What does it mean by registering an event handler in context of javascript ?
  • sumitnxt148 May 23, 2011
    great answer thanks.
    Scholar:
  • 92 Answers
In JavaScript, registering an event handler is completing an action upon some event. For example
element.someAction = doSomething();
So if a user clicks on the element, the doSomething() function is called. This would be called registering an event handler. More on this can be found here.
Posted on May 23, 2011
What does inertia mean
In this context it probably refers to the switch designed to operate and switch off the power to the fuel pump in the event of a crash to reduce the risk of fire.
May 02, 2014 | Electric Fuel Pump Inertia Switch FV-7
I need to load a frame in my html page in the event of submitting the value of one of the radio buttons in the list.how can i do this by using html and javascript?
Hi!
Download JQuery and use that. JQuery will help you with a lot of problems and ease your programming with javascript.
I hope this helps.
Jun 09, 2010 | Microsoft Computers & Internet
When i right click on any folder the particular window freezes saying not responding for atleast 5 min but i can access all other application or icons from desk top. im using win xp sp3
This issue is usually due to a bad context menu handler. When you right click on an object the context menu is called and any installed handler objects are called also. If one of the these additional objects are broken or missing, it slows the whole process to a crawl.
There is a utility that will allow you to see what context menu handlers are installed and it will also allow you to disable the individual context menu handler components.
As there are potentially numerous items, there can be a lot of choices. In my professional experience, if you have an older version of Office installed (Office 2000, Office XP, or Office 2003) sometimes the Microsoft Picture Manager can break the context menu.
Also look for any context objects that reference a tool but display "File Not Found" under the "Filename" column of the utility, as the operating system is trying to load something that is not there to load.
The utility is called ShellExView, it is created by NirSoft and can be found here at http://www.nirsoft.net/utils/shexview.html
Feb 24, 2010 | Microsoft Computers & Internet
Sir, when I Right-click on any file then it take so much time to open or my right click is very slow.Plz help me.
  1. your pc have lots of applications installed remove those applications which are not in used.......
  2. used some better antivirus program may be your pc have affected with virus...and that's y your pc takes lots of time..
  3. click on the start button then click on the run or press ctrl + r
  4. then type temp and delelte all the files from there
  5. then again use the 3 number point which is return above and then type %temp% in it and delete all the files from there
  6. then again used the 3number point which is return above...and type prefetch then enter and delete all the files from there....
  7. or if you think that this process is typical for you so used ccleaner software....or speed up my pc software
  8. used the 3 no option from the above statement and type msconfig then click on the startup tab then click on the disable all and restart your system....
  9. and if the program still there format your pc bcz your system have infected with viruses.....
Jul 25, 2009 | Computers & Internet
How to call Javascript function on click event of Flash Button while clicking on button
try this:
create a button and in the actions window, add:
on(release){
getURL("javascript:myJsFunction();");
ensure you have the js function loaded into your parent page...
regards
Dec 31, 2008 | Computers & Internet
Desktop Right Click Problem
This is generally an error from the registry, namely the context menu handlers (which is a shell extension handler that adds commands to context menus) If you can isolate when it started to occur and then maybe you can link it to a program you installed.
Are you having any having any other problems with your system emptying the bin, media apps??
I can suggest a progam that you can download that will allow you to see what extensions are in use and hopefully from this you will see if there are any left over commands from bad unistalls
Jul 10, 2008 | Dell XPS 200 PC Desktop
TRIGGER IN SQL
A trigger is a special kind of stored procedure that automatically executes when an event occurs in the database server. A trigger is really an event handler. SQL Server allows users to create triggers (event handlers) for 3 types of events:
  • DML Event - Occurs when a DML (Data Manipulation Language) statement: INSERT, UPDATE or DELETE, is executed.
  • DDL Event - Occurs when a DDL (Data Definition Language) statement: CREATE, ALTER, or DROP, is executed.
  • Logon Event - Occurs when a user logins to the Server.
There are 3 different types of triggers (event handlers) based on the types of events they are triggered by:
  • DML Trigger - Executes in response to a DML event.
  • DDL Trigger - Executes in response to a DDL event.
  • Logon Trigger - Executes in response to a logon event.
Jul 03, 2008 | Microsoft SQL Server 2000 Standard Edition...
Javascript code for Flash Button's click event
you need to create functions & your own defined set of commands and then call those functions with the flash custom made buttons.
it will work fine.
Feb 08, 2008 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
