Question about Home Fencing
Guardian garage door opener 21230L. Installed a drive gear assembly, now door is not working properly. Won't respond to remote to open but opens when done manually. Won't reverse direction when remote is pushed.
SOURCE: need a manual for guardian
http://www.vartutechnika.lt/assets//PDF_instrukcijos/pakeliami/B7-21230L.pdf
Posted on Jan 04, 2011
Testimonial: "Many thanks for help, just what I needed!"
  • 126 Answers
SOURCE: My Genie IC250 A garage door opener opens just
Id get back looking at the laser system
Posted on Jan 09, 2011
aquaman987
  • 927 Answers
SOURCE: After programming my cars homelink to the genie
I haven't done this in a while, but I think that you have to program all remotes and the homelink at the same time. I believe that when you reprogram, the opener code changes.
Try this and if it doesn't work, don't accept my answer.
Gary
Posted on Jun 23, 2011
SOURCE: I have a problem with
I have the same problem. Door does not open or close when press the push button and/or transmitter. The light flashes 5 times. Manually open or close the door is ok. On the manual troubleshoot, it says it's either the opener is overheated or it's on vocation mode. I don't know how to switch of vocation mode. Is it possible the thermal sensor is broken?
Can someone help?
Posted on Sep 05, 2011
  • 69 Answers
SOURCE: My guardian garage door opener 21230L isn't opening and shutting when using the remote. It's definitely not the remote, as I detached the red cord to manually open and shut it now I always have to ope
If it makes noise and does not move mechanism, then drive gear(nylon) is stripped.
Posted on Jan 22, 2015
I have a problem with a guardian 21230L garage door opener when you push the button the light flashes but no door movement happens can you help cheers
if your saying that the light on door opener housing is flashing then stopping after a few moments , this is a sign of a fault in door safety's , either the door has to much friction now to move or beam detectors have sensed a problem
Nov 13, 2015 | Building Materials
How do I remove the lens cover for the light on a Guardian garage door opener 21230L?
Not sure about the Guardian, but it should be in the installation manual which can be downloaded, if you don't have the original. On my "Linear" brand, you just have to press the plastic cover at the right place and it releases.
Aug 04, 2015 | Building Materials
Guardian sectional door 21230L opens & closes by itself without any one touching the remotes.
check all the wiring and be sure it is not pierced by a nail or staple
Oct 15, 2014 | Building Materials
Guardian 21230l
Sounds like you need a replacement remote.
Feb 11, 2014 | Garden
Remote won't work but keyless entry does on garage door
If the light in the wall control is flashing press and hold the lock button for 3 seconds. Your remote should now work.
Jul 23, 2012 | Sears Craftsman LiftMaster Chamberlain...
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a problem with a guardian 21230L garage door opener when you push the button the light flashes but no door movement happens can you help cheers Tom
Can someone help?
Jan 28, 2011 | liftmaster Electrical Supplies
Home Fencing Logo
224 people viewed this question
Top Home Fencing Experts
 Russ Hill
Russ Hill
Tom Chichester
ray gallant
Are you a Home Fencing Expert? Answer questions, earn points and help others
