Question about Canon imageRUNNER 400S Copier
I am using a canon ir 400s machine. But When I use the Stack bypass in the display it show the a4r paper. How can i set the stack bypass paper abain.
    Sergeant:
  • 372 Answers
In the copy settings in additional functions there is standard bypass settings.change it from there
Posted on May 24, 2011
I need copy A3 with Canon iR 2016j Black and White Copier
Press aditional function, slect copy setting, then stack bypass, then select paper size A3.
Apr 04, 2013 | Canon iR 2016i Black and White Copier
Copy is not coming in centre of the paper when using A4R size by Manual bypass table
first, did you manage the sideway rails to hold the paper centered?
Did You put the A4R paper in bypass horizontally?(the A4R way)
Did You select the A4R paper size for manual bypass settings?
I hope that something of these helps You!
Feb 15, 2011 | Canon imageRUNNER 400S Copier
Can A3 300gsm paper be used for a double-sided print run on this machine
Canon IR C3200 Published Specifications:
Acceptable Paper Weights
Cassettes: 17 lb. Bond to 110 lb. Index
(64gsm - 209gsm) and Transparency
Stack Bypass: 17 lb. Bond to 140 lb. Index
(64gsm - 253gsm) and Transparency
Jun 16, 2010 | Canon imageRUNNER C3200 Copier
Canon ir 400
Switch off machine
Open the rear cover then you see the green board
right hand up side it calls dc board remove all connection
re insert them.
switch on copier.
If problem exist replace the board.
Oct 14, 2008 | Canon imageRUNNER 400S Copier
STACK BYPASS option causes LOAD PAPER message & no print
1-did you change to bypass instead of trays in the menu?
2-the sensor (black lever in the bypass that triggers the sensor) is missing or bad
Oct 09, 2008 | Canon imageRUNNER 400S Copier
Canon Color ImageRunner - Tab Instructions
To be able to print using tab paper from the driver
Since the tab paper can only be fed from Stack Bypass, single reverse tab paper cannot be
used. The tab paper must be single forward.
1. Go to the printer and put some tab paper in Stack Bypass
2. Press Letter on C3200 LCD panel and press Next
3. Select Tab paper and press Done
4. Go to Windows Start menu and choose Settings
5. Open Printers folder
6. Select Canon iR C3200 PS3’s Properties
7. Click on Device Settings tab
8. Click on Form to Tray Assignment button
9. Making sure that Stack Bypass is highlighted and Paper Size is Letter, select
Tab Paper by scrolling down the Paper Type list
Page 2
Hint:
In order to print to Tab paper, it is necessary to select Tab Paper in the Form to Tray
Assignment dialog box before using this option. Otherwise, the option of printing to Tab paper
is not available from the print driver.
10. Click OK to close Form to Tray Assignment
11. Click OK to close Properties window
12. Open Word document called “tabs.doc”
13. Go to File menu and select “Print…”, and change the current printer to Canon
iR C3200 PS3.
14. Click on Properties
15. Click on Paper Source tab.
16. Select Paper Type option
17. Choose Tab Paper from Paper Type list. As soon as you select “Tab Paper”,
Conflict Information dialog will appear. Click on OK.
Page 3
Hint:
In order to change the tab position, click on Tab Position button. Clicking this button opens a
dialog box for specifying the width for shifting the image data to be printed on the tab part of
the paper.
Hint:
The conflict information displayed pertains to the finishing of the document. Tab paper must
be grouped, not collated. Since the default value for finishing is Collate, the driver
automatically adjusted the finishing option to resolve the conflict.
18. Click on OK to close the Properties window.
19. Click on OK to print the tab paper.
20. Go retrieve your output.
Note:
Please note that this procedure for printing on tab paper is not the same for all drivers. CCD
drivers would be similar to this procedure, but depending on the OS Platform, exact buttons
and steps would vary. However, from such drivers as imagePASS-C1 PS and Macintosh drivers
would work completely different from this procedure. Although we will not cover each
procedure step by step, we encourage you to take time to make yourself familiar with the
procedures.
Sep 30, 2008 | Canon imageRUNNER C3200 Color Printer
Canon ir 2200 print from oracle
ive had this before its under your printer setting tools you have to set that copier for tray 1 or letter turn off automatic
Sep 01, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon Imagerunner 330s - Stack Bypass
you can select for tray (letter size ) as default in paper settings
the stack bypass paper sensor may be broken and is active all the time
Jan 29, 2008 | Canon ImageRUNNER 330s Copier
Error Code E580
Error Code E580 relates to these below:
• The stack tray lifter motor (M5) is
faulty.
• The stack tray paper height sensor
(S10) is faulty or the harness
connector is disconnected or has an
open circuit.
• The stack tray lifter motor clock
sensor (S9) is faulty, or the connector
is disconnected or has an open circuit.
• The stack tray lifter motor load is
faulty.
• The finisher controller PC is faulty.
Dec 07, 2007 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
163 people viewed this question
old marine
old marine
