Question about Majesco BloodRayne 2 for Windows
Problem getting out a level
I am stuck in a level with bloodrayne 2 were i must open a door wich is destroyed with 2 knifes.
I must make the electric work again and i don't know how.
This level is following the train or metro station.
The name of the level is:union station abandoned shopping plaza.
I tried everything but I can not get out of this room.
  • 199 Answers
Mission Three: Union Station
Head through the hall and up the stairs and you will come out to the train yard. Hang a left and then enter the open door on the train. Go through the car and kill the enemies that appear and head out the other side. Enter the large building and a scene with more Kestrels will play. After the big bang, you are in for a tough battle with another Kestral and a few armed punks. After you get Kestrel down to the ¼ health mark, she will take off to a platform high above. Head forward to the ramp leaning against the train and climb it. Go left and slide across the rail to the train across from it. Make a left and run to the end of the train and jump to the pole. Swing to the pipe and climb up. Back jump to the next pole and swing your way over to the platform Kestrel is on.
After the scene, head back down and across the ground to the doorway on the far side at the other end. Enter it and follow the hallway through until you reach the set of stairs on the other side of the sprinklers. Follow the stairs up and then follow through the hallway until a scene plays that shows a catwalk collapse. Head up the stairs there and take out the punks and then make a right at the top to head up more stairs. When you reach the top, swing across the bars to the next platform and then halfway down the stairs. Jump to the staircase on the left and head up to the next platform and more poles to swing across.
Enter the vent at the end and follow it through to a large room you’ll drop into. When the Kestrel shuts the gate, you need to open it up. This part can get a bit tricky. What you need to do is toss a body into the electrical panels on each side of the door and make sure you have a body on each panel at the same time. When you do, the gate will open for you to go through. The easiest way is to use your hook and throw the bodies into the panels. You can try kicking them in but it takes a long time and getting two up like that will not work quick enough. Use the hook to throw them into them and then go through after it opens. Follow the opening in the wall around and through until you reach the staircase. Head up and take out the punks there.
Continue up the next set of stairs and make your way to the end of the corridor. Go through the door on the left and enter the hallway. Head left and drop down the hole at the end. Follow the next corridor along to a set of stairs and go up and up and up to the top floor. Head through the door and go up another set of stairs. Take out the punks here and then you’ll be in a room with a large window. After the scene hop through and head to the left and around the corner to the door there. Kill all the enemies in sight and then a scene will play as a guy comes through the door there. Kill him and then go through the door to trigger another scene.
Head through the door on the left after the scene and head through the room to the right. Drop through the opening and head down the stairs to the ground floor of the club. Look up to the right and there will be a large neon sign that says Strages. Target it and then toss up your hook to grab it and pull it down. When it crashes down, run through the door there and you will come to the dance floor. When the punks attack, you will need to toss one onto each of the four speakers in the corners. When you have a punk in each speaker, the dj booth will blow and you can escape the dance floor. Make your way up the stairs and again until you come to the floor with a doorway directly across from you. Enter there and take out the enemies inside.
Target the ceiling and then pull it down with your hook. Jump up the debris and head down the corridor to the opening at the end. Go to the fence directly in front of you and start wall climbing up to the top. Jump over to the closest scaffolding and take out the punk there. Go to the corner of it and rail slide down the pipe and again on the next one. Jump to grab the pole and swing over to the next platform. Make your way to the ramp and run down it to the catwalk against the wall. Run to the right and head up the spiral stairs. Kill the rest of the punks and then enter the gear room. After the scene climb up the pole in the room with your back away from the gear. Back jump off to the flat gear and land on it.
From there jump up and grab the pole and then swing over onto the next gear. Jump from that gear to the right and then from there to the pole above. Swing up the poles and then over to the gear beside the weight going up and down. Climb the pole with your back to the weight and wait for it to lower. Jump back on to it and ride it up. Now you will have a little scene with Ephemera. After the scene, you will battle her for a little while until another scene plays. After the speech Ephemera gives, the mission will end.
Posted on Aug 20, 2008
How do i remove the rear door panel on a 2005 pontiac grand prix
  • Instructions
      • 1Roll the door window all the way up. Disconnect the car battery's negative cable with a wrench.
      • 2. Remove all cover plugs on the interior door panel with a putty knife. Remove all armrests, door pulls, the window crank and trim-panel retaining screws with a screwdriver.3. Remove and disconnect any electrical devices in the door panel. Pry the controls out with a putty knife, and unplug the wires.
  • 4. Pry the trim-panel clips loose with the putty knife. Do not pry on the panel between the clips, or the panel could be damaged. Separate the trim panel from the door slightly, and disconnect the courtesy light. Remove the panel from the door.
  • Sep 12, 2012 | 2005 Pontiac Grand Prix
    1991 2 door lumina, can't open drivers side door it is stuck? tryed everything poss.
    about only option u have is to get inner door panel off so u can get to latch yes u will probably destroy the panel in the process but u should be able to get a new one at a junk yard
    once panel is off u should be able to have better access to latch to get door open
    Jan 23, 2011 | 1991 Chevrolet Lumina
    I painted s front exterior door and now it's stuck closed. how do i fix it?
