Question about Toshiba 500 GB Portable External E05A050DAU2XM (Blue) Hard Drive
I have a Mac OS X v. 10.4.11 computer. The notation on the outside of the packaging states that the portable hard drive must be reformatted for this computer. How is this done? Thanks.
  • 3,530 Answers
Welcome to Fixya
Here's the procedure on how to format the portable HD using Mac OS X.
Insert your USB portable drive. Run the disk utility of software of your MAC. It opens in default, with no drives selected in the left hand column. If you will look at the tabs near the top of the Disk Utility window (red box below), you will notice that the tab 'Partitioning' is not available as it was in Tiger. Select the hard drive that you wish to partition in the left hand column. Once you have select a hard drive to partition, the Partition tab will now appear along with the other tabs near the top of the window. In the Partition tab, my Disk Utility is shown below. You will note that both the Name and Format sections are grayed out, (red box below). This is because the drive that I have selected has already been named and formatted and is currently in use. These option will become available once we have set the new partition scheme. Also note that the "Mac OS 9 Drivers Installed" box is checked. Unless you have a specific need for OS 9 drivers, leave this box unchecked. In the Partition tab select the number of partitions that you want from the 'Volume Scheme' drop-down menu. Once you have set the number of partitions in the Volume Scheme' drop-down, select one of the partitions. When a partition is selected, you will notice that both Name and Format, have now become available for this partition. Name your partition and then select your format. You'll want Mac OS Extended (Journaled) for a partition that you will want to serve as a boot (start-up) volume. Select Mac OS Extended (No Journaling) for volumes that will be used as media or data storage drives. You can change the alloted size of the partitions by dragging the little button found between the the partitions in the Volume Scheme section, up or down. Select each partition and then name and set the format. When you are done, click on the 'Apply' button.
Thank you for using Fixya!
Posted on May 23, 2011
How to replace solid state hard drive on imac computer
Hi Felix
Pretty simple really.... once you get the iMac opened!
See below
Simply find the existing hard drive, disconnect and slip it out.
You might have to remove a couple of screw in locating studs from the old drive and add to the new drive.
The connectors should match up with the existing cable.
Called SATA (Serial ATA)
The temperature sensor is stuck to the outside of the drive, carefully peel it off and stick it on the new drive.
Use Carbon Copy Cloner (CCC) to make a clone copy of your existing drive or install a new OS X (Downloadt off Apple Site)
Good Luck
I'll assume you know that Maverics, Yosemite OS X are free to download. And the latest El Capitan is due in Days.
Resources:
Mac Backup Software
intel iMac HD install
Sep 17, 2015 | Apple iMac 24" Desktop
I want to use in my mac osx mac book pro
Hi Carmen; just plug it in to your system's USB port and format it for use with a mac os according to the provided instructions.
According to the manufacturer: Mac:
  • Built-in USB
  • Mac OS X 10.4 - 10.6
  • 128MB RAM
  • Drive must be reformatted for use with Mac (instructions included)
Mar 19, 2015 | Iomega 500GB Prestige USB 3.0 Portable...
I have purchased a toshiba 500GB Go portable hard drive to back up my Mac snow leopard, requires reformatting how do I reformat?
If you are using a mac go into applications then utilities and run i believe its called disk utility and you can use that utility to format the hdd
May 12, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
My Western Digital 520 MB portable hard drive is not showing up on my mac. I see its white light blipping constantly but it is not appearing on my computer. It worked a few times the past few days but it...
Try reformatting the drive. In Mac OSX go to the utilities Folder open up Disk Utility. In left hand window of the page you will see your drive. Highlight it. At top of page click on Erase. In Format drop down window select Mac OS Extended (Journaled). In window below format give your disk a name. At bottom of page click Erase.
After you have erased and reformatted click on First Aid at top of page. In First Aid highlight your disc and click on Repair Disc at bottom right hand of page. after Disc Repair try using it again and see if that works.
If it doesn't work repeat the above steps And if the doesn't work try another disc or go for a long walk and breath deeply.
Aug 30, 2010 | Western Digital My Book Home Edition 500...
