My laptop overheats u can hear the fan running but it still over heats how can i fix this problem with out taking it in to a store?
  • 93 Answers
Right click the task bar and click "start task manager" on the menu. Once it opens, start with the "Applications" tab and see what's running, shut down anything unnecessary then, move on the "Processes" and "Services" tabs stopping all the things that are running & not needed. A lot of this looks like Greek but you can google it all to find out if you can shut it down or not. Also, do a complete system virus scan to be sure. Another thing to do is to clean your system with a free program called CCleaner
Posted on May 24, 2011
My hp laptop fan not working
There is really no need to do a test. If you turn the laptop on and you do not hear the fan running it is bad. If you let the laptop run for a while it will shut down because it will overheat without the fan running. You will have to take the laptop apart to get to the fan that sits on the motherboard.
Mar 24, 2012 | Compaq Presario CQ56110US Laptop
Tip
How to stop over heating laptops or computers.
1. Fix Internal Cooling. The first and most important thing you need to do when your laptop is overheatingis to clean the fan(s) that provide(s) cooling to the CPU and graphics card. Over time, they build up layers of dust and dirt that slow them down and block airflow.
A laptop that severely overheats causes damage to the internal components. Before this happens, the laptop should attempt to shut itself down. ... If you smell smoke, a burning odor, the fans never run or the fan runs all the time, be careful to avoid ruining your laptop.
The most common cause of laptop overheating is a non-working fan. ... Viruses, spyware, adware and other types of malware put a heavy strain on the CPU and other components of your laptop. This causes those components to heat up, often to a point where the fan simply cannot move enough air over them to cool them down.
Determine Whether Your Computer Is Overheating or Just Hot. Laptops get hot. It's what they do. However, if your laptop is shutting down, suffering from the blue screen of *****, or experiencing serious slowdowns, then you have a much bigger problem on your hands.
Heat is a computer's enemy. Computers are designed with heat dispersion and ventilation in mind so they don't overheat. If too much heat builds up, your computermay become unstable, suddenly shut down, or even suffer component damage.
IF you need more info on laptops or computers go to this link...
laptop over heating Google Search
on Oct 24, 2017 | Computers & Internet
My acer aspire 6530G keeps overheating and shuting down! does this mean i havta replace the fan, if so will i be able to fix it my self. Thank you!
The most common cause for laptops overheating is due to the location they are sitting while in use. I would recommend getting a cooling fan accessory that you can place your laptop on while you use it. Even having your laptop sitting on your lap will cause it to overheat because the cooling fan is on the bottom and it cant breath.
If you have an external cooling fan and it still overheats, make sure your PC fan is turning on. If its getting that hot you will more than likely hear the fan motor turning at a very high rate. Simply place your ear by one of the vent on the bottom of your PC.
If the fan is out, replacing these can be slightly complex if you are not comfortable taking your laptop apart. See if there is a local PC store in your area that may assist you with that. Most stores are happy to help out.
I hope this helps you,
regards,
Nico
Jul 06, 2011 | Computers & Internet
I have a Lenovo IdeaPad U460s 0885 - Core i3 330UM 1.2 GHz when i try loading sims 3 it overheats and shutsdown
Laptops shut down when they overheat to protect themselves from damage due to heat. Can you hear the fan running on the laptop? If not, then take it in to a shop to be looked at, or contact the manufacturer if it is still in warranty.
I will assume that the fan is probably running at full blast all the time. if this is the case, then you probably need to clean the heatsink on your laptop. How?
An air compressor is best for this if you have access to one. A can of compressed air may work, but usually does not have enough pressure to clear it out.
Your laptop fan draws air in through the bottom of the laptop and pushes it through a heatsink. The heatsink is a piece of metal that draws heat away from the cpu (main chip on the laptop) and allows the fan to cool it. The fan blows air between tiny metal "fins" on the heatsink. You will probably be able to find where your laptop blows out the hot air.
Find where the hot air comes out of the laptop, and blast compressed air into that place. You will probably see a cloud of dust come out of the bottom of the laptop. Keep blasting air until no more dust comes out. Once this is done, the laptop should run quieter and cooler. Let me know if this does not fix the shutdowns.
Hope this helps!
Joe
Jun 04, 2011 | Lenovo IdeaPad U460 1.2GHz Intel Core i3...
Overheating problem with HP Probook 4510s
Jun 04, 2011 | HP ProBook 4510s Notebook
It is been 1 year that I bought my laptop.I have Toshiba A665-s6065.when I use it for some hours in normal cases(internet,movie,...),Toshiba health monitor shows me that my CPU temperature is going up and...
Hi RGH.
How to Fix an Overheating Laptop - MakeUseOf.
What can happen to a laptop if it overheats?
Negative Effects of an Overheated Laptop ' Chron.com.
How can I stop my laptop from overheating while playing games?
Maintain a cool environment.Try keeping your laptop in an air-conditioned or cool area to allow your system to cool down and prevent it from overheating. Consider using a heat sink. Use a steel flat bar as an external heat sink. It works because your computer has to heat up more mass before it overheats.
3 Ways to Keep Your Laptop from Overheating - wikiHow
HOPE THIS HELPS YOU OUT.
Nov 04, 2017 | Toshiba Satellite A665S6065 Notebook
Hi, I have an Advent laptop that shutsdown after 10 minutes. Appears to over heat and I can't hear any fans running? Any advise? Regards Steve
Take a can of air and where the air vents are, blow alot of air into them to make sure the vents are free of dust and dirt, that can cause laptops to overheat.
If that doesn't work, you'll need to take apart the laptop and clean out the CPU fan so its clear of dust and dirt.
Apr 22, 2010 | Advent 4211c Notebook
Notebook fan is not running and unit is getting hot
the fan vanes are clogged, this may happen if you have pets or live in a humid region.
take the unit apart and remove the heat sink from the laptop, get some arctic ice silicone from a computer store and apply an amount equal to that of a piece of rice to the processor (after first cleaning of the residue on the heat sink), clean the cooling vanes out and replace the heat sink, put the unit back together and the unit should not overheat again.
The silicone will take a while to solidify to the optimum.
Apr 02, 2009 | Compaq Presario C700T , Pentium Dual-Core...
RED Ring of death xclamp fixed but..
Do you have the fan in? If you do, take it out or put 2 screwdrivers through the back holes to stop the fans from spinning. IF you have the fans out and its still not overheating, just leave it on for a while until it does. It will overheat eventually.
Nov 22, 2008 | Microsoft Xbox 360 Console
Acer overheats and slows down
yes in the dos startup where it gives you computer settings
by hitting delete right at bootup before it goes into windows or f11 or f12 depending on manufacture the heat source is right on the bottom of laptop they make a carage for the laptop that props it up right this is a normal thing amongst laptops
May 26, 2008 | Acer Aspire 3502WLCi Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