    Well, first you have to get it open, get the stuck paint cleaned up, then remove some wood so that you can paint it without it hitting the jamb, or was it stuck to the stop? Anyway, when it dries, rub a bar of soap on there, it won't stick again. Hope this helps.
    Aug 05, 2010 | Garden
    How do you remove interior door handle form 1993 Ford Tercer The window won't roll up and I can't get the handle off to get the panel off to get to the window tract
    It's easy!
    1. Remove triangle-shaped plastic cover Fwd of door window - gently pry it off
    2. Remove screw from the plastic cover behind door open lever
    3. Remove door lock plunger. (unscrew)
    4. Remove screws down inside the door pull hand-hold area
    5. Look for other phillips screws - sometimes around the lower 1/2
    6. Pry hidden plastic hold down fasteners from around the edge - pull the panel away from the door and where you see it 'stuck' to the door, slide a pry tool, a stiff putty knife works well, up in that area and pop the fastener off.
    7. Lift door liner enough to get to the mirror power connector and unplug.
    8. For some model years, with door panel loose, you can access the bolts / screws that hold the interior trim piece in place and remove.
    9. Remove Mylar cover for access to 3 Mirror mount studs, speaker screws, door lock actuators, window motors, etc.
    10. Remove nuts, (hold the mirror up from outside) and remove mirror. (Feed electrical harness through door openings as required to facilitate removal.
    11. Reverse order for installation.
    Jun 01, 2010 | 1993 Ford Taurus
    I need to repair the locking mechanism on my 91 ford escort..cant get into door panel..can someone help
    Hello Paul,
    The following steps should get you through the process:
    you will need:
    An automotive trim tool, OR a strong butter knife or long flat headed screw driver, a phillips screwdriver, and some patience.
    • If you do not have the trim tool, Wrap a strong butter knife or long flat headed screwdriver in electrical tape.
    • Pry off the door latch bezel (remove screws exposed)
    • Pry off the window roller (if applicable)
    • If you have the tray/storage space on the door, check for screws, some have them some don't. Remove them
    • Remove all exposed screws
    • Pry the door trim panel from the bottom right, you should hear a "pop" about 1" in after lifting the panel about 1/2" up.
    • Pry your way along the bottom then work your way up.
    • Once all trip clips are loosened, the trim should be held at the top by the window seal.
    • Hold the panel on both sides and gently lift it up and outward in a rocking motion.
    • There may or may not be a moisture barrier between the panel and the door itself.
    • Installation is reverse of removal. PLEASE replace any damaged or destroyed trim clips. You can usually purchase a bag of 5 at your local auto parts store for about $4 USD. There should be 8 in your car's door panel.
    Best of luck!
    May 02, 2010 | 1991 Ford Escort
    Dryer doesn't stop when the door is opened
    it sounds like your door switch is stuck. you can replace it yourself. first, shut off the breaker. second, wrap a putty knife with masking tape to prevent scratching up the dryer. then, use it to pop open the plastic catch on each front corner. take your time and look inside the small gap with a flashlight to help figure it out. after you have the top of the dryer safely tilted back, look for 2 wires running to the door. they will plug into a switch that is flipped when you close the door completely. you know what i mean, it probably used to click when you shut the door. unplug these wires from either side of the switch. remove the switch and replace it. hook up your wires. close the top and you should be good to go. good luck
    Nov 01, 2009 | Whirlpool GEQ9800P Electric Dryer
    Hi, I'm housesitting for a friend of mine and I can't get their ASKO 5250 series washing machine to unlock to get my clothes out! It's been stuck for 2 days. HELP!
    If the door switch is faulty, you can manually open the door.
    Get a flat screw driver or butter knife, open the little door on the bottom left of the machine, from right to left.
    this is the lid for the water pump filter. You will see a red plastic ring which is normally screwed on to the machine with a philips head screw. Unscrew the ring from its position and pull down until the door pops open.
    Good luck.
    Ash
    Oct 21, 2009 | Asko W6021 Front Load Washer
    Hoover 5020D Dryer door won't open... button is
    You probably have a coin or other metal object stuck at the bottom of your dryer door preveinting it from opening. Take a table knife and see if you can push the object upward to allow the door to open..
    Jul 29, 2009 | GE DBXR463EDWW Electric Dryer
    2000 Toyota Corolla VE -- Glove Box Stuck
    The most common cause is something inside the glove box jammed in the latch. Push glove box door release , and GENTLY insert a flat putty knife, plastic knife, or similar type tool in the groove of door, GENTLY try to pry open the door. U will probably (hopefully) find a napkin, map, or glove (does anybody actually put gloves in the glove box?) jammed in the inside latch. Let me know how u make out.
    Nov 02, 2008 | 2000 Toyota Corolla
    Majesco BloodRayne 2 for Windows Logo
    210 people viewed this question
    Top Majesco Video Game Consoles & Games Experts
    EnergeeUK
    Level 1 Expert
    Are you a Majesco Video Game Console and Game Expert? Answer questions, earn points and help others
