Question about Samsung DV218AEW Electric Dryer
3 day old samsung dv210 stuck on cooling mode on panel thus meaning it wont dry clothes. yes a have 220 volts and yes 4-inch dryer hose clean no lint build up ! what is it ?
  • 833 Answers
SOURCE: Clothes aren't getting dry very fast
First, check your circuit breakers, turn them off and on...there are two linked together labeled 40 amperes or more. Next guess will be the thermostat or the heating coils. Use a multimeter to check these parts. A diagram is usually attached to the back of the unit. Oh, is the drum turning? Are your clothes reasonably damp dry when you put them in? Is the vent hose kinked when the unit is in place?
Posted on Dec 18, 2007
aborcass
  • 2651 Answers
SOURCE: gas dryer/ whirlpool
well your generating heat which is a good sign, either there is a blockage in your venting() most likely source of issue!) but you say ou replaced, i would then look to replacing the valve coils, 279834, about 20 bucks, easy to replace... its possible that they open the valve upon start up allowing heat, but after being on 20-30 min they overheat and no longer open not allowing heat to generate..
Posted on Apr 09, 2008
  • 235 Answers
SOURCE: My dryer has two problems, one it doesn't dry the
Sounds like your bias thermostat is bad. It's the one that has the 4 prongs.
Posted on Jun 30, 2009
  • 5 Answers
SOURCE: Samsung dryer DV218AEW stuck on cool down cycle
pcb damaged
Posted on Sep 12, 2009
57 varieties
  • 1653 Answers
SOURCE: Samsung dryer DV448AEP/XAA - lint buildup
Yes this is rellatively normal as clothes are just not made the same way any more. You could turn down the drying temperature slightly and put in an anti static drying sheet but it won't make that much difference.
Posted on Oct 13, 2009
Testimonial: "I just had a repairman out because the dryer was no longer heating. The whole inside of the dryer was full of lint. It was awful. "
What to Do If a Dryer Won't Heat? Brand name Inglis, It's only 2yrs old, While I'm using stop for a while then when I start again the timer is done my clothes is not dry & it's cold. We...
If yourdryer is not heating, check your dryer's venting. First thing to check is to see if you aregetting air flow to the outside through your vent hood. Next, check your voltage to see if you aregetting 220 volts to your outlet. Youcan do this by taking a volt meter set at 250 volts. Take the red leg of the volt meter to the oneside and the black leg to the other side. If the volt reader reads 220 then you are getting the propervoltage. Finally, if you are getting 220volts then it is your dryer heating elements. On a 220 volt for the dryer one leg is for the motor and leg is for theelement. If you are getting 220 volt thenit is your heating elements that are bad.
May 11, 2011 | Dryers
Cooling light stays on during dry cycle. no heat is to dry clothes. I've switched the circut breaker numerous times and unplugged the unit many times also to "reset" . What's next..
Try a timed dry cycle instead of an automatic cycle. If that works, then you will need to clean off the moisture detection bars inside the dryer to get the auto cycle to work again. Look for two curved metal bars, about 3/16 inch wide and 4 inches long, about an inch apart, located just inside the front of the dryer, near the right side of the lint filter. (you'll have to stick your head in the dryer drum to see them) Often times, use of dryer sheets will result in a waxy coating forming on these bars, preventing the dryer from detecting the moisture in the clothes. The dryer sees no moisture, it goes into the cool down mode and then stops. Clean the bars off, and you should be back in the laundry business.
Feb 05, 2011 | LG DLE7177 Dryer
The cooling light is always on and the clothes take forever to dry!
Inside the dryer, near the lint filter, you will find two curved metal bars, about 1/4 inch wide each, about an inch apart and about 4 inches long. These sense the moisture in the clothes. When fabric softener sheets are used, a waxy substance will eventually coat the bars, so the dryer will not "see" that the clothes are still wet, and go right to a cool down. Clean them off, or use time dry only.
Jan 17, 2011 | LG DLE2512W Electric Dryer
Dryer has started to take longer to dry clothes only 3 yrs old, any reason why this could be happening. A load used to dry in roughly 30 minutes now can take up to an hour.
I would check your venting. If your venting is plugged up it will not be able to expel moisture properly causing long dry times. Feel the airflow outside if its not strong then thats your problem. Good luck.
_MJ_
Dec 15, 2010 | Estate EED4100SQ Electric Dryer
It seems like the dryer takes forever to dry clothes. normal loads and the lint trap is clean. is there anything else i can do
look inside your homes electrical panel..make sure both breakers to the dryer are in the on possition. its 220 volts and if one is tripped only110 volts are present....if thats good youll need to replace your heating elements on the back of the dryer. there are usually 2. each is held in by 2 bolts usually...not hard to change. you can find these at lowes or home depot..thanks and have a great day
Nov 08, 2009 | Kenmore Elite HE4 Electric Dryer
Oct 13, 2009 | Samsung Dryers
Clothes not drying, lint in dryer
Is the vent 4 inches all the way out? The recommended run length of 10 feet is max, however not very practical or followed. You need a vent brush to run completely through the full length and get as clean as possible. The water is from condensation caused by the long run through the attic. Any kinks in the vent will exacerbate your problem. If you do not like the dryer being 4-6 inches from the wall for the elbow, there is a kit available at most home centers, Lowes, Home Depot, that gives you the same volumn as the 4 inch round in 2 inch flat.
Eric
Jun 08, 2009 | Whirlpool Dryers
Dle2532 lg dryer, cooling light is always on
I'll take a stab that you use dryer softener sheets. These will deposit a coating on the two metal sensor bars (about 4 inches long, very near the lint filter inside the drum) which prevents the sensor from "seeing" that the clothes are still wet, so the dryer jumps to the cool down portion of the cycle. Clean the metal bars off and it should work again. (note: the bars are not in the cycle if you choose time dry instead of using the automatic cycles)
Apr 11, 2009 | LG DLE2532W Electric Dryer
Dryer will not dry cloths
make sure that the dryer has the proper voltage going to it and if it does then check the heating element and the safety on the left top of the element housing
Apr 18, 2008 | Whirlpool LGR7646E Dryer
Samsung DV218AEW Electric Dryer Logo
1,287 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
