White line through printing about 30mm apart when in draft text & text/pictures ok on photos [both settings] have cleaned heads but still problem exists
HP Officejet Pro L 7680 All in one printer prints with a white line running horizontally through all the letters.
Can anyone help?
Thank You,
Alfred F. Marton
marton@san.rr.com
Posted on Dec 04, 2008
How to fix the white lines on my prints
Print a test pattern to see if that is good. If so, then you are probably printing in draft mode. Simple select text and photos in printer properties and that should take care of it,
Sep 07, 2014 | Epson Stylus Photo 810 InkJet Printer
Lots of tiny white horizontal lines on the printed picture.
Run a nozzle check. If there are gaps do head cleaning. When printing pictures it best to set the setting to best photo to get good print outs.
Goodluck.
Jul 15, 2010 | Epson Stylus Photo 1290 InkJet Printer
Toubleshooting and routine maintainance is what comes oout on myscreen
Found this on the web. Click on link below to print the entire manual out to keep. Below are steps to do cleaning. If you find this helpful pls rate me. Thanks and Good Luck.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
How to improve print quality Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print head. You can start the cleaning process manually if needed. Clean the print head and ink cartridges if you get a horizontal line in the text or graphics on your printed pages. You can clean Black only or three colors at a time (Cyan/Yellow/Magenta), or all four colors at once.
Cleaning the print head consumes ink. Cleaning too often uses ink unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press or to select Cleaning.
Press Menu/Set.
3 Press or to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished, the MFC will go back to standby mode automatically. If you clean the print head at least five times and the print has not improved, call Brother Customer Service (see Brother numbers on page i).
Checking the print quality
If faded or streaked colors and text appears on your output, some of the nozzles may be clogged. You can check this by printing the Print Quality Check Sheet and looking at the nozzle check pattern.
1 Press Ink.
2 Press or to select Test Print.
Press Menu/Set.
3 Press or to select Print Quality.
Press Menu/Set.
4 Press Color Start.
The MFC begins printing the Print Quality Check Sheet.
5 Check the sheet to see if the quality is OK by following these steps:
Color block quality check
The LCD shows:
6 Check the quality of the four color blocks on the sheet.
7 If all lines are clear and visible, press 1 (Yes), and go to Step 10.
OR
If you can see missing short lines as shown below, press 2 (No).
The LCD will ask you if the print quality is OK for black and three colors.
OK Poor
Is Quality OK?
1.Yes 2.No
Black OK?
1.Yes 2.N
8 Press 2 (No) for Black or three colors
with a problem.
The LCD shows:
Press 1 (Yes). The MFC will start cleaning the print head.
9 After cleaning is finished, press Color Start. The MFC will start
printing the Print Quality Check Sheet again and then return to
step 5.
10 Press Stop/Exit.
Jan 14, 2010 | Brother MFC 210C All-In-One InkJet Printer
Cannot print keeps saying clean printer cannot find info to do it
Caution
1 Press Ink.
Press Menu/Set.
Press Menu/Set.
1 Press Ink.
Press Menu/Set.
Press Menu/Set.
The LCD shows:
OR
OK Poor
Is Quality OK?
1.Yes 2.No
Black OK?
1.Yes 2.N
with a problem.
The LCD shows:
step 5.
10 Press Stop/Exit.
There is more, but too long to put here.
Jan 13, 2010 | Brother MFC 210C All-In-One InkJet Printer
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
Kodak ESP 5 runs out of ink after about 40 pages of standard text black & white documents. Also the color ink level is dropping, but no color is being used (the printer is set for black & white...
As far as the quantity of black & white - to get more out of it - go to start menu.. Click on on settings,, then printers,, Right click on the ESP 5,, click on printing preferences,, then clcik on draft,, then click on (at the top) advanced,, click on black & white.. Then click on apply then ok..
Now - every time you print it will be in this mode.. If you want to print in color - you will have to choose that each time..
For you black & white docs - this will print faster & use allot less ink..
As far as your color issue & puddling - It could be the printer head.. If it is new enough - call Kodak & maybe get a replacement.. If to old - maybe keep the color cartrige out and caped with the plastic caps until you need to print color.. Snap it in & out as needed..
I hope this helped..
Jun 11, 2009 | Kodak ESP 5 Printer
Vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Vertical lines through my text and photos
Either clean the print head nozzles or select a higher print quality and turn off High Speed mode.
Jan 04, 2009 | Epson Stylus Photo R300 InkJet Printer
Blure text
three options to be checkout. 1)the cartridge ink is near to empty.if this is the case  get your cartridge refilled or replace it with new. 2)the head unit in which the cartridges r installed.in that head the holes from where the ink comes out may be blocked so it needs cleaning manually by removing the head. 3)or the third option the printout is set on draft mode .if this is the case go to printer properties and change that draft setting to normal mode printing.
Nov 30, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Lines on pics
Could be either or Both.
1:) Clean the print heads, using the printer toolbox et,c.
2:) Check the head alignment.
3:) check the printer rollers are in good condition.
4:) check the printers general settings, to ensure the settings are correct. paper type. print quality ( Draft-Text-Photo et,c )
Mike @ Compurepair.
Jun 22, 2008 | HP PhotoSmart 7760 InkJet Printer
870 people viewed this question
jasbo
jasbo
