Question about HP LaserJet M3035xs MFP All-In-One Printer
Set up a mail merge for labels avery L7162, but the printer prints them a different size - Printer is HP M3035. It is something not set up on the printer
  • moman2001 May 23, 2011
    Have you verified using a print preview that the document margins are not different from the template? If the print preview is not available, you might want to print to a PDF printer and look at the printed file, Does it look correct in the PDF file?
    Also Does the template that you are using have at least 0.25" margins on the left and right sides? If not, the printer will add the margins so that it will feed correctly.
  • HP Master
  • 1,915 Answers
You will need to feed these through the manual tray and you should set the paper size and type to match this label. The avery site shows this as an A4 label sheet. If you are in North America the default on this printer is letter size not A4.You should also ensure that you have configured the print driver correctly when you go to print.
Posted on May 24, 2011
How to print labels
Use Avery Label sheet.
Set correct paper size on Word and the Operating system.
Use label from Sheet feed tray only.
According to the printer specifications for the Officejet 8600 Pro Plus, the following label sheet sizes are supported;
HP Officejet Pro 8600 All in One Printer series N911 Manuals
Mar 15, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
What settings does my printer have to be on to print avery 5292 label
In Microsoft Word, click Tools, Letters and Mailings and select the label from Options. It is done from the authoring software not the printer. All the Settings are self explanatory, set the page size to Letter.
Apr 16, 2015 | Canon imageRUNNER 1025iF
Avery labels set
try going to driver printing preferences /paper or paper/quality tab and set your size for custom and to the 4 x 6 specific size for that sheet and the type as labels for tray 1.
Oct 21, 2013 | HP LaserJet 1020 Printer
How may I do a return address label--all 30 labels on 5160 Avery template without typing the address 30 times
Hi Jan,
You can use the option Mail Merge In Microsoft Word to print Return address.
If you are Using Windows 2003, Follow the link below
http://www.wikihow.com/Mail-Merge-in-Microsoft-Word
If you are using Windows 2012, You will find Mail Merge option under Mailing tab on top - Create Mail Merge option
Regards,
Sean
Apr 22, 2013 | HP Officejet 6310 All-In-One InkJet...
Printing avery labels
You need to check the driver settings inthe printer properties and make sure that you are selecting labels as the paper stock. Often times this will adjust the fusing temperature so the toner is melted thoroughly on the label. You may also check the toner..some compatible brand toners do not do well on Avery labels.
Mar 27, 2013 | HEWLETT-PACKARD CP1025 Laser Printer
I have an HP 5550 Series Deskjet printer. Only recently, I have encountered difficulty printing labels. I have double-checked the Printing Properties, including label size, label paper size, Avery paper #,...
This printer have the capabilites of sense the size of label, each colomn width.
So, you must set the right size of colomn width, in your application (ms. word) to match label width.
May this help.
Oct 10, 2008 | Office Equipment & Supplies
Problems with avery mac label expert
To reset the size in your printer to the correct A4 size, do this:
Go to your Applications folder on your hard drive.
In it, you will find a Utilities folder.
Inside that folder, you will find a folder called "Printer Setup Utility."
Inside THAT folder, you will find a list of printers you have connected to your Mac.
Click on one. You will see, at the top of your screen, a set of menus. Click on the "Printer Setup Utility" menu at the far left.
Choose "Preferences" from the drop-down list.
You will see a dialog box with three options: Printing, Sharing, and Faxing. If Printing is not automatically displayed, click on the Printing tab.
At the bottom of the Printing dialog box, you will see another pull-down menu: "Default paper size in page setup"
Choose A4, or whatever size you wish.
Close up all the boxes, and print your labels to your heart's content.
When you're done with your labels, don't forget to repeat this process to switch your printer back to your ordinary size paper.
Hope this helps.
-lizwb
Apr 18, 2008 | Computers & Internet
How do you print divider tabs
Depends on the size of your tabs...
In Microsoft Word:
Pull down the tools menu and select "Letters and Mailings" and then choose "Envelopes and Labels", choose the labels tab, and select "Avery 5836 - Divider -Mtg. Creator" or manually set a height of 0.5" and a width of 1.75".
In any Word Processing Application:
Make a table 10x1, set the row height to 0.5", and then set every other column width to 1.75" and 0.5" respectively with a 0.5" left and right margin, 1.0" bottom margin, and a 2.0" top margin. Add rows until you fill the page.
Hope this was helpful and remember to vote...Thanks
Dec 10, 2007 | HP LaserJet 2200D Printer
HP LaserJet M3035xs MFP All-In-One Printer Logo
341 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
