Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
Starter moter will not turn over motor soinide cliks but when starter moter dos try to start just a grinding noice
Why my 92 toyota celica wont start jus go clik clik is hot. The mechanich clooless
loosen the starter and try again. if its in a bind it will do this click click action. but if the starter motor is bad and the solenoid is good it will also make the clicking sound.
Jul 18, 2014 | 1992 Toyota Celica
New starter problems on a 99 suburban 1500 4wd 350 vortec
pull the starter and check the ring gear teeth for burrs and mashed teeth. Ensure that the new starter has the correct number of teeth on the pinion as required by the ring gear or you will have the wrong gear ratio for your vehicle. There are many engines that use the same starter motor but are differentiated by the number of teeth on the pinion. I suspect that will be why there is hard noise and kick back as that is the out of mesh gears trying to work
Dec 25, 2013 | Cars & Trucks
Starter motor solenoid wont engage
There is condenser shaped part attched to the starter moter this is the part which makes the starter moter to spin and when it is stuck the moter does not spin you can check it by one person sitting in the car holding the key to start position and another one hit it softly with some spanner or something The starter moter will move there is a small gear in it which requires replace ment Or the other possible reason can be the carbon brushes in the starter moter are worn out or the place where these brushes touch on armature the place is worn out that Y ou will only come to know when you will take the moter away from the engine Lastly I hope you might have checked your battery that it is giving sufficient current to the moter
Aug 16, 2012 | 2003 Volkswagen Jetta TDI
My 95 buick lasabre just clik and don't crank we replace battery and started
If it just clicks make sure the engine isn't locked up by turning it by hand. If it turns freely it is possible that you have a defective starter motor provided all your connections to the starter and battery are clean and making good contact.
Jun 16, 2012 | 2002 Buick LeSabre
Starter moter is not strong enoth to run the bike so i had it cheked and its ok but i just get clik clik .when i start it up.
Sounds like the solenoid contact point is not hitting the solenoid cap. The solenoid cap have this two terminal( + ) which when you activate the solenoid, a rod would push copper bar and short the two terminal, thus giving power for the starter motor to wind up.
You should pull down again the starter and check that solenoid cap and make sure the contact points are clean and equally seated when it was hit bay a fusing bar.
Thanks for using FixYa!
Jul 04, 2011 | 1991 Yamaha XJ 600
Zip 100 wont start battery not flat, motor does not turn over just a clicking sound. Will start with the kick starter
Sounds like dirty terminals, start their. If that is OK, then your solenoid has crapped itself. You can clean the dirty terminals, but you will require an auto-electrician to fix the starter motor.
Jan 19, 2010 | 2005 Gilera Runner VX 125
The engine wouldn't turn over.
check the battary make shore theres plenty of life in it , if that doesent work make shore the starter moter is not jamming, if the stater moter is jamming try to krank it over mannualy that will free the starter moter , and then it should turn over . if it does then your starter motor is the problem
Jun 22, 2009 | 2004 Dodge Durango
Suzuki Bandit 400 not starting
The starter motor could be the culprit, check the starter motor.
Apr 15, 2009 | 1993 Suzuki GSF 400 Bandit
The car cut off and won't start, attemps with a grinding noice?
If you are Getting a Grinding noise, It is going to be the Starter. I would get the Fuel Pump and Filter Checked out also as the Starter would not cause the Car to Die. But, The Fuel Pump and Filter Would. Let me know what you find!
Jan 24, 2009 | 2000 Mitsubishi Galant
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
49 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
