Question about Inverter 1000-2000w Peak Surge Power
What does soft start mean - Inverter 1000-2000w Peak Surge Power
  • 396 Answers
Soft start will slowly ramp up the current to the load preventing a surge of current from a cold start. It is similar to having an automobile and pushing the accelerator to the floor to accelerate from a stop using maximum engine horsepower. A soft start would be to accelerate gradually from a stop to the maximum engine horse power which would prolong the life of the motor.
Posted on May 23, 2011
Mcculloch mp49 will not start, doesn't seem to be getting fuel, any pointers? has good spark
no fuel delivery means fuel system problems. service your carb and check your fuel pick up in the tank and all fuel lines. lines should be soft not hard and should not be mushy but should be soft
Oct 02, 2014 | Garden
Daytona 955i soft brake leaver
If by "soft" you mean "spongy", that usually means there's air in the system that needs to be bled out.
Feb 03, 2014 | 2003 Triumph Daytona 955i
What is the soft key
Look at the display on your phone. You'll see some labels at the bottom. These correspond to the keys just below the display. The meaning and function of these keys vary according to context, and the labels change to reflect that. Thus the keys are "soft" in that their meanings change.
Mar 20, 2012 | Vtech DECT 6.0 Digital Cordless Phone
What is meant by a soft start
Soft start means that your grinder will start at a slower speed, then rev up to the normal speed, so the grinder won't "dig" into your work.
Hope that helps.
Handie Andie
Mar 25, 2011 | Makita GA7040S 15Amp 7" Angle Grinder Soft...
What is a soft start?
Recently, the growing market of portable electronic devices brings greater demands for power management integrated circuit (PMIC). Among different PMIC, DC-DC converter is important in regulating the power supply, due to its high efficiency, capacity of outputting current and small static current . However, an inrush current and overshoot voltage appears in the startup period of the DC-DC converter, which may causes damage to the whole system and the load. Thus, a so called soft-start function is adopted during the startup stage of the DC-DC converter, which smoothly conducts the output voltage and current in the inductor to the steady state.In a typical DC-DC converter, as in Fig.1 a Buck system, a negative feedback is applied to build a system that automatically adjusts the duty cycle to obtain a given output voltage maintaining steady under all conditions [2]. Usually the output voltage is measured with a factor of H. The sensed output signal Vfb is compared with a reference voltage Vref. The negative feedback loop makes the sensed voltage accurately follows Vref, so that a constant Vout achieved. Accordingly, Vref can be replaced by a ramp signal during soft-start, holding the output voltage to climb bit by bit. As the duty cycle is limited, an inrush current can also be suppressed. During soft-start stage, a ramp voltage VSS is generated from a capacitor charged by a current bias. The smaller one VSS is added to the feedback loop, compared with Vref by a comparator, until it reaches Vref. The drawback of this method is that the soft-start capacitor CSS is usually too large to be integrated on chip, which means additional pin and PCB area. Furthermore, voltage spike may still occur at the end of the soft-start, because two control signals Vref and VSS are put through at the same time by comparator, and compared to feedback voltage Vfb, To DO A SOFT-START First, a whole power up the system is enabled by signal ENA, a simple bias is initiated.The LDO (Low dropout regulator) works by this rough bias.When the LDO is stable, it outputs power supply to a precision bandgap. BG_ready signal will go high when the precision bandgap stably works. The bias of LDO will change from a simple one to a precision one, leading to a more precision LDO output. When the power up process is over, an LDO_ready signal is sent all over the chip, and the rest of the chip will work then. This whole process will guarantee a safe power environment to sensitive analog modules. This LDO_ready signal will also tells the state control module to change the stage form SD (shut down) mode to SS (soft start) mode. When the soft-start is accomplished, an SS_ok signal will switch the stage to NM (Nmoral operation) mode. Furthermore, the entire protection signal can be incorporated in the state module to boot different operation stage...hope this helps
Jul 01, 2010 | GE Electrical Supplies
New Game + Not Functioning Enchanted Arms
Ummm... wouldn't this be better on the Ubi-soft forums?
Mar 19, 2010 | Ubi Soft Entertainment Enchanted Arms for...
Comes up with a red cross on screen and l cant get to the menu
The red cross means that you need to perform a soft reset.
If your device is not starting up properly, follow the steps below: >>
  1. Soft reset your device.(<Click)
  1. If your device still does not start up, then reinstall the TomTom application using HOME.(<Click)
If you found this information helpful, please give me a big thumbs-up when you rate my answer.
Feb 05, 2010 | Tomtom GO 720 GPS
I want to reboot my computer acer. How can I do that
Reboot basically means to "restart" the computer. You have a soft reboot which means hitting the reset button on the front of the computer or going to the start, shut down, restart computer. A hard reboot is shutting the system off completely and then turning it back on.
Nov 29, 2008 | Acer Computers & Internet
My HTC tytnII do not start
Hi
Not sure what you mean.
Do you mean it won't switch on?
or
Do you mean it wont charge?
or
Do you mean it won't switch on or charge?
Does it show a Red LED at anytime?
Mike
Sep 09, 2008 | HTC TyTN Smartphone
Inverter 1000-2000w Peak Surge Power Logo
179 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
George Scott
George Scott
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
