Question about Samsung UN55B8500 TV
We are having problems with the volume on our Samsung LED Series 6 6400/6500 TV. We know how to adjust the volume, but have to keep turning it up higher and higher. When we wanted the sound low, in the past, we would set it to around 21; however, how we have to wet it up in the high 40's. Is there any way to adjust that. used the remote and found the way to adjust it to high and did that, but it did not help. Thanks for your assistance.
SOURCE: Remote not working
I have the same TV, and it has developed exactly the same problem! Hopefully there is a solution...
Posted on Sep 23, 2007
SOURCE: New Samsung Tv High pitched hum
There is a specific reference to this condition on the Samsung support website. My new LN-T3253H had the same whistling problem when I first started using it. Several days into use the whistle has subsided somewhat. I entered a tech support case on the Samsung support site and Samsung is sending a technician to my home to perform a repair - no charge as unit is still under full manufacturer's warranty.
Posted on Apr 04, 2008
  • 8 Answers
SOURCE: Max. VOLUME on Samsung TVs Too Low
Some models have a volume limit setting, check the MENU and look at the audio settings.
If this has external speakers use other speakers. If it has audio output connect them to a external amp and useing the remote adjust the volume. Check if audio settings are set to internal, external and fixed or vairable output.
Posted on Jan 10, 2009
SOURCE: my samsung ws28a116d remote will only adjust the
To reset the remote so that it works properly again, take the batterys out of the remote, then press and hold the power battery for at least 30 seconds to drain out any power left in the hadnset , then replace battterys and it should work again. We had this fault and this solution worked for us
Posted on Sep 26, 2009
SOURCE: Samsung P237HD tv/monitor,unit buzzing when on.
Had bad buzzing after connecting an old Proton monitor (1986) to cable box. Read some of the solutions here, readjusted the manual Balance -- presto. Sharing this in case it helps others. Thanks, all.
Posted on Jun 18, 2010
Samsung UN65F6350A turns off and restarts
Hi William I have the same tv. It had the same problem. I had to have the main board replaced. It seemed to fix the problem of turning on and off randomly but now i have a problem with the screen.
Feb 19, 2016 | Samsung 6350 Series UN65F6350 65" LED...
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from
Easy fix for new Samsung TV switching on and off power ...
? 4:41
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
Problems with screen
Is this a LCD, LED OR Plasma Television? Or Do you know the model Number, model number usually in the back of TV.
Feb 07, 2015 | Samsung Televison & Video
Volume adjusts on it's own on my Bush standard TV Bush LED26916HD 26" HDTV-Ready LCD LED TV FREEVIEW
My bush 50inch .volume kept going up and down.only to discover i had the audio description on.turned it off via the menu options and it was fine then
Jun 22, 2012 | Televison & Video
How could the ring volume be adjusted (turned down or off) on a samsung inkjet tel./fax SF-340 series?
To adjust the ringer volume, simply press the left/right arrow buttons, the SF340 must be in standby mode.
Every time you push one of those buttons, the ringer volume will be changed down or up. Volume 0 means no ring.
Please let me know if it helped.
Aug 10, 2011 | Samsung SF-340 Plain Paper Inkjet Fax
I have a '96 samsung 25" tube tv. model # TXE2546 - series # 3CAG700429. when i turn it on it has always made a click sound a couple of seconds afterwards. the "power & timer" led light flashes about...
This problems the FBT-the Flyback Transformer have cold solders.Must resolders the FBT.The right side wall of the FBT-the "H" horizontal transistor,must be also resolder too.
Oct 18, 2010 | Samsung TXJ2754 27" TV
Image not as clear from HTPC on Samsung Series 5000 LED 55
Most PC video cards have their own adjustments for Color and Gamma corrections. I know exactly what you talking about. I have a similar setup and have seen the same problems. You should try switching the Color Gamut if possible. Television broadcast use the NTSC Gamut. A PC can have a predefined Gamut for any number of purposes and applications. Ex: Adobe has several for you to choose from. I hope this helps as a starting point for researching the problem, as I realize it is not a firm solution.
Mar 15, 2010 | Televison & Video
I just connected a new Samsung LED/LCD TV. I am
programm the remote to your tv by pressing the TV button till all lights light up at the top then enter your 3 digit tv code ( samsung codes are 738, 516 or 680 then press pound. this should enable you to controll power and volume, be sure to press sat to operate you dish recvr.
Oct 07, 2009 | DISH Network Televison & Video
My brightness keeps resetting
i had the same problem....... on the actual tv u have to press and hold the volume button and menu button together for about 5 seconds and then on the screen it should say dynamic and that hopefully will sort it for u. Worked for me :)
Dec 27, 2008 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
Samsung UN55B8500 TV Logo
75 people viewed this question
Jerry Greenberg
Jerry Greenberg
