Question about Vacuums
Heating element broken on elna press opal. how can i find someone local to fix it please
Bissell Proheat Clearview Force won't produce steam
Either the electrical connection to the water-heating element are corroded or broken. Worse, the element itself my be dead/non-functioning. You would have to dis-assemble the machine to find out what can be repaired or replaced.
Oct 14, 2013 | Bissell Vacuums
I have been given an Elna 614DE overlocker but it is missing the accessory box and accesories, can u please advise where I may be able to buy one
I would Google the model number or first search on Ebay for this set of wands or tools. I bet someone has them on Ebay.
Nov 03, 2012 | Vacuums
How do I diagnose the heating element for a shark steam mop
please go to http://www.sharkclean.com/products/shark-pro-steam-pocket-mop-s3601/support/how-to-videos.shtml and see the video for better troubleshooting and fix it.
However , if the system has heating element you must use the VOM for test continuity, if they donot the heating is faulty.
God bless you
Jul 22, 2012 | Vacuums
Where can I get my Elna machine fixed? It is quite an old model and the zigzag function is broken. I am in the Toronto Downtown region.
Here is the email address for Great Western Sewing Machine Services in Toronto: brian@gwsms.com
He was the service manager for Elna, Toronto for many years.
Also, Norm Sewing Machine provides on-site servicing. Here is there phone: 416-993-4466
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 06, 2011 | Vacuums
I purchased a Seal-A-Meal roll to make my own bags but can't figure out how to use it. I have a model VS108. Is it possible to seal without vacuuming?
On most models of vacuum sealing systems, you cut off the roll the size of bag you need. Slip one open end of the bag just on top of the heating element over it about 1/8-1/4" and press down the lid to seal the bottom of the bag. Fill the bag and then place the open end far enough into the vacuum cavity over the heating element and close the lid and press down and hold until the cycle finishes. If you don't want a vacuum, just put enough bag material to cover the heating element but not into the vacuum cavity. Hope this helps
Jan 03, 2011 | Vacuums
I have a Shark Steam Mop S3501CO model. When I press the release button to exchange mop heads, the mop head does not release. Nils Friis
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
That head can stick very tight...get someone to hold the head and you pull the mop...
The heating element may have died or there is an obstruction...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
Aug 02, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
DZ9080 IRON IS NOT VERY OLD, BUT HAS HEATING AND STEAMING PROBLEMS. IT MAY BE ALL HEATING RELATED! MY WIFE WILL SOMETIMES JUST LEAVE IT "ON" FOR TWO HOURS AND THEN IT WILL START STEAMING AGAIN. I CANNOT...
I couldn't find any warranty information on this iron, but I suspect that the heating element either has a faulty connection or part of it has cracked, making contact at time, but poor contact at other times. The unit will have to be taken apart and inspected and troubleshot, and that's why I was inquiring about the warranty. Someone in a review of them said that their website and 800 number weren't working, so you might try to refer to your manual that came with it for support. Another person who uses them regularly said they just last for about 3 years before needing to be replaced. If the warranty isn't valid for you, I would disassemble it and try to see if an electrical connection to the element is cracked, perhaps, or has heat damage, then try to secure it. If the element's cracked or damaged by heat, it will need to be replaced. There's a chance the control unit's faulty, and any fix could run into some money. If you do have it serviced, get an estimate first. Sometimes it's just better to bite the bullet and get a new one. Good luck, and hope this helps.
Jun 25, 2010 | Rowenta Vacuums
Vacuums Logo
44 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
