Question about Garden
Have bought a riviera horizon 260 porch awning but have no instuction how to put it together could please advice mrs lock
2 Suggested Answers
  • 59 Answers
SOURCE: Would like to see some drawings of how to erect a Wessex 260 awning for the first time
The only instructions I could find are written, not drawings.
https://system.netsuite.com/core/media/media.nl?id=1248098&c=3378359&h=7e396119957381494398&whence=
Posted on Mar 07, 2017
Awning problems on a avenger 26bh
Please describe the problem that you are having in detail.
May 03, 2014 | Prime Time Manufacturing 2012 Avenger 26BH
We just purchased a used '99 Starcraft Field & Stream PUP. There were no instructions for setting up the awning. I need step-by-step ''how-to'' help since everything I've found says, ''raise support...
I had exact same problem on my 93 popup. I finally figured it out. First, the poles with the plastic rings slide into the poles with the metal rings. These are the vertical support poles. Next, the poles w/ plastic nipples slide into the other poles with rubber ends. When put together the poles with the nipples should be spring loaded. These spring loaded poles rest against the top of the camper and the nipples are inserted into the 3 holes of the pole that go across the front of the awning giving you rafter support. The tension from the spring should keep the pole in place against the side of the camper. The first 3 poles with the plastic rings go from the ground to the front awning pole where the nipples can slide through the plastic ring and then into the awning pole. The vertical poles can be adjusted for height by sliding them up or down and then twisting them like a screw to tighten them up and keep them in place. 2 of my 3 vertical poles will not lock when I twist them so I have to get tricky with them. The metal rings, which should now be at the ground, are there so that you can stake it down under windy conditions. I hope this wasn't too confusing but I beleive it will help you. Good luck!!!
May 14, 2009 | Sport & Outdoor - Others
I need assembly instructions for Corsican Classic Iron Crib #1682
I need Stabilizer Bars for Delta Luv Crib #4750 - 6
Jan 11, 2009 | Corsican 1682 Crib
Instuctions
1. Turn on the blue tooth headset
2. Press both volumes keys together so light flashes red/green
3. turn on phones blue tooth
4. Find device and select.
Jul 15, 2008 | Sony Ericsson Akono HBH-300 Consumer...
Garden Logo
208 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
