Question about Ecoquest Breeze AT Living Air Purifier
Id like some instruction on how to use ? curently trying to remove odours from a vehicle ? some instructions on how to use the unit would be a great help
    Problem Solver:
  • 17 Answers
Odors from a vehicle takes 2-14 hours on "high". Depends on the odors. Run the AC & heater fan for 20 minutes also when the car is full of ozone and have the unit aimed up on the floor toward the firewall on high. You should not stay in the car while doing this. Mild new odors can be neutralized in 20 minutes to 2 hours. Bigger and older problems take longer.
Posted on Jun 27, 2011
I have a bleach smell when the unit is working. This takes away from overall effectiveness as I have to open doors to get the odour out. Is this normal.
If the unit hasn't been cleaned recently and that includes the filter, that may be the problem. Also, be sure to carefully remove and clean the glass plaques. Be sure they are totally dry before reinstalling them.
Hope this helps you solve the odor problem.
Mar 22, 2011 | Ecoquest Breeze AT Living Air Purifier
Blueaire 501 dust caked up on wires and fan,how do you take it apart to clean it?
Hi, I have had the same problem and have figured out how to open it.
To open your blueair air purifier, follow the steps below;
1. Get a phillips head screwdriver,
2. Open the unit and remove the air filters.
3. Use the phillips head screwdriver to remove the screws that you can see.
4. After taking out the screws, remove the "galvanizedSwedish steel housing"
(cream coloured sides) of the purifier by lifting it upwards (i.e. from bottom to top of unit).
4. You will now have access to the interior of the purifier.
5. You can now take out the fan and clean it, or what ever part you are trying to clean. I used a Dyson HEPA vacuum cleaner.
6. To reassemble, reverse the instructions above to reassemble the purifier.
Feb 28, 2011 | Blueair 501 Air Purifier
I was considering Biozone for restrooms etc and I assumed,as your info.says that it would be odour free?Some I have seen are not odour free.Is it just a uv lamp system or is there some form of ozone...
the UV lamp does produce some ozone .. this one specifies .04 ppm .. thats not very much but might be detectable as a slight fresh air odor .. some other types use electrostatic filtering and some even have strong ozone generators .. ozone does kill bacteria, fungus and such and will freshen the air removing many odors but is not considered healthy in large or concentrated amounts or for prolonged periods .. the UV lamp will also kill bacteria and fungus without producing so much ozone.
Purifying Method: Photoplasma, UV, ions, and ozone.
Oct 09, 2010 | Biozone 500 Air Purifier
I have cleaned my ionic pro several times works for a few minutes and then says clean again what can I do?
Please call customer service for Ionic Pro at 800-875-8577. They will provide troubleshooting instructions and if they do not correct the issue, they will give you instructions on how to get your unit replaced. Thank you.
Feb 08, 2010 | Ionic Pro TURBO Air Purifier
I need to lubricate the fan. How do I get to it?
Email to miller@healthyti.com and ask for free supplemental cleaning instructions. The cleaning instructions include detailed fan removal instructions. The cleaning instructions may be beneficial as well, since proper cleaning is critical to satisfactory operation.
Aug 09, 2009 | Ecoquest Breeze AT Living Air Purifier
Red Light
slow blinking light means the unit is in DRY MODE.. flast blinking light means some sort of arcing or bad power supply..
if in dry mode let the unit run for an hour and it will stop blinking ..
Jun 28, 2009 | Oreck XL Professional Air Purifier
Display reads "Perform Maintenance"
Hi Sean,
If the unit is under-warranty, I'd contact the dealer who sold it to you, or EcoQuest customer service (info follows). Get an RMA# (Returned Merchandise Authorization) and take it from there.
If it's not under warranty, they will still repair it, but will charge you. If the controls aren't working, you'll probably need to decide if it's worth it or if you should consider purchasing a new one. Getting into fixing circuit boards or other electonics gets expensive in a hurry.
Hope this helps.
EcoQuest International,
310 T. Elmer Cox Drive
Greeneville, TN 37743
1-800-989-2299
Dec 10, 2008 | Ecoquest Fresh Air Living Air Purifier
Instructions/owners manual for Holmes HAP756-U
what kind of unit/ model do you have for a purifier so i can better assist you
Jun 02, 2008 | Air Purifiers
Flashing lights on Model 1871
I wonder how many others are having this problem? It sounds like the wiring "went out" about the same time on all of these. Strange how it went bad just after the warranty ran out too. Something is fishy here. Planned obselescence? Anyone know a good attorney. Sounds like a good class action suit. I have two units. Bought them at the same time and both started flashing at the same time.
Nov 04, 2007 | Sharper Image Professional Plus Ionic...
Ecoquest Breeze AT Living Air Purifier Logo
59 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
