Question about Philips Computers & Internet
I installed vista sp 1 in my hp laptop and philips external harddrive was also plugged in and when i finished installing vista sp1 all folders showed E:\liuuv.scr.. i cant open any folders... all folders are showing only in kb's. how to solve the problem sir.
  • 243 Answers
It seems viruses on your hard drive and the extension of viruses is .scr (it hides all files). Try this tips to un hide your files, you must show the hiden files on you pc by following these steps
1.open my computer
2. click on tools
3. click on folder option
4. on the advance setting find the category of hidden files and folder
5.
show choose hidden files and folder
6. click ok
the second step click run (you can find by left click start button )
type cmd
you will be in a command prompt and it will be C:\\
then type the path of your hard drive (for example F:)
after the path show your drive
(for example F:) type attrib -s -h -r -a /s /d
wait until the process finish
now you can see the original file of you with extension file folder not .exe or .scr
you can delete the file with extension .exe and .scr by one left click to the file and press shift and delete button on your keyboard.
don't forget to scan your drive with anti virus
Posted on May 23, 2011
Testimonial: "thank u very much... recovered my external hd with all files... excellent feedback"
Asus g2s
Did you do ALL your windows update before the Service Pack? That SP has been out for years? Doesn't your laptop have Windows Updates set to Auto? Choose one or the other, Vista or Win 7 and do a Full Install.
May 09, 2013 | ASUS Computers & Internet
Trying to transfer data from an old harddrive i have (maxtor, diamondmax plus 9 80 GB ATA / 133 HDD) to My HP laptop
Install the hard drive into an USB hard drive adapter case the plug this USB hard drive into the USB port in your laptop. The laptop will see it as an external storage device, open the various folders and copy the files to your laptop.
You can delete any unwanted files off this external USB hard disk and use it for backups and file transfer.
Mar 14, 2013 | Computers & Internet
Low disk space winsxs is 10 gb how do I delete this file pls
The bad news are that i don’t recommend doing any manual removals on winsxs folder. Such a step could probably make your applications non-workable or even break your system!
If you have Vista sp1 installed use the vsp1cln.exe : The utility removes all Vista SP1 uninstall files and by using it you can reduce few gigs.
To run vsp1cln.exe:
  • Press on vista start button type cmd.exe and hit on enter.
  • hen enter the following command:Vsp1cln.exe and press enter key
  • You will be asked to confirm your action , just press “Y” and after few minutes your winsxs will be smaller.
Other ways to reduce the winsxs folder:
  • You can uninstall non needed application
  • If you have office 2007 installed , and you can get later distribution like with sp1 included – uninstall your entire office, and install the version that includes sp files.
Apr 13, 2010 | Microsoft Windows? Vista Home Basic...
How i can make a bootable Windows CD for my personal use
Create a temporary working folder at the root (top) of the C: drive called "XPSETUP" (without the quotes). Actually, you can name it anything you want and put it anywhere you like, but for ease of explanation, the remainder of the steps below will assume that you have created the XPSETUP folder in the root of drive C:. This C:\XPSETUP folder will be where you will create the CDROM directory structure for your bootable Windows CD.
Copy the entire C:\I386 to C:\XPSETUP. When you have finished, you will have C:\XPSETUP\I386. Notice that I said "copy", not "move". Do NOT drag and drop the I386 folder into the XPSETUP directory. If you do so, you may end up moving it into the XPSETUP folder (depending on where you created the XPSETUP folder). It is important to work from a copy of the I386 directory so that if you make mistakes, you can simply go back and start all over again. If you move the directory or drag and drop it, and you make a mistake, your mistake will be permanent. So once again, COPY the entire I386 folder to XPSETUP. It may take a while for the copy operation to complete, but it's safer this way.
If you're not sure how to copy, follow the following procedure: Highlight the I386 folder using Windows Explorer. Right-click the folder and select "Copy". Then open the XPSETUP folder. The folder should be empty at the moment. Right click the empty space in the window and click "Paste". A very lengthy copy procedure will take place.
To verify that you have copied the folder and not moved it, return to the top of C: and check that the I386 folder is still there and that the original files in that folder are still there.
Create an ASCII text file with only the word "Windows " (without the quotes and including the final space after the word "Windows") in it, followed by a new line. To do this, open up Notepad. Notepad can be found in your Start menu -> Programs -> Accessories -> Notepad. Type the word "Windows" without the quotes and following my case exactly (that is, "W" is a capital letter and the rest are in small letters). Then type one additional space. Finally, hit the ENTER key. Do not add anything else to this file. Do not change anything - for example, do not type everything in capital letters or anything like that. The contents of the file must be exactly as I said, or Windows setup will issue an error message.
Save the file with the filename "WIN51" (include the quotes so that Notepad will not add a ".txt" extension behind your back) in C:\XPSETUP. Again, the filename's spelling and case must be exactly like mine.
If your PC or laptop originally came with XP Home, make a copy of the file you just created and call it "WIN51IC". If you are using XP Home Service Pack 1 (SP 1), make two copies of the file and call them "WIN51IC" and "WIN51IC.SP1". If you are using XP Home Service Pack 2 (SP 2), make three copies of the file and call them "WIN51IC", "WIN51IC.SP1" and "WIN51IC.SP2". All the copies of the files should be in C:\XPSETUP.
