Question about BenQ PB6240 Multimedia Projector
When powered on - Humming vibration noise loud - first time using since purchase
    Problem Solver:
  • 22 Answers
Awerwerw
Posted on May 23, 2011
1996 ford contour loud humming noise and vibration from front wheels
You have a defective wheel bearing most likely, the noise sounds correct for that problem. have a shop drive it before you replace anything to confirm my guess.
Sep 26, 2012 | 1995 Ford Contour
Vibration at highway speeds loud humming noise,
Possibly a wheel bearing issue, does it `get progressively worse as speed increases or better as it decreases? does it stop when applying the brakes or get worse?
Oct 30, 2011 | 2006 Ford Escape
Estate TS25AFXKQ FRIG makes a loud humming / vibrating sound when it kicks on. I do not see any visual problems. Had a similar issue a year ago but it stopped. Now it last long time.
Hello Gene,
I am so sorry to take so long to answer your question i was offline but suppose i was shown as online sorry again.
Now then is it the compressor that is making the loud humming noise and does it repeat it several times a hour/day ??
The buzzing humming noise is coming from the compressor due to the start relay being burnt and the relay should be replaced. The relay clips onto the compressor and is held in place by a wire retainer under a plastic cover on the side of the compressor.
The part number for that relay is 8201786 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
If you should need further assistiance please replay and i will glad to help you,
GENE
Oct 14, 2011 | Estate TS25AFXKQ Side by Side Refrigerator
Altec Lansing GT5051, I'm hearing a humming noise from the speakers as soon as I turn them on. The humming noise is heard even if speakers are not connected to source.If I try and play music with...
Sounds like a problem in the speakers' internal power supply, maybe a faulty capacitor. Speakers need to be looked at by a technician, or replaced with a new set.
Jun 05, 2011 | Altec Lansing GT5051 Computer Speakers
Ilo DVDR05 Vibration and loud humming noise
i experienced that problem before.one cause is the cd itself.there cd's that are too thick so the motor has hard time rotating that makes vibrating sound.the other ,don't put something over your unit.the cover is touching the holder of the cd and makes a sound.just do the necessary things to be done like don't put something on top your unit.if not, then a manual analysis of the tech is the last option.
May 17, 2009 | iLO DVDR05 DVD Recorder
Loud Humming noise every time we run the dishwasher
Hi, I had this exact same problem. In my situation it turned out to be the pump that pumps out all of the used water. It was rubbing up against the floor so that every time it turned on it made a loud vibrating sound. I just reached under the washer and put a piece of rubber between it and the floor and it solved the problem.
good luck!
I saw this post because I am considering buying the same model you have. Other than the noise problem you have, what do you think of it?
Mar 29, 2009 | Jenn-Air Dishwashers
Loud humming noise coming from 360
The loud humming noise is usually the DVD drive. It is very fast but is very loud. If you have the NXE dashboard you can download games to you Xbox 360 to run them from the hard drive (you will still need to put in the disk for copy protection issues). The Xbox should make less noise then. Try to mount the Xbox 360 on a hard surface which is in contact with a soft floor to reduce the noise travelling through your home.
If it is making a loud noise while there is no disk in the drive then take the console to a Microsoft dealer whenever you can to have them take a look at it.
Feb 13, 2009 | Microsoft Xbox 360 Console
Noise / vibration from gas regulator
This is on the Weber site, under support. I have been experiencing the same problem and have not used it because of it.
Humming or whistling from the regulator: Outside temperature, humidity, barometric pressure, and the gas level within the tank may cause the rubber diaphragm inside the regulator to vibrate, making a humming or whistling sound. Although this sound may be alarming, this is NOT dangerous as long as it is not accompanied by the smell of gas. If the humming sound persists, a change in atmospheric conditions will eventually stop the vibration.
Jun 03, 2008 | Weber Genesis Silver B Grill
BenQ PB6240 Multimedia Projector Logo
181 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
