Question about JVC Audio Players & Recorders
My JVC KT-SR 1000 Sirius Radio attached to windshield. The monitor will fade and then in a while the sound will stop' The radio seems to get very hot. I have tried to adjust the DISP button but it does not help. If I park my car in the garage it will work until it getd out in the sun on the windshield. This unit is about 10 years old. SID 001023904810 PSN 079E1165
  • cgatesnewbur May 26, 2011
    I had asked for a place where I could send my JVC KT SR 1000 radio for repair or can I purchase the fan and replace it myself.I use this radio in both our cars and I have all the cradels and antennas so I want to continue using this radio. Can I send it back to JVC for repair?
    President:
  • 2,047 Answers
The unit is having problems due to overheating. Usually this unit is supposed to have a fan inside it or a cooling mechanism to ensure that the unit remains cool. The location on the windshield only compounds the problem as the windshield transfers direct heat to it. try locating the unit in a different part of the car which does not have direct sunlight on it. Overheating is a problem that affects majority of devices and the rate of temperature increase from the sun has made this situation worse by the day.
All you have to do is locate the unit at a better place away from the direct sunlight and a part which has access to ventilation.
Hope this solution has been helpful?
Posted on May 23, 2011
Backlite display on JVC sirius radio stopped working?
Typical Sirius junk - overheats and display goes out. Buy a new XM Onyx Plus radio instead.
Dec 28, 2012 | JVC KT-SR2000 SIRIUS Radio Receiver
Citroen c15 van i have fitted a radio only when you turn the side lights on it blows the fuse
Does the radio work if the dash lights are off?
I'm wondering if the power and lamp wires are reversed in the 3 wire connector that plugs into the side of the radio.
satellite radio receiver
Aug 24, 2012 | JVC KT-SR2000 SIRIUS Radio Receiver with...
My sirius kt-sr3000 also works fine in car dock, but when inserted into it's plug+play boom box,boom it displays "antenna not detected"
Try swapping the boombox antenna with the car dock to see if you get the same problem. If yo do, you know the boombox is bad. Otherwise, its the antenna and you just need to get a replacement.
Jun 13, 2011 | JVC KT-SR2000 SIRIUS Radio Receiver
JVC KT-SR 1000 and KT-SR 2000
Tom, does the 1000 and 2000 interchange? I have 2000 that went out and it appears only 1000 is available new. Have all accessories would not rather dump if possible.
Thank you.
Aug 08, 2008 | JVC KT-SR1000 SIRIUS Radio Receiver
Backlight
My JVC does the same thing. i called sirius to cancel my subscription because of this reason and they are sending me a free cheap InV as a replacement.
Aug 18, 2007 | JVC KT-PK2000 SIRIUS Radio Receiver with...
Power supply to Sirius Radio
yes, some sirius radios work on 5 volts, and some work on 12 volts. Your sportster replay is a 5 volt unit. If you trace that wire back, you will find a cigarette lighter plug with a transformer built into it, with either wires soldered to the terminals, or a female cig plug wired up behind the dash. Whatever sirius unit you plan on hooking up, I strongly reccommend using the transformer that it came with......however if you're willing to take a chance, it's most likely 5 volts.
Aug 18, 2007 | JVC KT-SR1000 SIRIUS Radio Receiver
LCD screen back light doesn't work
Ditto - JVC KT-SR2000 backlight doesn't work (watched die yesterday), after 2 years, 10 months. Sadly JVC no longer represents quality.
Note: Original JVC KT-SR2000 was a fire hazard - defective from start - overheated hardly describes it. BestBuy replaced first month.
Feb 20, 2007 | JVC KT-SR2000 SIRIUS Radio Receiver with...
109 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
