Question about Black & Decker Drills
The chuck is frozen on my 14,4 Black and Decker cordless drill. This is the second time that has happened with a Black and Decker drill so I assume it is a product defect. In use it was not that tightened and happened with normal use.
  • Black & Decker Master
  • 43,501 Answers
Yes, they are an inferior product. However you can replace the B & D chuck with a Jacobs chuck that will hold up and last for a long time!
Jacobs Chuck
heatman101
Posted on May 23, 2011
The chuck on my drill willnot turn in either direction
The same thing happened to me. I found the carbon bar that contacts the motor had broken and it was jammed. For around $25 I got a new motor and replaced it. The unit I had was a Black & Decker.
Aug 04, 2014 | Black & Decker 18V Cordless Drill/Driver
12 volt black and decker keyless chuck will not close. Model CD120G
Try giving the inside a spray with WD40 then try closing the chuck. Check that there is not a left handed screw in the center of the chuck that has become partialy unscrewed. The chuck can jam open and just need a strong gril to release it. If the outer sleve of the chuck is turning but nothiing happens then you will need to get the chuck replaced.
Jun 10, 2012 | Black & Decker 18V Cordless Drill/Driver
Black & Decker cordless drill 9.6V chuck will not come off shaft
If it won't close the only other option you have is to break the outer collar and use a chisel to hit on the exposed jaws inside the chuck. I have detailed instructions in the tip section on how to remove a chuck from these drills. Let me know if you need more assistance.
Jan 31, 2012 | Black & Decker Drills
New Black and Decker, 18 volt, cordless drill. I can't tighen the bit
I oil mine up to help the jaws move . also check the screw at the base of the chuck inside its a standard head. shine flash lite where you put the bit it holders the Jacobs chuck to the shaft.
Jul 07, 2011 | Black & Decker & Cordless Drill
I bought a Black & Decker 7.2v cordless drill with
Just charge battery put bit in and your ready to go.
Jul 04, 2011 | Black & Decker Drills
How do I exchange bits in the keyless * BLACK & DECKER 12-Volt 3/8" Cordless Drill
In Black and Decker drills when the drill stops turning the chuck spindle locks automatically. All you have to do is grip the outer sleeve of the chuck and turn it anti clockwise to open it. Turn it clockwise to close it. When you press the trigger to start drilling the spindle unlocks automatically again.
Jan 10, 2011 | Black & Decker Garden
How do replace a chuck on a black-decker cordless drill
you must open the chuck all the way and the screw is in the back inside the chuck this is a left screw which means its righty loosey and lefty tighty; unlike normal righty tighty and lefty loosey.
Mar 29, 2010 | Black & Decker 18 Volt Cordless Drill...
How to remove chuck from cordless Black and decker drill
open the chuck all the way then look in and you will see the head of a screw take that out .
then you need to hold the arbor some how so you can un screw the chuck from the shaft.
Nov 06, 2009 | Black & Decker Drills
Black and Decker Cordless Drill Chuck stuck in full open position
I'd put penetrating oil in it and tap the chuck with a plastic hammer. That should free it up.
Best rgrds, W/D
Aug 18, 2009 | Black & Decker Drills
Insretion sdrill bit
Loosen drill chuck, insert flat end into chuck and tighten.....go drill some holes!
Jul 10, 2009 | Black & Decker & Swivel Cordless Drill
Drills Logo
217 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
