Question about Samson dB300A 2 Way Powered PA Speaker, 300 Watts
Hi, I have a samson db300a that isn't working. I've tested the speaker and the input circuit and both of these are fine (tested by unplugging them from the main board and plugging them into another db300a's board/speaker etc) and have limited the problem to the main board though nothing appears loose, burnt or broken in any way. Should I just get a replacement board?
2 Suggested Answers
  • 140 Answers
SOURCE: Hello. Is it possible to
I am working on getting your schematic. Hang in there, it may take a couple of days.
Posted on Nov 23, 2010
My Zoom R16 wont turn on
Hi , i have the same problem, did you fix the problem already ?
Jan 06, 2013 | Samson Technology Zoom R16 Recorder /...
I'm using the Peavey XR 8600 with two EV Force i 25 speakers. My question is this, what is the difference between the two outputs on the Peavey? I naturally assumed one was left and one was right....
DO NOT parallel more than two 8 ohm speakers on either output and you will be OK. You could also use one speaker on each output. That would be easier on the equipment as it would be an 8 ohm load on each instead of a 4 ohm load on one of the internal amps. If you want to drive stage minitors, then you existing setup is fine and you will connect the monitors to the second speaker output and set the Mon switch as MAIN/MON.
Aug 23, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Hi, I have one Samson Auro d412a active speaker plugged into the output channel of a 12 channel passive mixing board. When I sing into the mic, the speaker shuts down and the red light on the back...
If you read the TRUE specs on this speaker it is really a 200 Watt RMS unit. Make sure you are using balanced lines to the speaker XLR or TRS cables. The mixer should NOT be a passive mixer as these do NOT generate true balanced lines. Make sure the mic can't "hear" the speaker or you may be getting supersonic feedback that is above your hearing range that saturates the amp. If *********** can't stand to be ain a 15 foot square room with teh level you are generating, it is TOO loud for this unit to handle.
Aug 01, 2011 | Samson Auro D412A Speaker PA Active
I bought a samson co1 studio condenser with a lexicon alpha desktop recording studio. the mic doesn't seem to work. what i thought is that maybe because it is self-powered. im not sure. i need...
The problem is the PC thinks the Mic is attached to the Alpha rather than through the USB directly.
The Alpha software probably ALSO assumes this. Look in the "Sounds and Devices" page of the control panel and check to make sure the appropriate device is selected for voice input. If you don't see the Mic selected, select it, and if it isn't in the list, then it needs a driver installed or activated. Often the PC's audio system wants to "fight" this and it takes some "persuasion" to get it to cooperate.
Apr 16, 2011 | Samson CO1/SR850 MICROPH./HEADPHONES SET
Samson dB300A 2 Way Powered PA Speaker, 300 Watts Logo
Top Samson Music Experts
Matthew Spark
Matthew Spark
Vito Vacirca Jr.
ray gallant
Are you a Samson Music Expert? Answer questions, earn points and help others