If your PC or laptop originally came with XP Professional, make a copy of the file you just created and call it "WIN51IP". If you are using XP Professional Service Pack 1 (SP 1), make two copies of the file and call them "WIN51IP" and "WIN51IP.SP1". If you are using XP Professional Service Pack 2 (SP 2), make three copies of the file and call them "WIN51IP", "WIN51IP.SP1" and "WIN51IP.SP2". All the copies of the files should be in C:\XPSETUP.
Note carefully what I said above. You may be running XP SP 2 now, but if your PC came with XP SP 1, you should create the files for XP SP 1. There is an exception to this. If your PC or laptop came with XP or XP SP 1, but you want your Windows install CD to install XP SP 2, create the WIN51 files needed for SP 2 and follow the procedure for slipstreaming Windows service pack 2 (SP 2) into the Windows setup CDROM given in the next step.
If your PC or laptop came originally with XP or XP SP 1 (service pack 1) but you want your Windows setup disk to install XP SP 2, do the following. Otherwise, skip to the next step.
Note that even if you have since updated your computer to SP 2, you will still need to do this step if you want your setup CD to install Windows XP Service Pack 2. The reason is that updating your running Windows system does not automatically update the I386 directory. Your I386 directory still contains the Windows setup files belonging to whatever version of Windows you had when you first bought your PC/laptop.
Download Windows XP service pack 2 from http://www.microsoft.com/downloads/details.aspx?FamilyId=049C9DBE-3B8E-4F30-8245-9E368D3CDB5A&displaylang=en Save it anywhere you like except in the C:\XPSETUP folder. For the purpose of this tutorial, I will assume you saved it as C:\XPSP2.EXE, that is, in the root folder with the filename "XPSP2.EXE".
Important: if you did not configure Windows to show you the full filename you should probably do so before changing the name of the file. Otherwise, you may be inadvertently saving the file as "XPSP2.EXE.EXE" without your knowing. (That is, you see the filename as "XPSP2.EXE" in Windows Explorer but it's actually "XPSP2.EXE.EXE".)
You will need to update the C:\XPSETUP\I386 folder to contain the updated SP 2 files. As a side benefit, the service pack 2 updater will also create a few files (including setup.exe) in the C:\XPSETUP folder. This process of integrating the service pack files into the original XP or XP SP 1 is known as "slipstreaming".
To slipstream SP 2, first open up a command prompt. To do this, click the Start menu, select the Run menu item, and enter the words "cmd". Click the OK button. A black command prompt window will open.
Enter the following line into the window and press the ENTER key.
C:\XPSP2.EXE /integrate:C:\XPSETUP
After the program finishes, you can close the command prompt window. If you look into your XPSETUP folder, you will notice a few new files there.
At this point, the C:\XPSETUP directory contains all the files that will be copied to your Windows Setup CDROM. Don't worry if the directory does not contain files like "setup.exe" which you see on the retail CDROMs. You won't need it for a fresh install from the bootable CDROM. Note: You will only have "setup.exe" if you had to slipstream Service Pack 2 as mentioned earlier. The Service Pack 2 slipstreamer creates setup.exe for you.
Now open the wxp10.zip file that you downloaded earlier. Simply doubleclicking it in Windows explorer should do the trick. Go into the cds directory and into wxphome (or wxppro; it doesn't matter which) directory, followed by the files directory. Drag the "w2ksect.bin" file into C:\ (the root directory/folder of drive C:). Don't get creative and place it in some other directory. If you do that, ImgBurn will not be able to find c:\w2ksect.bin later.
You could do all that OR simply download an XP LIVE DVD.. This will  bootup from DVD and work without using/installing to the Hard Drive.
here is the torrent DL link No torrent?  Here > http://www.utorrent.com/
DL and install.. then click on torrent link and it will DL.
http://thepiratebay.org/torrent/3820108/Windows_XP_Live_Edition(Run_Windows_from_CD)
here is a link how to make it.
http://www.intowindows.com/how-to-create-live-usbcddvd-of-vistaxp/
Feb 01, 2010 | Microsoft Windows XP Professional SP2
Hard drive will not completely finish installing Vista Sp1.
Try booting in Safe Mode (press F8 during startup). Once in safe mode, see if you can see the update in the Add/Remove programs from the Control Panel. Make sure the select the "View updates" checkbox.
If it is there, try uninstalling it before you boot in regular mode again.
While in Safe Mode, also disable the automatic Windows update. You can then try to install it manually from the Microsoft site instead.
Microsoft has some more ideas on how to fix SP installation.
Jules
Jul 16, 2009 | Samsung HM060HI Hard Drive
Can't install SP1 on Acer Aspire 5720G Laptop
There's an article on the microsoft website about this problem,very common issue assuming this runs vista.
Jul 11, 2009 | Computers & Internet
Install XP/sp3 on toshiba portege R500
Do you have XP or Vista installed on your laptop?
Does you laptop boot up into Windows?
What steps are you doing in trying to install the Service Pack?
You have to install the correct Service Pack for youe laptop, these were released in 2008.
SP3 is for Windows XP.
The service pack for Vista is SP1
Jan 02, 2009 | Compaq Armada E500 Notebook
My display drivers and audio drivers not supporting vista ultimate
you shouldn't have installed vista service pack 1
its a known issue with vista service pack 1
if u had vista before and u updated it to sp1...i would suggest you to either do a system restore and uninstall sp1
or install XP back
Jun 04, 2008 | Microsoft Windows Vista Ultimate Edition
Vista sp1
check out http://www.cracks.am for all the cracks u need .
vista hacks,sp hacks etc
Mar 07, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
176 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
