Question about Car Audio & Video
Speedometer was replaced. In the process it was unplugged for awhile which now has locked up the dvd player and radio so it can't be used. How do you unlock this. Chevy Venture.
    Problem Solver:
  • 22 Answers
Asfasfasf
Posted on May 23, 2011
Locking up
Unplug DVD player and unhook all attachments, press and hold power for at least 2 minutes, this will remove any residual voltage in the unit and hopefully reset the microprocessor ic. Now install everything back into place and try again, if this fails! I recommend replacing the player.
Apr 10, 2012 | Televison & Video
What causes a dvd player to say no disc
Dirty DVD's cause the 'read' sensor optics in the DVD player to become 'dirty' and hence unable to interpret the digital bits on your other DVD's.
Buy and use a DVD cleaner disk kit from Radio Shack.
Mar 03, 2012 | Samsung Computers & Internet
Can't get green standby light to stay on, so can eject DVD from combined TV and DVD player.
First try unplugging and plugging back in then remove caseing and insert paper clip under locking mechanism and hit eject...your locking mechanism signals that there's no cd in it and so to it there's no dvd or cd...hope that helps:)
Jan 04, 2012 | Televison & Video
LG DVD RC689D HOW TO UNLOCK
Hello
Check this process.
1. Open the disc tray.
2. (Press 'setup' and scroll to 'lock'.
3. Press '0' seven times.
4. (Press 'ENTER, Setup)
Nov 28, 2011 | LG Televison & Video
I played some bootleg movies. And now my Sony DVD player (model DVPSR500H). Will not play Retail DVD's. What can I do? I tryed unpluging it. And that did re-set it.
Your DVD player is now locked to the region of your bootleg movies! Sony only allows a certain number of changes before it becomes locked to the 'chosen' most played regio.
You need to make your Sony DVP SR500H 'Region Free'. Try the following:
1) Switch on player
2) Open DVD/CD tray compartment
3) Using the remote controller, enter 2812
4) Press 9 on key pad (to make it multi region) and then enter or Nav Ctr button
5) Press CLEAR to exit
Good luck.
May 03, 2011 | Sony Televison & Video
Have panasonic dmr-ez485v error message -NO READ- changed disks used prerecorded movie same as my recorded disks, hit reset - still no change
I just saw the date on this message and realize that it was awhile ago. I assume that you have dealt with it by now... So for others who are trying to fix their DVD player:
I have a DMR-EZ485V DVD player and just started getting the error message "No Read." I couldn't find an answer on the internet and finally called Panasonic's customer service, (there is no charge 1.800.211.7262). Since it says "No Read" to everything--store-bought DVDs, burned DVDs, CDs; AND when there is nothing in there (it acts like it is trying to read when the tray is empty), the customer service rep thinks that I am having a lens issue. It either needs to be cleaned (can pick-up a product at Best Buy or Radio Shack) or, if that doesn't work, the lens needs to be replaced.
Aug 09, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
DVD player does not open or close
Sometimes when DVD players display an error code the machine just locks up and won't perform at all. Many times if you unplug the unit and let it cool off for awhile then plug it back in it will release the DVD. If this doesn't work, some players have a tiny hole in the front panel through which you can insert a small tool to release the tray. If you don't have the tool a straightened paper clip will usually work.
Jul 20, 2009 | Toshiba MD24F52 24" TV/DVD
My go video is locked. How do i unlock it?
You can unlock by pressing and holding the Power switch. Sometimes it will then allow you to eject the disk after it restarts, but not always.
Mar 08, 2009 | GoVideo VR3845 DVD Recorder/VCR
DVD player
I am not a pro...did this process early today.
1.Remove 5 screws from bottom center dash. This peice has the cubby with change slots. There are 2 on the left side, 2 in front and 1 on the right. Pull out of the way.
2.Pull cup holder all the way out and depress tab on the very back of the top. Slide out and remove.
3.Pry small peice of plastic out of the way carefully with screwdriver. Remove.
4.Revove 2 screws that where hidden by this small part. Begin prying the dvd and radio surround off from the bottom, there are no more screws. Either let dangle to the side or unplug and revome from car.
5.Remove 2 screws to release dvd player. Unplug 2 seperate connections and remove. If you have change in it, shake upside down a little while slightly depressing the top to give room for $ to fall out. For 2 dvd just work out carefully while trying to line up the dvd with the opening.
Hope this helps someone! Kris
Aug 19, 2008 | 2005 Dodge Caravan
Car Audio & Video Logo
61 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
