Question about Husqvarna Chain Saw 20" Bar
I have a Husky 445 Rancher that once started the blade spins fine, but once the blade makes contact with the wood the blade stops spinning. Also the blade tension seems to slip and the blade becomes sloppy. Please help
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
The centrifugal clutch on the saw has probably most failed or is right out of adjustment. best to look that this is engaging properly first
Posted on May 23, 2011
I have installed a new blade in my circular saw R32021 and the blade stalls even before I begin to cut wood
by stalling do you mean that the blade stops spinning or the motor stops turning
if the blade stops spinning then the mounting bolt for the blade is not tight enough
if the motor stops spinning , junk it and get a new unit
Jan 20, 2017 | Blade Saws
My Ryobi 10" chop saw was stopping mid-cut. Why is it making an awful noise now?
The nut that holds the blade on May gave come loose. Or motor is shot
May 02, 2015 | Saws
Circular saw spinning but not cutting wood
Does the blade actually stop when you try to cut or does it spin but not cut. If it is stopping, and the motor is still running then I am afraid you have stripped gears and will need anew armature and spindle gear (sometimes complete with spindle, sometimes a press fit with a woodruff key to locate it). If the motor is stalling then it would suggest that the field coil is faulty, but you would notice excessive sparking from one brush if this was the case. if you get major sparking from both brushes then the armature is probably faulty, or if you are lucky it could just be brushes wearing low and not making a constant contact.
If the blade is spinning and not slowing when you try to cut I would think it is either blunt or mounted the wrong way round.
Sep 21, 2013 | Worx Versacut Mini Circular Saw
Blade stops when feeding wood
It may be that the motor is under powered for the load, but more likely it sounds like the motor is defective. Perhaps some of the windings have shorted. That might allow the blade to spin, but stop under any load. What brand and model is this saw?
Jan 30, 2018 | Bosch 4000 - 07 Electric Table Saws
Chain spins when not cutting
Sounds like a clutch issue but if the chain is spinning once you start the unit you'll need to do some adjusting to your carb.
Apr 13, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Cutting stair stringers with circular saw
the start of the cut is starting to close up and pinch the back of the blade once you have gone past centre,if the blade is past the starting edge you can tap a small wedge into the start of the cut and that will stop it .I AM AN EXP SAW PERSON TO PROVE IT I ONLY HAVE A THUMB, AND ONE REATTATCHED FINGER ON ONE HAND .that happened on a bench saw only the back of the saw blade lifts the wood and for some reason i pushed it back down,DUMB ..Be careful and think before you do , But a wedge will solve your problem
Aug 19, 2009 | Saws
Sears edger blade stops spinning, spins in air fine
check the clucth assamble in the head of the edger it sounds like it is slipping
Aug 16, 2009 | Craftsman Garden
Impact wrench never stops spinning!
you have a bad o-ring at the air inlet
Apr 16, 2009 | Impact Husky® 1/2" Wrench
Cant get the old blade off
should be a blade lock button, if not i clip vise grips on mine let the table keep the blade from turning put wrench on nut and tap wrench with hammer see if ya can loosen nut good luck billy
Mar 18, 2009 | Husky Wet Tile/Stone Saw with with Laser...
Husqvarna Chain Saw 20" Bar Logo
152 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
