Question about Gateway FPD2185W 21 in. LCD Television
No signal from computer to monitor 8/13/08 posted by mcartolano
If you read the posting and can offer a solution I would be most grateful!
  • 1 more comment
  • wjboyd Oct 07, 2008
    Not a damn thang comes up on the monitor. Tried using the vga plug instead. Still nothing shows on the screen. The power button won't even cut the monitor off.
  • Anonymous Oct 08, 2008
    same issue...plugging the power cord in give me 1 sec of blue on the power button, then a quick blue flash on the power button then off with no display coming on at all...
  • lilsecsi Oct 11, 2008
    For the last few days I have had to unplug the power cord from the monitor to get it to go on. The power button does nothing. Today, I unplug/plug the power cord in and I hear a humm for two seconds, get the Gateway logo on screen for one second then screen goes black.
    Novelist:
  • 159 Answers
On these it is usually the power/inverter board that causes this problem.
I repair quite a few fpd series models.
ebays bammbammfran
Posted on Oct 09, 2008
I have an AOC monitor and a Lenovo computer. The monitor comes on and says no signal when and the goes off. I have no idea how to change the resolution when I can't get the monitor to stay on.
When the computer is booting up, can you see the POST? No matter what resolution you set the computer to, you should at least see that if your computer is indeed working. If not, make sure your monitor is set to the correct input (DVI or VGA); there may be buttons for you to go into a menu system to select input. If you can see the POST but the monitor says "no signal" when Windows loads, then you'll need to go into SAFE MODE to change the resolution. To select that, press F8 just when Windows is beginning to load.
Jul 31, 2011 | Computers & Internet
My HP Pavilion a6642p PC has a monitor but the monitior says no signal input
If it says no signal input, then your computer is not putting out a signal. Possibly a bad video card. Also can be a computer that never really boots up and passes the POST. Unless the POST completes, it won't send a video signal.
May 12, 2011 | Computers & Internet
Monitor won't turn on power button blinks blue
Your computer is not POSTing and the monitor has gone into standby mode as it is not receiving a signal from your computer. My published guide entitled My Computer is not turning on!!! Is it dead!!! No POST!!! will get your computer working again!
Happy testing!
damnor01
Nov 27, 2010 | Gateway FPD1975W 19" LCD Monitor
POST test
no no need at all you can take the post without loging off or in active power just disconnect signal cable and see the massege no signal check signal cable
Feb 28, 2010 | Computers & Internet
Monitor shows on receiving signal, will not display image.
The Viewsonic VX2235WM has a known issue with the power supply going out. The flashing power light or no picture is the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jun 02, 2009 | ViewSonic VX2235WM Monitor
Monitor doesnt switch on
Can you try another monitor?
Since you did try another video card (AGP). I posted (In you're other post), you have to make a bios adjustment under Advanced menu. Once you're P4SP-MX bios is set to boot to the AGP or set to Enable. The bios will no longer try to load the on-board VGA card. I am not being picky about the statement I am going to make ( so don't be offended). Monitor's only receive signal. They do not send signal to PC, just receive. The odds of two video cards not working is high. You did mention you have not heard P.O.S.T (A single beep), which is a test of the motherboard. There could be a loose connection in you're PC. I would remove the memory first. Clean the contacts with alcohol on a cotton swab & blow out the memory slots with canned air (allow time to dry). Than firmely reseat the memory. I would than re-check all data & power connectors within the PC, making sure all are securley connected. With respect to the AGP card, I would do the same. Remove, clean & reseat. Most older AGP's require additional power. Some use a power cable that is also used to power a floppy drive & others use a 4 pin molex (see link),
http://pinouts.ru/connector/4_pin_Molex_power_connector.shtml.
When you are in the bios & within the Advanced menu you may also need to set the bios to read you're AGP card to the correct speed. (EX: 1x,2x,4x). Page 2-19 in you're manual. Once all these checks & cleaning have been completed, try again. Boot the PC and hopefully you will see display on you're monitor.
Post here. Let me know how thing go. Don't assume anything, check all.
Luck!
Mike
May 12, 2008 | ASUS P4SP-MX Motherboard
Computer not working with Samsung LCD TV
Your PC isn't working, the "CMOS Checksum Error" is a BIOS error. It has nothing to do with the monitor.
You have to let the PC load the default settings and try to boot up, if the defaults doesn't work, you have to reconfigure the options in the SETUP program. To enter Setup press "Del" or "F2" in the POST screen.
May 05, 2008 | Televison & Video
Is this dv4000 dead?
same here i believe its the hard drive. im replaceing ti to day ill post it that fixes it
Apr 15, 2008 | HP Pavilion dv4000 Notebook
Acer AL1716 (black) - Drops to No Signal -
Eric,
My apologies for the rude treatment you received from one of our Experts. I have deleted his post. I will be dealing with the Expert personally, and will also request that one or more of our Experts who are familiar with Acer Monitors come assist you with this question.
Again, on the behalf of FixYa, I offer my most sincere apologies.
John Goodman
Community Manager
experts@fixya.com
Feb 14, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
63 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
