Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
I have a Craftsman LT1000 with Briggs & Stratton engine model #311707, type #0125-E1. A stick jammed the blade and the flywheel key sheared. I replaced the key and started the engine at idle speed - it ran fine. When I began to increase the throttle the new flywheel key sheared. What should I look at next? Thanks, Ken
  • 2 more comments
  • ken_weave245 May 23, 2011
    Do you know what the torque value is for the flywheel?
  • ken_weave245 May 24, 2011
    Thanks! I hope to reassemble this evening and take it for a test drive. I'll post the results.
  • ken_weave245 May 25, 2011
    Thanks. I'll try it & let you know.
  • ken_weave245 May 31, 2011
    Finally had time over the Holiday weekend to try your suggestion of using some Loctite 660 fastmetal in the keyway. It was the best $12 that I ever spent. Put it back together with a new key & thin coating of Loctite 660 - it runs great. Thanks for the great suggestions.
  • Briggs & Str... Master
  • 5,603 Answers
With no load, the key should NOT have sheared. These are possibilities: The replaced key was the wrong size. It should fit TIGHT with no slop at all and be long enough. A second possibility is that the keyway in either the flywheel or the shaft has been damaged. If the edges have been rolled over that would cause a new key to fail. If the flywheel had not been fully seated that would lead to failure. When re-assembling the unit fully cleaning the taper and the bore of the flywheel AND the keyway is important. A very thin lubricant is needed to insure full mating of the part. Torquing the retaining nut to the specified torque is important and this can be a bit tough. gently tapping the wheel to make sure it is seated can help. At this point disassemble and inspect the parts for damage or gauling that would prevent the taper from seating properly and dress the parts lightly with emery if the surfaces have been damaged. Make sure replacement key fits tight and is the right one.
Posted on May 23, 2011
  • 1 more comment
  • Fred Yearian May 24, 2011
    Here is a site you should read: http://outdoorpowerinfo.com/repairs/flyw...
    I could not find the torque spec for that particular engine, but others I saw a 65 ft-lb spec for a 15/16 inch flywheel nut.. When you tighten it, wait a bit and then check torque again as some cold flow could result as parts mate.
    If there is any slop in the keyway, get some Loctite that is for the purpose. The real torque is carried by the tapered joint however, so perfect fitup is important.
  • Fred Yearian May 31, 2011
    Glad to hear it is fixed. If there is any slop in a keyway they just pound the key until it shears. I have seen them pounded until they get almost round and the excess metal is squeezed out lengthwise before it shears. Keys have to fit tight say with .001 max gap and Loctite is a good product when perfect fit is not possible. When mower blades hit a rock, the torque of the inertia of the flywheel is tremendous... and that can start the downward spiral to failure of the key.
  • 496 Answers
When you shear a key is can damage the key way and roll the lip check that to make sure it is ok, the key has to set right as will, if it is off it will shear. take your time and make sure there is no play when you put the flywheel on it has to tight or you'll chase your tail. let me know what you find
M.Woodring
Posted on May 25, 2011
  • 10,319 Answers
Get a case harden flwheel key instead. The manufacturer makes these keys from soft metal so the blade will shear the key off when heitting a tree stump or a large rock.
If you have a beautiful manicured lawn a harden key is right for yours
Posted on May 24, 2011
    Master:
  • 448 Answers
That's odd the key way shooed be tight with no slack in it make sure the bolt is tight and use lock tight (blue) on the blade on the fly wheel Ware the pull starter same thing the key way must be the right one if there is any slack it will cut it right in half
hope this helps you
bob
Need a repair manual .pdf for a Briggs and Stratton Model 311707 Type 0132-E1 engine
H.A., Check the attached links,instruction and guides for Briggs and Stratton, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My 311707 0132 E1 Model Overview from PartSelect com
http://www.smallenginesuppliers.com/html/engine-specs/briggs_vertical_shaft_engines/276781SingleCylinderOHV.pdf FAQ Small Engine Specifications Briggs Stratton Specs
Briggs Stratton Small Engine Specifications
Jul 01, 2016 | Measuring Tools & Sensors
Briggs & stratton mod. 406777-0115-E1 engine backfires thru exhaust
This is a true tale sign of a valve being out of adjustment or possible burnt or sticking. Most likely its just out of adjustment. Setting them to Book Specifications of: Valve Clearance (cold) IN and EX .005" (0.13 mm) should take care of the problem. Since you said that it runs fine rules out the possibility of a sheared flywheel key, though I have seen one run with it slightly sheared. Thanks; George
Apr 22, 2013 | Briggs & Stratton Garden
Starting trouble
if it's on a pushmower you will have to remove cowling to expose top of crank & flywheel & confirm the key holding the flywheel in place has not sheared. common issue after abrupt stop of blade. If carb problem would need more details on type of briggs. did you check for spark? if you have gas check to make sure float is not stuck closed. sometimes with gum buil up the needle sticks & stops gas flow. i have tapped slightly & been lucky to free but more often have to take apart & clean
Feb 20, 2013 | Cars & Trucks
Engine won't start and backfires
Did you loosen the coil when you changed the key? Check the setting between the flywheel and the coil. !0,000ths, I think.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton engine on my lawn mower won't start.
Remove the blade and check the keyway. If the key way has the shear pin still in it it may have been bent and not sheared off. That will cause it to be off timing. I would imagine the valves got bent from the sudden stop of the engine as well
May 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
380 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
