Question about Toshiba Tecra A7-S712 Notebook
I have a set of recovery disks for a Toshiba Tecra A7 S712 Model #PTA70U-00J007, but whenever I try to start running the process, I get a message that says "WRONG MACHINE." I can restore with a set of A10 disks that I have, but the XP OS comes back with a batch of missing drivers. Where can I download a good set of A7 recovery CDs or DVDs?
SOURCE: toshiba a105 recovery disks display
if you already formatted the hard drive;there's n o way for you to get restore image of mce 2005;you have to call the toshiba tech and send your har drive to load the restore image again.u can also try to tap 0 while rebooting your machine.to access the restore image if u still have it instead of using the recovery disc.
Posted on Oct 15, 2007
PT2Jim
  • 31 Answers
SOURCE: software currepted, has no recovery CD
You possibly can still order a recovery cd set from manufacturer at a cost assuming warranty has expired
TOSHIBA INDIA PVT. LTD.
6F, Dr. Gopal Das Bhawan,
28, Barakhamba Road,
New Delhi - 110001
India
Tel: 91 - 11 - 23318422/9957
Fax: 91 - 11 - 23714603
Posted on Nov 14, 2007
Nic61
  • 1073 Answers
SOURCE: I need more speed
Well, thats no problem, and its easy doen...BUT i recomend you to start with upgrade the memory. In the spec of your laptop it says that there is 512mb memory, and that your laptop supports 4gb of memory. Im sure that you will need ever mb of that max memory if you want to run a cad program on your laptop, you need the memory more then you need the differns betwin 1,83 and 2,4 cpu that you want. Best is for sure t upgrade both to max, but if you have to choise one, take the memory!
Here is all you want to know about your laptop, including all avalible drivers (if you need any)
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1209156&rpn=PTA70U&modelFilter=A7-S712&selCategory=3&selFamily=1073768664&selModel=1209156%7CPTA70U
Good luck to you
Please take a moment and rate my answer
Nic
Posted on Feb 10, 2009
SOURCE: Restore Original Configuration
If you have not yet found time to call Toshiba and get the recovery CD you may try the following:
1. Reboot you system
2. Press F1 (immediately you get options to press F2 and F12)
3. Press F8 (this will give you more options including system recovery)
Please ignore if you already have the CD. Having the CD is the best as previously said.
The step above have helped me many times to avoid doing factory system restore. I hope it helps you or someone else.
Posted on Jun 12, 2009
rhinoking1
  • 85 Answers
SOURCE: reinstalled windows xp on tecra a2, need all drivers
Two things to try, install service pack 3 for xp, and go to the Toshiba website look up your laptop and see if they fave drivers that are compatible with xp sp2 or sp3. Hope you find what you looking for and this info helps. GL
Posted on Jun 23, 2009
I was restoring to "out of the box" settings with
Best bet is to obtain new installation media. If the recovery cds were corrupted chances are system files are corrupted as well. NTLDR or NT Loader, contains information regarding location of system files, operating system etc. To correct it you'll most likely have to reinstall, either fresh, or run a repair operation using whatever OS install disc you're looking to run on your machine.
Jun 22, 2011 | Toshiba Tecra A7-S712 Notebook
Where is the num lock on the tecra a7-s712? Where is the scroll lock? How do i turn them on?
Hi
they are quite often around the top row of keys and are usually marked with Nulock and Scroll lock and you may have to press the Fn key with the approiate key you could check out your user manual that should tell you deffitanely where they are
good luck
Jun 13, 2011 | Toshiba Tecra A7-S712 Notebook
Fn button in my toshiba tecra a7 is not working, this case hapened after i formatt the laptop? thanks.
To fix this problem please follow the links below
http://alturl.com/zvnbe
http://findtechhelp12.blogspot.com/
Thank you
Mar 26, 2011 | Toshiba Tecra A7-S712 Notebook
Toshiba tecra A7 fingerprint and password. fingerprint device f*#ked and i dont know password. HELP
I would contact toshiba.com and speak to their technical department as I am sure I have read a bullitin about that issue by way of an updated driver and BIOS firmware update.
Hope that helps.
Jan 16, 2011 | Toshiba Tecra A7-S712 Notebook
Need to restore factory setting for my toshiba tecra a7 laptop without cd?
impossible
you can reinstall windows and download the drivers on the toshiba web site the technically it factory
May 08, 2010 | Toshiba Tecra A7-S712 Notebook
TECRA A7-S712 DOES NOT COMPLETE POST WHEN POWERING ON
1. It seems that the problem may be with the BIOS Or Motherboard!
2. If you can do, try to short the BIOS.
3. Check this site for detailed process to short BIOS :
http://www.laptop-repair.info/toshiba_bios_password.html
Jan 04, 2010 | Toshiba Tecra A7-S712 Notebook
SYSTEM RECOVERY CD
Contact Toshiba Customer Support. They can verify your info & for a small fee send you a new recovery cd for your system. Hope this helps.
Mar 19, 2009 | Toshiba Tecra A7-S712 Notebook
I need more speed
I would max out my memory before i would buy another processor. if your mem is maxed out at this time, try XP smoker. its a really good optimizer geared for windows. it will make your cpu 3 times as fast as the current processing rate you are experiencing now.
Feb 09, 2009 | Toshiba Tecra A7-S712 Notebook
Cant get the password of Tecra A8
Clear it with the 'clear cmos jumper'.
Jul 06, 2008 | Toshiba Tecra A7-S712 Notebook
Stuttering Tecra A7
It sounds like you havent installed the graphic drivers for video card. When you installed xp did you formatt the hard drive and do a clean install?
Drivers for the graphics and chipset can be found on the makers website.
Dec 29, 2007 | Toshiba Tecra A7-S712 Notebook
Toshiba Tecra A7-S712 Notebook Logo
89 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
