Question about Panasonic EW3109W Upper Arm BP Monitor
Ew3109 get a different reading every time.Can the unit be reset.Or can you send it some where to be checked Thanks
The oil light comes on even after oil change
What kind of car? Do you need to reset the oil change system? This is different on many cars...check your owners manual for instructions, or just go on line and ask "how to reset oil change indicator on...(your type of car or truck:) Hope this helps. If it is a low oil indicator, then you have a different problem...
Aug 21, 2015 | Cars & Trucks
My 1996 Chevy S10 gas guage always shows full when its not
maybe a problem with sending unit in the gas tank? Seems that GM has had this problem. They came up with an additive that you pour into the gas tank supposed to help control deposits on the sending unit.
You may be able to use resisters to check gage system. Get two or three resistors use in circuit one at a time, see if gage reads differently with each resistor, if so, the problem should be the sending unit.
Feb 22, 2015 | Cars & Trucks
My oil pressure gauge is reading high on my 92 pontiac bonnieville sse
I suggest you check your oil pressure with a manual gauge to know the exact oil pressure. If it reads different then it's the sending unit or the gauge itself that is the problem. Most often it is the sending unit. I hope this helps.
Jul 16, 2011 | Pontiac Bonneville Cars & Trucks
Gas hand floats bad and reads wrong says full when empty and empty when full makesno sense...reads different all the time though
more than likely the sending unit in the gas tank, Could be very costly/hard to replace as you must remove the gas tank to get at the sending unit.
Very good set of instructions here: http://www.ehow.com/how_6483038_replace-gas-tank-sending-unit.html
Feb 28, 2011 | 1999 Chevrolet Cavalier
Oil pressure gauge is reading 80 psi. I had the
The oil sending unit is located on the engine block behind the drivers cylinder head area.You have to climb up on the motor to see it cause it is hard to see behind the wiring harness.You may also want to purchase a new sending unit because it is very long and you might need to buy the sending unit socket to replace it.Hope this helps.Good luck.
Jul 20, 2010 | 2003 Chevrolet Silverado 1500
Range rover runs out disel but gauge&computer showes half full
check that the float isnt getting stuck or even bad also check the wires some times the float can get hung up and will only read to a certain point, or it could even your gauge could be off might need to pull the insterment cluster cover off and slide the needle off and reset it i would check the float first though
Aug 27, 2008 | Land Rover Discovery Cars & Trucks
Every time i fil the gas tank the gauge reads empty
I had the same problem...I purchased an inexpensive code checker/reset module at Princess Auto. Plugged the unit under the dash below the steering column and reset the error codes. This forced the gauge to reset and the sending unit now reads correctly. Give it a try.
Jul 21, 2008 | Saturn Relay Cars & Trucks
Panasonic EW3109W Upper Arm BP Monitor Logo
202 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Rick Goldsmith
Rick Goldsmith
Level 1 Expert
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
