My problem with adobe PDF files are too big (4 MG) to be sent and I looking for a solution to reduce the size of the file to half or moreof this size because I have send these files to have them put on the Web.
  • 1 more comment
  • geeon May 23, 2011
    Dear Rockmeister,
    I cannot send my files as zip file because the PDF files are used in our website. I cannot convert them to jpeg images either because as you say all pages will go as individual pages while we prefer to send files as a set of pages. Our webmaster has not complaint yet but sooner or later he will ask us to reduce the size so that it will not take up too much space on their server. Do you have another solution?
    best regards,
    John Kwok(geeon@netvigator.com)
    OK, Thanks for your help
  • geeon May 26, 2011
    The suggested solution as good and reasonable price ar $39 and I intend to buy this program. thanks a lot to you jackpot00 for your help.
    Gee On Kwok
  • 2,574 Answers
Download and install PDF optimizer >>start Download
Use it to reduce the file size.
Posted on May 23, 2011
    President:
  • 2,047 Answers
PDF files cannot be reduced unless you use compress software to zip the folder, and send.Although there is another way you can send them you can try to convert the pdf files to jpeg and this way compress the pictures so that they would be easier to send. Only problem with this is that the documents would be arranged as individual pages. If this method is not satisfactory let me know so i can find other alternatives.
Hope this solution has been helpful?
  • Rockme
    Rockme May 23, 2011
    Hello John kwok, i will check and get back to you. Will send you a direct mail when i find anything. Thank you for visiting FixYa.
How do I reduce the size of the .pdf files I make when I scan a document on my HP Officejet J4580? I get 15 page .pdfs sent to me that are half a mg in total size, but my docs, scanned at B&W or...
Hi, Brice,
Do not change anything with resolution.
After selecting Scan to PDF, click on Advance Option. Here in the new window which opens at the top you can see PDF as selected. Beside this "Options" button will be there. Click on it and a slider will appear. It will be at maximum. so you need to move the slider to minimum or closer to that and click OK Try scanning.
This will reduce the file size. This should be helpful
Regards,
Sean
May 23, 2014 | Office Equipment & Supplies
Tip
Reduce the file size of a PDF file
Sometimes when we scan a document and the output file is PDF the file size is too big which is very difficult to send as an email attachment. This also happens when you convert word documents into PDF format.
This guide assumes that Adobe Acrobat Professional or Standard is already installed on your computer for PDF conversion.
On your current PDF File click on File then select Print
On the Print window select Adobe PDF as the Printer Name then click on the Properties Tab
On the PDF Document Properties Window under Default Settings drop down, select Smallest File Size.
Click on OK on all open windows. This will start the conversion process. When it's finished this will prompt you to save the file. It is advisable to save the file in a different file name rather than replacing the original copy.
After the conversion you may compare the file size of the original file and the reduced PDF file. The reduced file can now be sent on email attachments easily.
on Apr 10, 2010 | Computers & Internet
Hello, i want to increase the front size on my dymo label maker. can you tell me how. thanks
For the LetraTAG see next page, pdf file (readable with Adobe Reader):
http://global.dymo.com/img/compel/jtnGWWsxLca9XoVQSkDLTDqfwWeAPBw9.pdf
Look in the second column. Under "SIZE" see how to setup your font size: condensed | normal | extended | big caps.
Apr 19, 2010 | Dymo LetraTAG Thermal Label Printer
Lexmark 7100 scan to .pdf makes file 23 times bigger than usual
> it should be 2-300K
Only if you use Adobe Acrobat (full version) to create the PDF.
All the "text" in the PDF will still be encoded as "scalable text fonts",
rather than as bitmaps.
Anything you "scan" will just be zero and one values,
and the size of the file will be proportional to the amount of "black" (and/or colour) in the scanned image.
Nov 26, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I HAVE A LEXMARK X9350 AND WHEN I SCAN ITEMS, THE FILE SIZE IS HUGE. EG 1 PAGE = 3MB. HOW CAN I REDUCE THE SIZE OF THE FILE
See the manual for X9350 on page 119.
The software application must be used for saving files to a specific format that you can select from the menu on the computer.
Standard scans are often saved as bitmap with the extension .bmp .
Select another file format like jpeg with the extension .jpg or .jpeg, when you want to view the scans in photoview afterwards.
Another option is to save the file in a format that can be read with Adobe Reader, selecting .pdf format.
A last option is to reduce your file size, changing the scan settings:
( I wouldn't advise; this can result in unclear copies ):
Advanced scan settings can be changed on the computer as well:
See reducing e.g. "scan resolution" and "color depth" on page 120.
Use the link support for Lexmark 9300 series for more help.
Sep 22, 2009 | Lexmark Office Equipment & Supplies
I can not reduce the file size on a pdf. document. How might I do this?
If you are using the Standard version and not just Reader, then under File there is "Reduce File Size". It will resave the file smaller (you may want to rename so you keep both files).
Jul 28, 2009 | Adobe Acrobat 6.0 for PC
Cannot compress a PDF
I assume you have tried the "reduce filesize" command. Try opening the file in Preview and print it - in the print dialog box select the pdf button, type a name and print. You get a file in the location you selected. This can reduce the size considerably.
Jun 26, 2009 | Adobe Acrobat 7.0 Professional for Mac
Intruction Manual for Panasonis DMR-EZ47V
I got your e-mail address.
I'm trying to send you the guide but the PDF file is big, so i'll have to use winzip to compress the file and make a bit smaller just to send it to you.
Once you get it, you will need to use winzip to open the file and to read it, you should use adobe acrobat reader 6.0
Mar 02, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Reduce Photo
You can use Photoshop to reduce Photo size to a minimum size that can be mailed and u can retain the resolution by it. Its afantastic application. Open your image in photoshop and right clik it on the top of the title bar choose image size and change the resoution to 150DPI or lessere but not less than 72 DPI.
R u can go to save as command in the file menu and save it for Web option is better to reduce the size of the image to very smaller one which can be mailed.
Thanks
Nov 09, 2007 | Adobe Photoshop 7.0 for PC
Open Questions:
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
