never make a loud noise, period. The way the motor is designed, it's quiet and should be quiet for the life of the motor. There are two motors on your Miele canister. One of the motors controls only the suction of the vacuum, while the other motor controls the power brush. Which one of your motors is making this horrible noise? You can tell this by removing the wands and power brush so that you just have the handle of the hose by itself. Now turn on the vacuum, do you still hear this noise? If yes, then this is a problem with your suction motor, and you need to bring this in to have an authorized Miele repair center take a look at it. The reason I say that is because you have a 7 year warranty on that suction motor, so if something is wrong with that motor, then this will be covered under Miele warranty. If it's the power brush motor that's causing the sound, this probably will not be covered unless the vacuum is under 1 year old. If it is the power brush, please just use the clarificaiton request here on Fixya and let me know, I'd be more then happy to try and walk you through diagnosing the power brush motor with you.
I hope this was helpful to you. If you did find this helpful, please be sure to click the thumbs up icon in the repair. I really appreciate it.
Chris J.
Mar 21, 2010 | Vacuums
Seems to charge but then wont come on
Sounds like you bought a defective battery
You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new. If it still goes red get a refund and a new one.
Mar 07, 2010 | iRobot Roomba 4105 Bagless Robotic Vacuum
Hoover Vacuum works, then stops in 3-5 mins. Works again in a couple of hours
sounds like the motor is overheating .check and see if the brush roller is turning when its on.if its hard to turn or won't turn at all take it back where you bought it and insist on a new one.my thoughts on new items is if you buy something new then it shouldn't have to be fixed.insist on it.please leave feedback...pete
May 04, 2009 | Vacuums
Electrolux Renaissance power nozzle turning on and off, brass pins hot
The deal with the Renny is that it runs off of circuit boards. Usually the problem of the main motor shutting on and off is caused by one of the Triac boards located inside the canister. Another problem could be the thermostat wire located on the inside of your motor itself. It's almost never the thermostat, so the triac board is most likely the issue.
As far as your power nozzle goes, the head eminating from the swivel body is in most cases due to an older design of the power nozzle. I would suggest investing in a new elbow assembly that includes a new swivel body as well as newer style of wiring that is proved to reduce arcing and heat production within the power nozzle.
In some cases, fixing the power nozzle will fix the problems you are experienceing with the main motor as the arcing happening in the power nozzle can in fact turn off your machine. So investing in a new elbow assembly for your power nozzle could in fact solve the problem in its entirety.
Oct 26, 2008 | Electrolux Guardian Bagged Canister Vacuum
Vacuum goes on and off while vacuuming
Defiantly sounds like a loose wire, but double check cord ends to make sure they aren't touch when moved from side to side. If not, check inside and see if their are loose connectors to the motor or even a weak switch.
Jun 20, 2008 | Kirby G4 Bagged Upright Vacuum
Kirby Sentria
sounds like the motor burned up. not sure if travel adapters will handle a large load like a motor, around 8 or amps. power needs in US are 110 volts ac, 60 hertz.
I believe UK is 220 volts and 50 hertz.
usually when a vac is brought to europe you must change motor.
Jun 13, 2008 | Kirby Vacuums
Vacuums Logo
15 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
