Question about Vehicle Parts & Accessories
NISSAN NATS PROBLEM (I NEED PIN) HI, I have a problem with nats in nissan primera. i need pin for login: vin of car :SJNBFAP11U0594153
2 Suggested Answers
SOURCE: Nissan (NATS) immovilizer 4 PIN code needed for a NIssan Sentra
hi ,i need a pin code to nats...
vin :SJNBFAP11U0594153
NISSAN PRIMERA 2001 1.6
Please Help..
Posted on May 23, 2011
Replaced sterring colum now it wont start
S (Nissan Vehicle Immobilizer System-NATS) has the following immobilizer functions:  Since only NVIS (NATS) ignition keys, whose ID nos. have been registered into the ECM and IMMU of NVIS (NATS), allow the engine to run, operation of a stolen vehicle without a NVIS (NATS) registered key is prevented by NVIS (NATS). That is to say, NVIS (NATS) will immobilize the engine if someone tries to start it without the registered key of NVIS (NATS).  All of the originally supplied ignition key IDs have been NVIS (NATS) registered. If requested by the vehicle owner, a maximum of five key IDs can be registered into the NVIS (NATS) components.  The security indicator lamp blinks when the ignition switch is in "OFF" or "ACC" position. Therefore, NVIS (NATS) warns outsiders that the vehicle is equipped with the system.  When NVIS (NATS) detects trouble, the security indicator lamp lights up while ignition key is in the "ON" position.  NVIS (NATS) trouble diagnoses, system initialization and additional registration for other NVIS (NATS) ignition key IDs must be carried out using CONSULT-II hardware and CONSULT-II NVIS (NATS) software. Regarding the procedures for NVIS (NATS) initialization and NVIS (NATS) ignition key ID registration, refer to CONSULT-II OPERATION MANUAL IVIS/NVIS.  When servicing a malfunction of the NVIS (indicated by lighting up of Security Indicator Lamp) or registering another NVIS ignition key ID no., it is necessary to re-register original key identification. Therefore, be sure to receive ALL KEYS from vehicle owner. System Composition NIEL0174 The immobilizer function of the NVIS (NATS) consists of the following:  NVIS (NATS) ignition key  NVIS (NATS) immobilizer control unit (IMMU) located in the ignition key cylinder  ECM  Security indicator lamp.
ANTI-THEFT SYSTEM ! Did you change KEY'S
Feb 07, 2017 | 2001 Nissan Sentra
Hi people my nissan xerra 2006 is not starting. but the key light on down, and when i try to starting it will not start. please help.
Hi this is a NATS fault you will need someone with diagnostic equipment to check this for you. Regards Jim...
May 07, 2015 | Nissan Cars & Trucks
I have nissan micra K11 with light flasing code
From what I understand it is the Nissan Anti-theft System (NATS) correct ?
The other numbers you show do not correspond to any codes I can find.
The reason the car is not starting is because the Nissan keys MUST be programmed for that car.
Make sure you did not have a new key made and that if you did you have to program it.
Your owners manual will tell you how.
Please elt me know what you find.
Feb 08, 2010 | Nissan Micra Cars & Trucks
I have a 98 nissan primera sri with the factory fitted nats alarm/immobiliser.the mil light is flashing on the instrument panel and the alarm indication light is on when i turn on the ignition.the engine...
your nissan primera nats alarm is connected to the factory fitted stereo. check your stereo fuse as these are the symtoms i have done this before
Sep 17, 2009 | 1998 Nissan 200SX
Please Help..
Aug 07, 2009 | Vehicle Parts & Accessories
04 axima
Yes this could be caused by the Nissan NATS system. Your keys may need to be initilized for the car. Is the SECURITY light on steady, or is it flashing?? Check it. If its steady, than the NATS locked you out and you will not start the car. If its flashing, than NATS should be all set and the car should start. MAke sure, that you are using initilized keys.
Aug 05, 2008 | 2004 Nissan Maxima
04 nissan primera 1.8 radio
you have a nats system fault re-code keys or disconnect battery for 24 hrs
Jan 07, 2008 | Coffee Makers & Espresso Machines
Vehicle Parts & Accessories Logo
51 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
