Question about Fujinon Mariner WPC-XL Binocular
Binoculars show double image - Fujinon Mariner WPC-XL Binocular
  • Albert Marani May 25, 2011
    You said solution can be found on line. Where? I have looked but have not found any site that describes how to repair the double image.
  • 17,970 Answers
The reflectors are out of alignment; the binoculars have been dropped. You may want to contact the manufactired to see about getting realignement.
Your binoculars may be out of collimation. With binoculars, it's essential that the two optical systems be precisely aligned. Unfortunately, these binoculars are very cheaply made, and are easily knocked out of alignment, even during normal shipping. There are instructions online for collimating binoculars.
Hope helps.
Posted on May 23, 2011
One image is slightly above the other at all distances. After using the binoculars for even a couple of moments, my eyes are strained. The problem was present when the binoculars were purchased, however...
The oculars are not aligned properly causing double vision. Check on the binoculars to see if there is a place to adjust the alignment of either of the oculars. Look for any loose screws that may cause the two oculars to be out of alignment.
If this is not the case try adding some torque to the binoculars to see if the will adjust to where they will both point in the same direction. The eyes can fuse disparate images slightly but there is a very small range that they can handle. If the two images are separated by more than this small amount it will cause eye strain and double vision.
Feb 13, 2011 | Minolta 10x25 Activa D WP XL Pocket...
Focusing problems
Hello Samaro,
This effect is produced when the tho sides of the binoculars are not focusing the same.
Since you sayit is present at long distance, it might be that one barrel is stuck and is not focusing the same as the otherone when you scroll the middle "focuser".
What you can do is open it up and try to clean it, also see if there is something, that is making one of the lenses not move forward as far as the other one.
Good luck,
Dahaka
Jul 28, 2008 | Fujinon CD Binocular
My Canon 10x30IS Image stabilized binoculars show a double image. Both sides focus and stabilize. Can I do something to fix it or should I send them in for repair?
Like I said before, one of the prisms has shifted and the binoculars have lost collimation. This is not something you can fix yourself.
Nov 18, 2010 | Canon IS (10x30)
Double image occured after the omega 40 X 70 binoculars were dropped
There are a series of lenses and prisms inside the binoculars. When the unit was dropped one of more of those elements have been dislodged and that is what is causing the double image. You can check with the retailer to see if there is a repair center in your area. The way these units are put together they are difficult to take apart, repair, and put back together. Depending on the cost of the unit you might be better off replacing them. Check with the retailer to see what they say.
Mar 17, 2010 | Omega ATN 7x50 Daytime Binoculars with...
My Nikon binoculars show two images
must have been dropped ...have to be realigned if you want i can supply estimate 15088331232 ...larry
Aug 08, 2009 | Nikon Optics
See two images at higher power.
Your binoculars are out of collimation. That means that the optical path needs to be aligned. Binoculars are designed so that the focus point of each barrel is the same over long and as short as possible distances. Binoculars that are properly aligned will still show a double image if you attempt to focus at something close that is too close for the models design. However this is not the same for long distances. The image at a long distance must not be doubled.
If they are under warranty and you haven't damaged them by dropping etc send them for repair to the manufacturer or ask the retailer where to send them.
If you are going to pay to have them fixed get a quote first. Binoculars that are of the zoom variety are not well thought of among binocular officionados as the quality of image degrades at higher magnification. For the price of repair you may be able to source a higher quality non zoom binocular.
Jul 20, 2009 | Sharper Image Spion (AR001)
Double image - one above the other
yes , they have to be realigned, if you want call me and we can talk further 5088331232...larry
Apr 22, 2009 | Steiner Tasco Offshore 54 Binoculars
Bushnell binoculars /double image
they have to be aligned if you want mail them to me for an estimate..larry@reichinstruments.com
Apr 19, 2009 | Bell & Howell Optics
Image appears double and slighly off when viewing
I was having a double vision problem with my Barska 10-30X50 zoom, 195FT/100YDS binoculars. One image was always higher than the other. This was tolerable at low zoom, but was further aggravated the more I zoomed in. I found that I could grasp both barrels and twist them in opposite directions (one side up, the other side down) and force the two images to merge--but that was a strain and an unpleasant viewing experience. As an experiment, while looking through the binoculars, I grasped the far end of the right barrel and twisted it on its axis. Nothing happened at first, but after a certain amount of resistance it began to rotate independently of the body. Lo and behold, this shifted the barrel's axis, and the image for that eye moved vertically! I turned it until the two images merged, and now I'm thrilled to say that the problem is solved! I don't have a clue if this would work on any other brand or model, but it's worth a try!
Apr 06, 2009 | Tasco Sonoma 16-840WA-1 (8x40MM) Binocular
Blurred,double image
These should still be well within warranty.. If you still have proof of purchase that will show the date which should be enough for the shop to honour the warranty.
Bushnell's warranty is 12 months everywhere..
Dec 14, 2008 | Bushnell Excursion Binoculars
Fujinon Mariner WPC-XL Binocular Logo
298 people viewed this question
Top Fuji Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Are you a Fuji Optic Expert? Answer questions, earn points and help others
