Question about Whirlpool LER4634J Electric Dryer
My dryer stoped working. I jumped the wires to the non resetable fuse and it worked. so i put new fuse in it worked for 5 min. or so then blew the fuse. what do you think?
    Brigadier General:
  • 3,301 Answers
Motor feedback,, its probably shot , take the belt off the motor,, and make sure the tub spins freely, if its binding at all, this could be the problem
Posted on May 31, 2011
Amp fuse 30a keep blowing
You have possibly melted a couple of wires together along the radio circuit. Also the radio unit itself has 1 or more protection fuses actually inside the unit that have blown, usually at back of unit in little bay near the wire clusters.
Check your relays too, a blow out through jump starting can do all sorts of little burn-outs.
Oct 15, 2016 | 2006 Lexus Rx 330
Fuel. temp gauges stoped working
I don't think they're related unless your brake master cylinder has a fluid level sensor in it. It's possible the wires have shorted together and blew the gauges fuse.
Dec 17, 2015 | Cars & Trucks
After jumping a car my cluster pannel stoped working on my 2003 GMC Danali
I would guess you blew the fuse for the cluster.
Have you checked them with a test light or meter yet ?
Sep 23, 2012 | 2003 GMC Yukon Denali
The thermal fuse blew on my dryer so it will not start. if i jump the two white wires together it will start. the wireing diagram says it is not resetable. would that have blown because one of the...
Hi, When ever you are replacing one the other(s) should always be replaced...so yes replace everything while you are at it...
heatman101
Sep 16, 2010 | Maytag Dryers
Kenmore dryer - put in new thermostat, had to jump fuse because couldn't get one today. Put a few clothes in dryer & it ran fine.After about 10 minutes I noticed dryer was shut off. Checked clothes...
why didn't you just wait till you got the fuse?you blew the first fuse because something is wrong and overheating it,you might have just needed to clean out the dryer because that's usually the cause of poping them now you might have cooked wires or anything else,not smart,what fuse did you jump out and send complete model number
Nov 07, 2009 | Kenmore 63942 Dryer
Miele T358C Dryer Blew up!
it could be a shorted heating element a shorted to the case, motor start capacitor, or a defective motor ,f i would inspect the first two items closely
Sep 20, 2009 | Miele Novotronic T240 Electric Dryer
Ac new and ran for 4 months then stoped.
Try checking the spacing of the clutch of the compressor to your A/C...chances are the gap is too large and will not pull down to engage the compressor. That should eliminate the jump wire and keep your car snowing. No clutch to engage the compressor, no A/C.
Apr 19, 2009 | 1999 Chevrolet Lumina
2001 S-10, Blowing "ECM Batt" fuse after running for about 30 min
that fuse feeds power to fuel pump relay circuit that feeds pump could be defective pump,or damaged circuit wires that shorts out! and not a good idea to put higher fuse in circuit could cause more damage to circuit! but i know when your stuck, u do what it takes,so inspect circuit related to fuse,
Mar 10, 2009 | 2001 Chevrolet S-10
Will not start
first check door switch if it is gas also check non resetable fuse located in rear on blower housing
Nov 12, 2008 | Kenmore 63942 Dryer
Dryer has no heat on any setting after house fuse blew.
We got the problem with our dryer figured out. After checking possible solutions on-line, we checked the power going into the dryer with a ohm tester and discovered we weren't getting full power that we expected. Just after changing the fuses in the house the first time we heard a snap sound but the fuses appeared to be fine, but no heat to the dryer. When we discovered we weren't getting full power we used the ohm tester to test the fuses indiviually and discovered one of the fuses were bad. Put in a new fuse and wala! the dryer is putting out heat. Thank you so much for the service you provide to "do-it-yourselfers" like us!
Nov 10, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
37 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
