Question about KitchenAid KSRG22FKSS Side by Side Refrigerator
Model KSRG22 -2001 side by side model- the ice crusher and dispenser does not dispense ice or crushed ice. It makes a motor sound when the door lever is pushed but nothing comes out. The ice bin has fresh ice and there is nothing blocking the bottom of the ice bin that I could see. What is not working? Can I fix it or do I need a repair person?
aborcass
  • 2651 Answers
SOURCE: ice won't dispense, no power to water light
I would check hte wire harness leadngto the door under hte freezer hinge. itll be wrapped in a black web like covering. Just under hte unit itself follow ht ewire and unplug hte harness. then carfully cut hte black webbing and inspect wires. there tends ot be apinch point there and the wires will sheer from one another, . if so there is no replcing hte harness, the door would have to be replaced at a cost of nealry $600. not enough room for a wire nut, but hav had sucess using stright inline bullet style connector, or others have sucessfully soldered connections back in place
Posted on Mar 25, 2008
Richie_asg1
  • 1036 Answers
SOURCE: ice dispenser in door clogged up or frozen
I would contact Hotpoint direct for this one. It sounds like a design fault to me.
What I think may be going on is that the cubes are melting too much, then refreezing lower down.
Set your freezer to -18, and the fridge to +2 and see if that changes things any.
Check seals in that area. Where is the moisture coming from to generate the frosting? - Is the location high in humidity?
Posted on Jun 11, 2008
ghappliances
  • 126 Answers
SOURCE: kitchenaid side by side model ksrs25ikss01
CHECK YOU SECOND VALVE IS WORKING IF THATS OK YOU MIGHT NEED YOUR ICE MAKER CHECKED AND SERVICED.GOODLUCK.MOHAMED
Posted on Sep 12, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
jumptrout51
  • 3361 Answers
SOURCE: ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
Posted on Mar 23, 2009
Hello! I have a Whirlpool side by side Gold series fridge. About 3 yrs old. The ice crusher and dispenser stopped working. There is a sound when you push the button to dispenser or crush, but nothing else....
Any of the ice crusher models have had trouble. The chips get into the mechnism and then freezes it up. Suggest you defrost the unit manually (NOT WITH WATER) and then try it.
Jun 08, 2011 | Refrigerators
I have a GE Profile refrigerator, Model PFSS6PKWBSS, with icemaker on door. Water is collecting under Deli-draw and leaking down freezer door onto floor. How do I fix leak?
Hi
Try and access the ice dispenser assembly and check from where the water is leaking. You would need to disassemble the ice dispenser and ice maker to check this. The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
1. Remove the upper ice bucket tray.
2. Slide out the ice dispenser assembly.
3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either side of the ice crusher.
7. Lift the ice crusher out of the bucket.
8. Remove the ice crusher back cover.
9. Remove the locking ring from the ice crusher auger.
10. Remove the plastic nut with a pair of pliers by turning it clockwise.
11. Remove the spacers and blades. The blades are numbered for reassembly.
Icemaker--
The icemaker is located in the upper rear of the freezer compartment and supplies ice to the dispenser tub.
1. Disconnect the icemaker cable connector.
2. Remove 1/4-in. icemaker mounting screws and slide out the icemaker.
This refrigerator is equipped with an Electronic Icemaker.
Hope this helps... Please post back if you need more information.
Daniel
May 01, 2011 | Refrigerators
I have a Kenmore side by side, not sure the model, but it's probably 10 years old or so. It has an ice maker with water, cube and crushed ice dispenser. The ice maker works fine, but it will not dispense...
Most of the time the bin has been removed and not put back in properly. When this happens ice blocks the drive motor. Remove the bin and turn the auger by hand make sure it will turn and is not jammed. Now with the bin out push the light button in that turns the light out and have someone push the button for ice while the door is still open the motor should turn in the back make sure thereis no ice blocking it. If it turns nothing is wrong with the motor. The clicking sound is usually the motor jammed by ice or the auger not engaged on the motor. hope this helps good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
MODEL FFS26ZRG THE ICE CRUSHER CHURUSHES THE ICE
there might be something in between the door and the ice crusher. If you could check what it is, would be good otherwise call in a repairman to work on this problem.
Jun 11, 2010 | Frigidaire FRS3R5EMB Side by Side...
Ge gss fridge,ice dispenser problem.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. The crush position is without the solenoid energized. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Your solenoid is part 45 and the linkage to the crusher is 46. The crusher is 41 on this diagram and parts list. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5150332&diagram_id=1239793#d1239793
Feb 28, 2010 | Frigidaire FRS3R5EMB Side by Side...
Makes ice fine but doesnt dispense
Sounds like the dispenser auger is frozen up or stuck. The lights dimming happens because the voltage drop from the stuck auger's motor when you try to use it. Remove the ice machine and clean it. Do not try to take it apart!
Sometimes, the ice machine will fill too much with water and get stuck. Often, it's because the cabinet isn't level.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice crusher don't work
Hi, It sounds like the selonoid that shifts the auger is not working. This part is located behind the panel that the bucket pushes against. The little wire arm on the bucket goes into this. Sometimes they just get froze up from the moister. If you remove the panel/section the selonoid is in, you can see if the part has went bad.
I hope this helps you. Please let me know If I can assist you further.
Vic
May 23, 2009 | Maytag MSD2650H Side by Side Refrigerator
Ice crusher has stopped crushing
Replace the switch behind the front panel on the freezer.
Mar 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Icemaker makes ice; door dispenser cranks, but no ice dispensed
sounds like either the dispenser motor is bad or the dispenser yoke is stripped. remove the bucket from the freezer. you will see a u shaped yoke in the rear of the disp area. this should be fairly hard to turn by hand if it turns easily then the motor gears are bad if the yoke slips on the motor shaft then you have a stripped yoke. hope that helps. peyton...
Jan 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
NO ICE AND IS MAKING FUNNY NOISE
I also have the same model as you. My problem with the ice maker has been build-up of ice under the cube pan which holds the crusher and cubes. ( I pulled the pan out and cleaned up the ice, pushed and re-seated the pan against the back of the freezer where it connects into the crusher motor). In a day or 2 it was working fine again. I got this problem because my son was pullying the pan out and emptying all the ice-cubes into his cooler for his bottles of water and soda., He was not pushing the pan back far enough to seat into the motor of the crusher and this left room for the ice to accumulate under the pan and pushing it forward away from the crusher motor which makes a loud noise when the pan is not seated correctly. There is another problem I had because the freezer was opened to often. The door dispenser became warm and the crushed ice accumulated in the dispenser and froze there, so if I opened the door, ice-cubes would fall out of the pan all over the floor. Also check the back of the pan where the crusher connects to the motor, mine was full of frozen moisture turned to ice which kept the crusher from seating properly. If this is not your problem then I would call a repairman as doing it yourself can be expensive because you may buy a part and then find out the old one was ok and it still doesn't work. Ice maker parts are very expensive .If you are positive that you know what is wrong then by all means fix-it. Also check your frozen food if it is frozen solid or soft, you may have a completely different problem than the ice-maker. Hope I helped some.
                                                     Jerry
Sep 06, 2007 | Samsung RS2630SH Side by Side Refrigerator
KitchenAid KSRG22FKSS Side by Side Refrigerator Logo
134 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
