Question about Vizio VA22LFHDTV10T LCD TV
I cannot get any audio from my tv / cable at all. I hae unplugged everything and reconnected. I can see the volume control on the screen and can see it go up and down from the tv and from the cable sepertely, but still no sound. Ay advice?
    Top Expert:
  • Vizio Master
  • 75,591 Answers
Hello
Either your tVs speaker of its audio output IC has damaged. Check the TV by onnecting its audio out jack to any other audio source, like amplifier or so, and see whether there is sound output comes through the outer source or not. If there is sound from the amp; and no sound output from the TV, check the speaker first. If it is OK, replace the audiou output IC. If there is no sound through outer amplifier, the audio detectcion section inside your TV is faulty. You must have a thorough knoledge and skill to repair it. OK.
Posted on May 23, 2011
My t v has no volume
Do you see the volume indicator moving when you press the vol up/down?
Could the internal TV speakers have been turned off? This is done when using a sound bar or a AVR (Audio Video Receiver) aka Home theater
Mar 03, 2015 | Televison & Video
I have a cable controller connected to a Bose sound system and a Haier 32 " flat screen TV. Everything works great until I want to view a DVD, then all I can hear is cable audio with the DVD video. How do...
That sounds like a miss-wired setup. I would unplug the wires and re-wire it making sure the right wires are in the right holes. Sounds to me that the DVD audio is not going to the bose and only the TV audio is.
Mar 02, 2018 | Televison & Video
TV was fine and then suddenly volume went off. Also the controls for channels and volume are not working
Hi
Thanks for using FixYa. Please check the audio with a DVD player or cable box. Also try using component cables if using a RCA component cable or vice versa. Check that all of the cables are plugged into the back of the TV & MUTE button is not pressed. Do a hard reset by unplugging the power cord for more than 4 hours and power it again, then go into the on-screen-menu and make sure the sap is off and stereo in on. Also try audio from Phone and 3.5mm jacks (if equipped). If this all didn't resolves the issue then it is an Audio IC or bad speakers/speaker connection. Please do accept the solution if the issue is resolved else revert for further assistance.
Thanks
Rylee
Mar 11, 2010 | Hisense Televison & Video
Panasonic remote and volume/channel buttons do not work
My son put a penny in the SD card slot of my Pansonic flat screen tv. I finally got the penny out but now the volume and tv controls do not work. I can change the channels through my cable box but that is it. The volume does not work on my cable remote or the flatscreen. What do you suggest I do to fix this problem?? Thanks, Josh
Jun 06, 2009 | Panasonic TH-42PX60U Television
Volume control
We forgot the very last step in programming. I tried programming one more time today and it worked so now everything is working correctly!!
Nov 05, 2008 | Audio Players & Recorders
Samsung LCD Flat Screen TV LN-S2651D - Volume Problem
I lived with it for about six weeks, then took the back off the TV. Just now it seems to be fixed, but I don't know if it will last.
I disconnected the wire leading to the channel up/down, volume up/down and source board, turned on the tv, turned it back off, reconnected the cable, and everything seems fine now.
Aug 24, 2008 | Samsung LN-S2651D 26 in. LCD Television
Audio problems
Good Day, corilyn;
Several things that you may try:
1. Unplug TV and Cable/Sat box for 3-4 minutes, plug all back in, that's resetting the devices.
2. Some boxes have volume controls, make sure 'box' volume are turned to max.
3. Go into TV's customer menu, go to audio section, make sure speakers are turned on/ set to internal speakers.
Good Luck, Big Irish.
Jul 08, 2008 | Sony Televison & Video
Samsung lns4041dx/xaa
Same problem with my set. The volume was either fully up, or fully down (usually down), and other controls didn't work- like I couldn't access the menus and could not adjust the width of the screen/aspect ratio.
Jun 03, 2008 | Samsung LN-S4041D 40 in. LCD HDTV
Sony 36' TV Volume Goes up on own/Stuck on Video 2
There's a setting in the menu. I think it's called "smart audio". It's supposed to adjust the volume automatically for commercials. But I don't think it works that well. Give that a try.
Jan 09, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Vizio VA22LFHDTV10T LCD TV Logo
235 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
