Do u have try look at drum. most likely tht only drum problemb
Hi, According to your problem, first check the cyan tonner is
not get damp. Clean the cartridges and make sure that the cartridges are
installed properly. Check the paper tray installed correctly and it pull the
paper properly. Finally check your paper status like the papers which you use
print are not damp, wet or curl. Use to try another new good quality paper.
It might be the Cyan toner cartridge which is defective or not properly insert. If toner cartridge is faulty, just replace it with new one. If not correctly installed the Cyan toner, sometimes it will not work well or cause problem when printing that color. If you have the old Cyan toner, try it.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
I've tried 3 different Cyan toners (2 brand new and 1 that cme with the printer which had been working fine until the problem occurred). Also don't think that there is an issue with the toner not being inserted properly
Toners are fine (I've tried 2 new cyan toners) and nothing obvious that would indicate that they have not been inserted properly
paper and toner are fine...problem of Cyan toner dropping out on only the bottom half of page still persists
