Question about Dell E172FP 17" LCD Flat Panel Monitor
I HAVE GOT A DELL LCD COMPUTER MONITOR. I WENT TO PLUG IT IN TO SEE IF IT WOULD POWER UP AND IT WOULDNT! WHAT COULD BE WRONG WITH IT? DOES IT HAVE A REST BUTTON? THE LIGHT ON THE POWER BUTTON DOESNT EVEN TURN ON. PLEASE HELP!!!
  • 11,361 Answers
It can be blown fuse, bad cas, shorted transistors, etc. There are more than one version of this monitor, see pictures here:
http://s807.photobucket.com/albums/yy352/budm/DELL/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Replacement board: http://www.lcdrepair.us
http://www.lcdrepair.us/E172fpbvideo.html
Posted on May 23, 2011
I just had had it repaired before it went wrong again... so I dont want bring it to a repairman again... I think if It was a minor error only it wouldnt have gone wrong after being repaired for the second...
Can you be more specific about "went wrong"?
Are you looking for repair help or are you just venting?
These are wonderful but complicated monitors.
I have sucessfully repaired many.
Monitor Mike
Jan 10, 2011 | ViewSonic VP2030b 20.1" LCD Monitor
The monitor went dark, seems to have no power.
Totally darken the room your computer is in, and see if you can see a very-dim image on your computer.
If so, it could be the "inverter" part inside the LCD that has failed (about a $20 part, but will take a technician about $50 to $75 to disassemble/replace/reassemble/test).
Try connecting the monitor to a different computer, to see if the monitor is OK.
Try connecting a different monitor to your computer, to see if the video-card is OK.
Jun 23, 2010 | Dell 1704FPTt 17" TFT LCD Flat Panel...
Monitor keeps turning off but power says it's still on
You are OK with the power cord, more likely to be failure in the power supply/Inverter board, look for bad fuse and shorterd transistors, see Dell pictures here: http://s807.photobucket.com/home/budm/allalbums
Transistors should be checked out off circuits.
Mar 16, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor went to black. checked and changed all
Check our web site at: www.ccl-la.com/badcaps.htm We have a free repair guide for that model Dell monitor.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Nov 03, 2009 | Dell E173FPb 17" TFT LCD Monitor
I plugged it in and the screen came up for a second and then went black. I turned it off and turned it back on, the screen came up for a second then went black again. What could be wrong?
is the cpu running ,, with connection to monitor,, you can try restart,, and go to display properties,, screensaver,, there power button and change the settings,,,
Sep 27, 2009 | Dell E173FP 17" LCD Monitor
Dell monitor
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's most likely the problem. You can confirm that it's actually the monitor and not your computer or the cable by plugging in another monitor if you have one to try. If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old your monitor is, and how much you've invested into it, you may find it better to just replace it with a gently used one from ebay.
Jun 09, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Dell LCD TV won't turn on
check the cable who comes from the cpu
May 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Plugged speakers into wrong slot and the monitor went black and the tower started beeping. Monitor and the tower both have power
Hi...there,
Oh...common...plugged to a wrong hole doesn't caused a black out...It's seems you got a busted backlight inverter....
Jan 09, 2009 | Fuji FP-988D 19" Flat Panel LCD Monitor
Dell LCD - Power problem
To my knowledge, there is no easy fix. If the LCD is not powering on and your AC adapter indicates there is power, then it is in the circuitry of the LCD assy and your best bet is a TV repairman.
Odds are, that you can buy a replacement cheaper that the cost to repair that one (1800FP is an 18" LCD by the way) You can buy a 19" Wide aspect Dell LCD at Walmart for $199
May 19, 2008 | Dell 1503FP 15" LCD Monitor
Dell E172FP 17" LCD Flat Panel Monitor Logo
50 people viewed this question
Alun Cox
