Question about Thetford Porta Potti
C4 cassette manual flush not working. is bellows prob likely?how can i replace it?
Grohe dual fush push button
hey,
If you can get a new bellows this is possible.Repairing a bellows is also possible if you have the skills and tools to hot-air solder it.
Look at this guide that might help you. though it is not the exact model, principle is the same.
Have fun
Avi
Grohe GD2 flush system concealed cistern repair fix and disassembly...
Dec 11, 2012 | Grohe 38 771 000 Eau2 Dual Flush Air...
My ac keeps showing up a code :c4. is still blowing air but not cold?
c4 SplitVRV ac unit, ceiling mounted cassettes, Sensor misplaced. Please find sensor and keep it right place. Thanks.
Feb 04, 2011 | Heating & Cooling
We have a thetford C200cs on the motorhome we have just bought (2003). No water seems to pump, & the blue flush button doesn't seem to work. Are there any instructions availabe? The fuse has been...
Red light is just a reed switch that turns on the LED when a floating magnet inside the cassette floats up (when the cassette is full) and switches on the reed switch thereby switching on the LED. It just tells you the cassette is full and you need to empty it.
I'd say either your button or electric valve is broken. All the button does is allow the electric valve to break the seal that allows water to flow from your onboard water system.
I'll assume that the water in the rest of your motorhome is working?
So check the switch first.
You can lever off the switch/LED panel and remove the square connector from the back of the button. Get a multimeter and set it to either Continuity or Resistance (Ohms). Place the connectors on 2 of the switch pins and press the switch (the switch is actually 2 switches with 4 pins, but each pair of pins is connected together) - if you get a beep (if multimeter on continuity) or low resistance reading (if on resistance) then the switch is working - if this is the case then it's probably the electric valve. If the switch is not working, then that's your culprit.
When you replace the connecter you can replace it either way round.
Feb 01, 2010 | Thetford Porta Potti
My car is running hot do u think i need to change the motor?
buy a radiator flush kit, some prestone flush additive, and even maybe a new thermostat, and a simple haynes manual for your auto. The manual will tell you where and how to change the thermostat, and how to drain the radiator, and how much radiator fluid you will need. The flush kit will instruct you where to put the flush fitting.
Remove the thermo, flush the motor, install new thermo and gasket. Add radiator fluid, done. This should solve your over heating probs. Don't let it over heat! You can cause major probs then.
You could always take it to a shop and pay the $200 to do it for you. My way would cost you less than $50.
please click yes if this helps. thanks
Jan 22, 2010 | 1999 Mercury Cougar
Cassette playback
Hi, I am brand new to this site. So I may not be very good. However your prob sounds like one I had a few years back. I solved mine by using two pencils, one in each hub.
Then winding manually from one to the other. This is quite time consuming, but it worked for me. Hope this helps, if not, sorry for wasting your time.
Jun 17, 2008 | Teac Audio Players & Recorders
How to replace the door bellows seal ?
I need some one to tell me how to install the rubber seal on a bosch maxx Eurowasher front loader washing machine. Part of the seal ripped off so water leaks out. Its only 6 months old and its not covered by warranty.
Jan 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code c4
sensar mis placed
Dec 20, 2007 | Heating & Cooling
Thetford Porta Potti  Logo
53 people viewed this question
Top Thetford Camping, Backpacking & Hiking Experts
Patricia Cross
Level 1 Expert
Fredrik Str?hle
Fredrik Str?hle
Level 1 Expert
Tony
Are you a Thetford Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
