Question about Cell Phones
On the Motorola V3 the # key is used also to change rapidly from one type of ring to another. When you hold the # key right now it is set for either LOUD or SILENT. How do I go about changing from SILENT to VIBRATE ? Thanks
  • 2 more comments
  • randbfrank May 23, 2011
    That is a negative..... The SILENT ring style does NOT allow any changes. You cannot scroll down the silent profile and make it VIBRATE.
    There must be a program command to make the # key a VIBRATE key.
    I will download the information as per your suggestion, but I do not believe that will do the trick.
    Richard
    Motorola V3 bought thru ATT has programmed from them that the # KEY when pressed, toggles from LOUD to VIBRATE and vice-versa.
    The phone I bought thru AMZN that came unlocked blah.. blah... has the # KEY set to SILENT, so it toggles between LOUD to SILENT and vise-versa.
    How can I reprogram the phone so that I make the # KEY to toggle between LOUD and VIBRATE ?
    Richard
    Thank you for your comments and thank you for your honesty.
    I have an "old" ATT/Cingular Motorola V3 that has that feature on the #key. It is probably, as you say, a different OS on the phone.
    Oh well, can't win them all. Thank you again
    Richard
    The most helpful part was the HONESTY of the expert who gave the facts as they are. Most appreciated.
  • Cell Phones Master
  • 4,737 Answers
Just to be honest, it's not possible, but technically and perhaps it must be possible by customizing
the application data of the Phone. Which means you need to install a new customized o.s. I have never heard about it either, but I am only telling you the possibility. In fact, you can't change the default Loud and Silent switch. Other keys like, navigation keys, soft key, etc.. you can change, but # key function can't be modified or changed. Hope this clears your doubt.
Let me know if you need further help..
Good Luck.
Thanks for using FixYa.
Posted on May 23, 2011
  • Lebanon Raingam
    Lebanon Raingam May 23, 2011
    You are welcome and thanks to you too. Regards.
    President:
  • 2,047 Answers
Motorola just like other phones come with the silent feature on the # key. You can change the alerts for incoming calls and other events. Your changes are saved in the current ring style profile.
Go to settings > ring styles > silent scroll to calls then press change to edit from here you can select the vibrate option so that the phone vibrates when on silent mode.
here is a link to a user manual of your device
http://www.motorola.com/staticfiles/Support/Mobile%20Phones/RAZR%20V3/US-EN/_Documents/Static%20Files/V3_06_UG_generic.pdf
The same instructions above can be found on page 40.
Hope this solution has been helpful?
How to turn off text clicking
REDUCING KEYPAD VOLUME
STEP 1 Press the phone's menu key, located between the two soft keys on the top of its keypad.
STEP 2 Scroll to "Settings" and press the center key to select it.
STEP 3 Scroll to "Ring Styles," press the center key, scroll to the specific ring profile that you are using and press the center key to select it.
STEP 4 Scroll to "Key Volume," select it by pressing the center button, turn the volume all the way down and press the center button to lock your changes.
STEP 5 Press the soft key labeled "Exit" to exit the menu system.
STEP 6 Repeat this process for every ring profile in which you want the keypad not to make sound when you use it.
Mark
Motorola Support
May 09, 2014 | Motorola Mobility RAZR V3
Ringtones silent
Make sure that you didn't turn your phone to silent. Hold down the # key and see if it say silent or loud, soft, etc.. Make sure that the volume is turned to maximum, by using the top switch on the left hand side of your closed hand set. Make should that you have a ring tone assigned because if not nothing will work. Follow the below instructions
Menu-Settings-Ring Styles-Detail-Calls (Assign a tune)-click OK
This should get your ring tone back
Feb 26, 2011 | Motorola Mobility RAZR V3
WHERE I CAN GET MOTOROLA V3 PC SUITE?
Go to rapid library and get index.php...in that you can type motorola v3 pc suite ...You will get download option ...Hope this will help you...Thank you...
Oct 20, 2009 | Motorola Mobility RAZR V3
Can't change message alert on v3 razor
it is simple.
press menu key (circle dot in middle)
go to settings
go to ring styles
Go to (watever it is on) details
Scroll until you find Text Msgs:
and change it
Mar 28, 2009 | Motorola Mobility RAZR V3
Red Motorola V3 Razr
try going to settings, audio, then change the "Style". Also check the detail of it to make sure it is set for the volume and ringtone you want.
Jun 27, 2008 | Motorola Mobility RAZR V3
No Ringtone
try pressing and holding the # key. Motorolas can be put in sient mode this way and may need to turn the volume back on with the same method. If that doesnt work try a master reset. (Instructions for this are on motorola.com). If it stil isnt working try removing the battery with the phone turned on. If all else fails contact your carrier for warranty information
Jan 18, 2008 | Motorola Mobility RAZR V3
Ringing styles problem sir,,
try resetting your phone to its factory settings...
Oct 16, 2007 | Motorola Mobility RAZR V3
Loud key sounds
with your v3 press <<>> select <<>> select <<>> in <<>> you must choose a ring style exemple:<<>> then goto <<>> and move to <<>> and change 7,6,5,4,3,2,1. Normaly, i put number 3 it's loud enought.
Aug 22, 2007 | Motorola Mobility RAZR V3
Message alerts v3
I have this problem I can't access the loud setting but I can the soft I'm not yet sure why but you may need to update the software on your phone to fix this bug. Sometimes I take off the back and take out my battery and put it back in and then sometimes i can access also when you select your ring tone to change just push left or right instead of using the menu that drops down that also sometimes works for me hope one of the helps.
Feb 24, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
