Question about Kingston Technologies 512MB DataTraveler I (DTI512KR) Hard Drive
The capacity of my USB key (512 Mo) is reduced to 0 kb and I can't access neither format it
  • Kingston Master
  • 27,725 Answers
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Posted on May 23, 2011
  • Brian Sullivan
    Brian Sullivan May 23, 2011
    click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
    click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
Andiyi had a memory card of sandisk 8 GB in which the windows was unable to format?
never don't use windows utility for flash drive formatting. use only manufacture's format utility. http://kb.sandisk.com/
Aug 17, 2011 | SanDisk 4GB microSD High Capacity Memory...
My one week old usb today said used capacity 0 bytesfree 0 bytesfile system raw.cannot be formated.it says insert flash drive. This happened the last new usb device I bought three weeks ago. Is this a...
This is probably a problem of system files on the USB key.
First of all, read the manual for the key, and verify that no utility provided with the key to reset or reformat. If such a utility is present, it is recommended that you used same before proceed to next step.
Otherwise, to reformat and therefore repair the USB key, you can use standard tools of Windows. Insert the key into the USB port of a PC, then go to:
Start / Control Panel / Administrative Tools / Computer Management / Storage / Disk Management /
Select the drive to the USB key in but ensure same is not a hard disk system!
Once the back up of your USB key effected, delete the existing partitions on the key (right click / delete the partition.). Format the key to FAT16 using all the available space (right-click / Format). For more than 2GB, it is recommended that you format same as FAT32.
If the available space is under the capacity of the key, this is surely a hardware problem, in which case it may be necessary to reduce the after-sales service.
It should be noted however that a difference of about 10% should not be considered, prior the way the manufacturer has recorded bytes. To be more appropriate, as a manufacturer considers that a Megabyte equals 1 million bytes or 1024 * 1024 bytes, a key of 512 MB can display 512 000 000 bytes or 488 481 250 bytes.
May 14, 2010 | PNY USB SmartMedia Reader PC (SFRUSBWB)
Je veux savoir les caracteristiques de mon pc
Merci pour votre demande.
Voila les details demander
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} desktop
i
OLIVETTI OLIVETTI
OLIVETTI DESKTOP AD200N-1245 OLIVETTI DESKTOP AD200N-1245
Processeur Intel® Pentium® Dual Core E2180 (2x 2.00 GHz, 1 Mo L2 cache), Chipset VIA® PM900, Mémoire DDR2 1024 Mo, Disque Dur SATA 160 Go Intel ® Pentium ® Dual Core E2180 (2x 2.00 GHz, 1 MB L2 cache) Chipset VIA ® PM900, DDR2 1024MB, HDD 160GB SATA
Prix public : 6100DHS Retail price: 6100DHS
OLIVETTI DESKTOP AD200N-1210 OLIVETTI DESKTOP AD200N-1210 Processeur Intel® Celeron® 420 (Core 1.60 GHz, 512 Ko L2 cache), Chipset VIA® PM900, Mémoire DDR2 512 Mo, Disque Dur ATA 80 Go Intel ® Celeron ® 420 (Core 1.60 GHz, 512 KB L2 cache) Chipset VIA ® PM900, DDR2 512MB, HDD 80GB ATA
Oct 19, 2009 | Computers & Internet
How do I format my 512 data traveler. When I connect, it shows available and used as 0
you first open ms dos
then go to drive by command like cd (then drive name)
and then format (drive name)
when it is format it works properly
Jun 30, 2009 | Kingston (SDCZ2-512-A10-KT)...
My usb was suddenly says used capacity 0 bytes,free 0 bytes,FILE SYSTEM raw.Cannot be formated.it says insert flash drive.give me the best solution.
Jun 05, 2009 | PNY USB SmartMedia Reader PC (SFRUSBWB)
Motherboard processor support
Processor Family Processor Speed System Bus Frequency Cache Size BIOS Version Notes Pentium® III processor 850 MHz 100 MHz 256 KB P14 or greater The following board revisions (AA numbers) support these processors: 754552-200 or later
754558-200 or later
A01450-200 or later.
See the board revision note, below, for an explanation.
800 MHz 100 MHz 256 KB P14 or greater 750 MHz 100 MHz 256 KB P14 or greater 700 MHz 100 MHz 256 KB P14 or greater 650 MHz 100 MHz 256 KB P14 or greater 600E MHz 100 MHz 256 KB P14 or greater 550E MHz 100 MHz 256 KB P14 or greater 600 MHz 100 MHz 512 KB P12 or greater All board revisions support these processors 550 MHz 100 MHz 512 KB P07 or greater 500 MHz 100 MHz 512 KB P07 or greater 450 MHz 100 MHz 512 KB P07 or greater Pentium® II processor 450 MHz 100 MHz 512 KB P01 or greater 400 MHz 100 MHz 512 KB P01 or greater 350 MHz 100 MHz 512 KB P01 or greater 333 MHz 66 MHz 512 KB P01 or greater 300 MHz 66 MHz 512 KB P01 or greater 266 MHz 66 MHz 512 KB P01 or greater 233 MHz 66 MHz 512 KB P01 or greater Intel® Celeron® processor 433 MHz 66 MHz 128 KB P01 or greater 400 MHz 66 MHz 128 KB P01 or greater 366 MHz 66 MHz 128 KB P01 or greater 333 MHz 66 MHz 128 KB P01 or greater 300A MHz 66 MHz 128 KB P01 or greater 300 MHz 66 MHz 0 KB P01 or greater 266 MHz 66 MHz 0 KB P01 or greateri hope that this solved your request.
Sergio
Mar 13, 2008 | Intel Desktop Board SE440BX-2 Motherboard
1 gb usb
Hi
You need a format your USB drive!!!
Plug in USB drive and in MY COMPUTER right click on the USB drive!!! Select format and that will do it!!!
Good luck!!
Jan 29, 2008 | Kingston (SDCZ2-512-A10-KT)...
Data transfer.....
Hi, For formatting, you can try HP Drive Key Boot Utility. Do a google of cp006049.exe (HP USB FlashDrive), download and install. This utility has worked for most if not all types of flashdisk. Good luck and kind regards.
Sep 28, 2007 | Kingston (SDCZ2-512-A10-KT)...
Usb mp3 player
You have to thow it away. Sorry. But the storage on your MP3 player is corrupt. This happens alot with USB devices.. Specially Thumbrives and mp3 players.
Apr 20, 2007 | TwinMOS Technologies MP3 USB S21 256 Mb...
Computers & Internet Logo
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
