Question about Schwinn Cycling
The resistance on my schwinn srb-1500 just stopped working. The bike is in perfect condition and the computer console seems to be working fine. (I've replaced the batteries) The tension appears to adjust on the screen, but nothing in the resistance with the pedals
  • 31 Answers
SOURCE: The tension adjustment does not get difficult enough
If you are refering to a regular bicycle this means the derailer is not making the chain jump from gear to gear. You probably need a new shifter cable or the shifter cable came unhooked from the derailer. I would take your bike to a bike shop to have this reconnected and then they will adjust it for you.
If you are refering to an exercise bike then here may be your solution. From what I have seen on exercise bikes there are three different kind of bikes. I am refering to how there resistance works.
First type has a strap that wraps around the wheel. There is a some kind of a nut and a bolt that holds that strap around the wheel. You simply need to tighten that nut. The strap will stretch over time and that is why you do not have the same resisteace you had when the bike was new. Afer you tighten this you will find that regular tensioner works better.
The Second type of exercise bike has what appears to be brake pads contacting the wheel. Basically your peddaling the bike with the brakes on. Pretty simple concept. Again there should be some sort of adjustment around this pad that is touching the wheel. Probably a screw or a bolt. Some even have adjusters that you can turn with your fingers.
The new and improved exercise bikes have what is called magnetic resistance. This is where your resitance is created by a magnet and some sort of power source such as batteries or your bike being plugged into a wall outlet. If you are using batteries replace them. I found that with my elyptical exerciser new batteries made a world of difference in the resistance settings. If changing the batteries doesn't help then there may be another problem. This could be the computer. Just check your user manual and I am sure you can get it replaced.
Posted on Mar 14, 2009
SOURCE: Schwinn recumbent bike 203 Ac adapter or batteries?
It uses an AC adapter. You can visit:
fitnessrepairparts.com
This is where I am getting the AC parts for my 201.
Posted on Mar 22, 2009
SOURCE: battery missing for exercise bike
I have a Schwinn airdyne (model AD-3) that uses a button type battery in the count-down timer, which is above the work load indicator or the 'speedometer'. According to the manual I was given with the bike, it utilizes a 1 1/2 volt watch - type battery (LR44, A 76 or equivalent).
Hope this helps.
Posted on Apr 23, 2009
  • 108 Answers
SOURCE: No resistance when I pedal the stationary exercise bike
I looked into this thinking is must be a simple belt, or tention wheel, but these devices are much more complex than the average exercise machine. See the Recumbent selection here.
It appears that the tentioning device is a magnetic brake.
This would require that it be plugged into a power source and programmed to provide a desired tention.
I've never used one of these so I can't say what kind of programming options there are or where they are found.
Hope this helps.
Richard.
Posted on Dec 07, 2009
SOURCE: the resistance belt on my Schwinn 205p recumbent
http://www.fitnessrepairparts.com/equipment/SelectEquipment/100 lists all the parts for this model
Posted on Jan 03, 2010
Does the schwinn recumbent 270 bike have a battery? It has an AC adaptor. The resistance will not increase when i press the higher resistance button.
It does not have a battery. Your resistance motor is most likely faulty. The only thing is, with schwinn, you will most likely have to replace the resistance motor, the console, and the wiring. All of this is very hard to find and will probably be more of a hassle than it's worth.
Jun 10, 2017 | Schwinn Exercise & Fitness
Need owners manual for schwinn SRB-1500 recombenant bike
Try Schwinn.com, or ebay, search by model number
Oct 24, 2014 | Cycling
Console says I am not pedaling when I am, no resistance, then it shuts off
Seem like you have a sensor problem. Open up the bike and check to see if your sensor is aligned properly. Check your sensor magnet. Get parts at www.treadmilldoctor.com or usedtreadmillrepairparts.com
Dec 30, 2013 | Schwinn Exercise & Fitness
Schwinn recumbent srb 1800
usually means faulty console .
Nov 07, 2013 | Exercise & Fitness
My schwinn 240 recumbent bike shows E-3 on console. the magnet is stuck to the flywheel and won't come off. i've tried adjusting the resistance on the console, unplugged the brake sensor cable, etc. how...
Hello, do you have a manual or electric resistance control? The manual one has a return spring, the electric on has a resistance motor that could be bad.
Feb 05, 2011 | Schwinn Exercise & Fitness
Schwinn SRB 1500 no resistance when peddling
just make sure that all the nuts and bolts are tight otherwise replace the cord which might have lost its strength and may have become elastic.
Jul 20, 2009 | Exercise & Fitness
Cycling Logo
347 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
michael
michael
Jim Goldsmith
Jim Goldsmith
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
