Question about Balboa Instruments Duplex Digital Panel 2 Pump
I have a Balboa R574 control and heater on a Jacuzzi Spa. The motor starts and runs fine on low speed, but trips the exterior GFI after about three minutes running on high pump. The pump and motor were replaced this season. The heater and pressure switch are brand new. The red wire going to the J terminal looks like it over heated and is scorched. The fuse does not blow. What else should we look at? Thanks, Susan
    Scholar:
  • 46 Answers
Understand that this information isbeing provided as-is and without warranty or guarantee. As with allelectrical components and devices, all work should be performed by a licensedspa or pool technician. Serious injury or death can occur if a component isimproperly repaired or installed. This islikely an issue with the GFCI breaker not being able to handle the load or aproblem with the high speed of the pump.
You can find answers to common spa orbath problems online at http://www.balboadirect.com/support.aspx Hope that helps!
Posted on Sep 12, 2011
I have a Jacuzzi spa with a Balboa R576 (522205) control box. The control panel constantly shows "OH" (overheating) even when the water temp is 50-100 degrees F. When I reset the system by flipping the...
There are some things to check.
Make sure the vents on your cabinet are not obstructed.
Make sure your filter cycle is not too long
Make sure you are not running high speed for more then 30 mins.
Have you looked through the Balboa error message site. I have attached a link follow your error through and you may find your answer. Diagnostic Messages
Mar 02, 2015 | Balboa BB58048 Jacuzzi R574 R576, 4.0KW,...
Leisurebay spa with Balboa controls.Just wired it up 240v.as soon as i flip the breaker it trips.disconnected wires from pump relay and connected them together,now the breaker stays and the pumps will
make sure the spas control panel is set for 230v next check the GFIC it might be faulty. AS A TEST ONLY you can bypass the gfi af all works, try another GFI. but this doesn't rule out.. shorted motor,heater or even a light ..
give me a vote if'n I was of help.I love praise, it's the fuel that keeps me fix'n yer stuff.. Jay
Nov 12, 2014 | Pool & Spa
No temperature display cant set temperature
Located behind the access panel there is a grey box that is the spa pack. Open that up with the 2 screws on the top of the pack. There is a small glass fuse on the circuit board. One of those fuses is most likely blown. If that is not the culprit you need a new topside control. More than likely it's the fuse.
Mar 04, 2013 | Jacuzzi Balboa R574 System for 1 2 Speed...
Balboa hot tub m7 wont power on at all
Either the spa is incorrectly wired or one of the fuses is blown in the spa pack. Typically this is due to your electrician wiring the spa incorrectly and blowing the fuse on accident.
Aug 06, 2012 | Jacuzzi Balboa R574 System for 1 2 Speed...
Hot tub keeps running all night keeping me awake. How do you shut it off? It's a Great Lakes.
If the system is the Jacuzzi 52221-05 system mentioned in the subject header, there could be a stuck relay causing the problem and you might need to get a spa technician out to assist you in repairing the problem. However...
If it is a Great Lakes system as mentioned in your message body, then there could be a programming issue allowing the filter cycle to run continuously. Provide a model number off of the Balboa control. Then we can provide you an instruction manual or reference card to assist you in resolving this problem. you can also search our online manuals at our website. You can find them online at:
BALBOA WATER GROUP INSTRUCTION MANUALS
Sep 18, 2011 | Jacuzzi Balboa R574 System for 1 2 Speed...
Colman Spa trips GFI what is most common problem? GFI test good. Pump disconnected still trips, is heater most likely? Can you replace only heater? thanks
this should be simple ...
1.shut off the power
2.disconnect wires to heating element
3. turn power back on and see if it works if so replace heating element 45-95 dollars
if it still trips unplug all the cables from the pumps blower ozonators and see if it runs now,,,, if so plug each cable back (one at a time) until it trips again.if it trips that the problem pump etc.
99 percent of the the time its not the gfi its a device that is wet or shorted out ..Try everything else before replacing the gfi
Dec 31, 2010 | Balboa Instruments BALBOA 30kW HEATER ASSY...
Our hot tub screen is not on is there a reset button? the jets are still turning on but there is no way to adjust the temperature control
No there is no reset button for the keypad display. The only way to reset it to switch off the power for a short while and then turn it on again.
Your fault will either be with the keypad connection on the PCB within the spa pack. Or more likely a problem with either the PCB or keypad.
Your best option is to get a spa tech/engineer out to investigate the problem.
Regards,
Ian Kime.
http://hottub.synthasite.com
Dec 05, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
When i turn jacuzzi on it primes and one of the pumps/jets turns on, then when i try to turn the other jet/pump on it makes a funny sound and blows a fuse i checked to see if any air is in the line but...
This is probally a bad motor, the sound you hear is the motor trying to start but when it can't the breaker trips. If it takes a start capacitor it may be this rather than a motor but you will have to pull the motor to see. It may also be a clog in the pump but the motor sounds like the problem.
Sep 29, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
WHAT IS THE MODE BUTTON FOR?
EC stands for Economy. Change the mode until you reach ST and then it will stop flashing and function as normal.
Economy mode only allows the heater to function when the hot tub is on its filtration cycle.
Regards,
Ian.
Jan 04, 2009 | Jacuzzi Balboa R574 System for 1 2 Speed...
Balboa Instruments Duplex Digital Panel 2 Pump Logo
305 people viewed this question
Top Balboa Instruments Garden Experts
Ian Kime
Ian Kime
Paul Stonecypher
Paul Stonecypher
Level 1 Expert
Mister Danger
Are you a Balboa Instruments Garden Expert? Answer questions, earn points and help others