I bought a Verbatim Clon USB Portable HardDrive to back up files from my Mac Computer. When I click and drag, I get this pop up " items can't be move because verbatim can't be modified." It says the hard...
You have to partition your Verbatim Drive to work on a Mac. Go to Macintosh HD / Applications / Utilities / Disk Utility. When in Disk Utility select the 232.9 GB SAMSUNG HM250HI Media to the left.
Dec 19, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
Mac OS X 10.4.11 SimpleDrive 1TB HD appears on Desktop only occasionally. Does not appear in Disk Utility. Have transferred files to it, light is on, plugged in, just takes several restarts to appear.
If you unplug the power and USB cables from the drive (but not the computer), plug in the power and then plug in the drive, the Mac will remount the drive on the desktop. I am having the same issue, only my old HDD used to be my TimeMachine drive and now I want my SimpleTech drive for that. The issue is that when the SimpleTech drive disappears, OS X automatically uses my old HDD for TimeMachine and all my disk space vanishes.
Very ARRGH!!!
I'm trying to find a better solution, because having to mess with the cables means it's no good for TimeMachine... and very frustrating on top of it.
Aug 12, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
Reformatting external Hard Drive
click on the hard drive and use the disc manager to format
or right click on the hard drive properties and use the format tab
May 11, 2017 | Maxtor BASICS Personal Storage 3200...
Seagate free agent go 250 gb external / macbook pro os x tiger
If you can see the drive in Applications --> utilities --> Disk Utility, then you will be able to reformat it in the Mac OS format and read it.
Good day, Damien
Dec 24, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
DOES THE VERBATIM HARD DRIVE NEED TO BE FORMATED?
Many Verbatim hard drive models with a FireWire interface come “Mac formatted” – pre-formatted for immediate use with Apple Macintosh computers running Mac OS. They are formatted as HFS+, the preferred format when using the drive exclusively with Mac OS computers.
Note: A Mac-formatted drive will not mount on a Windows PC.
If you plan to use a Mac-formatted hard drive only with computers running Mac OS, you can leave it formatted as it comes from the factory. However, if you plan to use your hard drive with computers running Windows, or with both Mac OS and Windows computers, you should reformat your Verbatim hard drive before saving data to it. Generally, for use with both Mac OS and Windows you should format to FAT32, and for use strictly with Windows you should format to NTFS. More information about these two format types is given below.
FAT32 FAT32 is compatible with the following Windows operating systems: Windows 98, Windows 98 SE, Windows Me, Windows 2000, Windows XP, Windows Vista. FAT32 can also be read by Apple Macintosh computers running Mac OS.
Limitations: Maximum file size is limited to 4TB. Furthermore, using the formatting tools included with Windows 2000, Windows XP, and Windows Vista users will not be able to create partition sizes larger than 32GB (though they can access these larger partitions). This limitation does not apply to other supported operating systems. Furthermore, Verbatim provides a FAT32 format utility (see further below for download instructions) that eliminates the 32GB partition limitation.
FAT32 is a good choice if you’ll be using your Verbatim hard drive with older computers running Windows 98, Windows 98 SE, or Windows Me, or if you’ll be using it with both Windows and Mac OS computers.
NTFS NTFS is compatible with the following Windows operating systems: Windows NT, Windows 2000, Windows XP and Windows Vista. NTFS usually results in higher performance than FAT32, and will permit users to create partition sizes larger than 32GB, and file sizes larger than 4TB.
Limitations: NTFS is not compatible with Windows 98, Windows 98 SE, Windows Me, or Apple Macintosh computers running Mac OS.
NTFS is a good choice if you will be using your Verbatim hard drive only with one or more computers running Windows XP, Windows 2000 or Windows Vista. This is also a good choice if you plan to store files larger than 4TB, such as digital video files.
Per: http://www.verbatim.com/downloads/format.cfm
Good Luck
cbinny1
Oct 20, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Acomdata Portable Hard Drive
I upgraded from Mac OS 9.1 to Mac OS10.5 and the new system will not read my hard drive. Can you help?
May 06, 2008 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Toshiba 500 GB Portable External E05A050DAU2XM (Blue) Hard Drive Logo
82 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
