Question about Dryers
Machine makes a buzzing sound but the drum does not turn
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on May 25, 2011
My dryer motor comes on (you can hear a humming noise) but the drum does not turn.
GE dryer won't start. Makes buzzing noise... - YouTube
? 0:39
www.youtube.com/watch?v=W_og12QJqm8
May 8, 2010 - Uploaded by maxicheong Anyone seen this before? When i tried to turn on the dryer, i get ahumming / buzzing sound and the drum ...
Oct 08, 2015 | GE WE12M22 Dryer
Hotpoint TDC62p is making a buzzing/humming sound and the drum will not spin though it does move if you push it.
Either something is binding the blower wheel up or the motor is bad. The best thing is to take the front of the machine off to access the blower wheel to verify ifanything is indeed binding it.IF not read the next section.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 17, 2012 | Hotpoint Tumble Dryer Tdc60n Tdc60p Tdc60s...
The drum is not turning but the power light comes on hear a buzzing sound coming from inside also its still heating up
If this machine is older then 8 years, It may have died. Also, If the machine was recently over-filled with too many clothes, and if it is over-filled on a regular basis, it can destroy the machine's ability to turn the drum. We had a similar problem with an old machine...someone over filled it and the drum died.
Mar 28, 2011 | Washing Machines
Drum won't spin on its own, makes a low buzzing
either your bearings have gone or u have something trapped between inner and outer drum
Mar 20, 2010 | Washing Machines
Dryer has started to make a loud sqealing when it starts and gets up to speed, the kind of sound a loose fan belt makes on a car, and now just makes a buzzing sound when the button is pushed but dosen't...
If you push the start button and you here a buzzing sound, This sounds like the motor is bad.
Somthing you can try and this might not work. but open the dryer door and turn the drum a littel bit then close the door and try to start it. If it starts running again then you have hit a bad spot on the motor.
If it just still just makes the buzzing noise then the motor is most likley bad.
Jan 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Amana electric dryer just stopped working. I pushed the knob, there was a loud buzzing sound, and then the dryer just stopped
The buzzing sound is the motor trying to start and not being able to. There is either something stuck so that the motor can't turn or the motor is bad. The most likely case is that the motor has failed.
You can trying turning the drum by hand and make sure that it is free. Also by turning the drum you will sometimes get the motor off of a "flat spot" in the motor and it will run for a while again.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 30, 2009 | Washing Machines
Yamaha DTXtreme IIS Drum Moduel repair
Listen to the output with headphones to check for noise.
OFTEN the output of a drum machine is CORRUPTED by an inadequate sound system. The waveforms generated by a drum machine tax the sound systems. A bass drum output can drive the speaker cone such that it goes beyond the linear range that the speaker and amplifier can handle and this appears as "noise". The noise may sound like a buzz or totally break up.
Turn the volume down and see if EXACTLY the same noise appears at low levels. If not, then saturation of the amp and speaker is likely. Continued use while it is doing that will often destroy the speaker.
Nov 28, 2009 | Yamaha Music
WASHER DOES NOT TURN
Sounds like the motor has frozen. Try to work the drum loose from the bottom (empty and unplugged) it just might be jammed from a pen or similar item lodged inside (someone not emptying their pockets). Since its buzzing (its the motor TRYING to move the drum) it has to be jammed from something. Rarely it could be a bearing locked up in either the drum or the motor itself though its unlikely.
Mar 21, 2009 | Washing Machines
Dryers Logo
Top Dryers Experts
